| 600/600 PRO Aftermarket Upgrades and Mods Align T-REX 600/600 PRO Aftermarket Upgrades and Mods Support |
#1481 |
Is it the tail gear you mean? It sits under the maingear just with the shaft through it. Did you turn the hub upside down? I think the screws are mounted downwards and up ( screwed towards head)
#1482 |
Thank you!
I will leave some space between pinion and main gear then.
Protos 500 T-Rex 600 12S Raptor 60 V2 Logo 600SE To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#1483 |
#1484 |
Hi I have a TRex 600CF setup:
My T-Rex 600 FBL. With Castle 1717 Motor 1500 KV 4 Pole, 14 Tooth Pinion, KDE Mod.7 Main Gear 164 Tooth, WR Super BEC set at 6 volt, Castle Link Quick Connect, V Bar 5 Pro, Futaba R6008HS receiver, Futaba 10 CHG 2.4 G Transmitter, 6s 22.2 Volt 6000 mAh Nano-Tech Battery 25-50c, 3 - Align DS610 Cyclic Servos @ 6V, Futaba BLS254 Tail Servo, WR LED Tail Step Down 5.2 Volt. My question is that I have to run 2250 RPM or the heli seems to lag a little on colective. I wanted to run a lower head speed. If I converted it to 12s could I run a lower head speed and not have this lag in collective ? I have a 4035-560 Scorpion Motor, Kontronik 80HV or 120 HV. I also have 2 sets of custon heli parts 2mm carbon frames, it says they are cut for the larger motors. I have the Align FBL head but I am thinking of switching to the Compass FBL head or Trax. |
#1485 |
Well I'm just about done with her and it's about time! I have 13+ At full stick and center stick I have 0 and lowest stick I have -13 degrees pitch!!! WOW!!!! I could get 18 degree's of pitch out of this head if I wanted to. Can't wait to get ti in the Air. I have the ESC and the BEC, Servos mounted now the motor. and the RX Then she will be ready for her maiden flight I so CAN'T WAIT!!! My first 600 and first 12s system!!!
