Go Back   HeliFreak > R/C Helicopter Support > 600 Class Electric Helicopters > 600/600 PRO Aftermarket Upgrades and Mods
600/600 PRO Aftermarket Upgrades and Mods Align T-REX 600/600 PRO Aftermarket Upgrades and Mods Support
Old 06-05-2010, 03:40 PM   #901
ady
the thing is , i`ve flown this heli a lot , and i mean alot , 12s or nitro , same heli tho , flybarless without electronics , i fitted a 3G a sort while ago and after a few flights she went in due to cyclic failure , took the 3G back to get checked but it got lost in the post , so the shop gave me the parts to rebuild anyhow , i`ve been flying this heli the past few weeks FBL with no electronics agains cos i enjoy it , on thursday i was given a new 3G unit , so i fitted it , and friday evening on the second flight , i lost all cyclics n tail and in she went please note , another reg ( flighttech) was being used at this time , rebuilt heli this morning with wifes credit card , removed reg and went direct from a 2s li-po cos the 3G can take it and i`ve flown this way for a while with my DS610`s , servo`s were being fed from the reg as i`d by-passed the 3G , different receiver too , but alas , after 3mins on my timer , in she went again , with no cyclics at all , i used the transmitter for my planks and they don`t have problems , so i ain`t a clue , but all i do now is for a fact is that everytime i fit a 3G to this heli , it stops working , but its 2 3G`s , but i have changed the rec , reg n li-po ? anyhow its bust for now and i`ll ask father xmas for a new kit
ady is offline        Reply With Quote
Old 06-05-2010, 04:11 PM   #902
Lajon
Originally Posted by SkinWalk3r View Post
the instructions for the WR bec say to remove the positive red wire from the ESC...has anyone done this with a CC type esc ? something about them being opto-isolated and needing that wire to be connected seems to come to mind.
Well the CC Phoenix user guide is quite clear about that:
You should NEVER disconnect the red throttle wire
on the Phoenix HV or Phoenix Ice HV ESCs..
/Lars
T-Rex 450 Pro, T-Rex 500 CF, Goblin 500, Logo 500, T-Rex 600 Pro, T-Rex 700E, V-Bar, DX8
Lajon is offline        Reply With Quote
Old 06-05-2010, 05:32 PM   #903
SkinWalk3r
/Lars
Lars ; exactly ! but who do I go with . CC says dont remove WR says do remove !
SkinWalk3r is offline        Reply With Quote
Old 06-05-2010, 06:25 PM   #904
climbing-n-flying
SkinWalk3r, the CC HV85 that I run does not supply power to the rec. so you have to use a BEC. On my CC45 that I run on my 450 it can/does power the rec., but I run a BEC for that ESC (to help with heat and supply more amps) so I have to disconnect the red wire so I do not double the power to my rec. and fry it. I am not sure about the ICE version as I do not have one.The reason the WR BEC says to disconnect the red wire is so you are not sending more voltage than needed. So if you have the Phoenix HV85, leave the red wire. I hope this helps.
The day I STOP learning new trick's, is the day I DIE!!
HDX-Align 450
Align 600
climbing-n-flying is offline        Reply With Quote
Old 06-05-2010, 08:40 PM   #905
adroc3905
Good to know for future reference.
TBS Discovery
Rave 450 FBL - miniVbar
Trex 500 ESP FBL - Beastx
Trex 600 ESP FBL - Beastx
adroc3905 is offline        Reply With Quote
Old 06-06-2010, 02:13 AM   #906
rceccleston
Opto isolated esc's such as the CC 85/110 HV or CC ICE HV series require the use of the power provided on the red wire, by an external BEC or regulator, to power the logic of the speed controller.
Western Robotics are suggesting the red wire is disconnect if the esc is not opto-isolated and has an active internal switching or linear BEC installed.
T-Rex 700e 'Chrome Edition', Skookum 720, Turnigy , Scorpion motors, Align servos. DX8 with Turnigy 4000Mah Li-Po
rceccleston is online now        Reply With Quote
Old 06-06-2010, 02:59 AM   #907
chucky21022002
I experienced this the hard way because I could not calibrate my esc, have to send back to hobby shop and to Horizon Hobby. The technician told me that the red wire needs to be plugged on the receiver even though there is a BEC installed. Thank you Rceccleston for sharing your 12s setup, I finally finished building mine. Hope to maiden Thursday (10/6). Here 's a couple of pics...
ID:	161132   Click image for larger version
ID:	161133   Click image for larger version
ID:	161134   Click image for larger version
Copter X Hybrid Fubar
Trex 500 Vbar Trex 600 Vbar
Compass 7HV Mini V Compass 6HV Vbar
chucky21022002 is online now        Reply With Quote
Old 06-06-2010, 07:05 AM   #908
SkinWalk3r
ok. thanks Lars and climbing-n-flying and rceccleston and others
Old 06-06-2010, 12:24 PM   #909
lovespicyfood
I'm curious, what Turnigy batteries are those? You look to have pretty much the exact setup I am building (though I'm seriously thinking of replacing the CC BEC PRO). Are they 6s3000 40C? If so, how's the CG?
Thanks!
Pete
lovespicyfood is offline        Reply With Quote
Old 06-06-2010, 04:23 PM   #910
SkinWalk3r
will I be ok running the 4025-630 with 13t Mikado ?
Old 06-06-2010, 05:02 PM   #911
chucky21022002
Thanks!
Pete
Pete, those batteries are 40C 3000maH Flightmax batteries. The CoG is nose heavy. I made a few modifications like moving the battery tray back a little bit ( there is a hole further back where the original placement of the batt tray), moving the BEC at the back and thinking of changing those plastic tail grips with metal ones. If worse comes to worst, I might add some stick-on lead weights to correct the Cog.
Old 06-06-2010, 11:34 PM   #912
lovespicyfood
Thanks for the reply, I aprpeciate it. I loathe adding weight to correct COG issues but sometimes you have no choice... Hmmmm...perhaps I should go for lighter lipos...
Old 06-06-2010, 11:53 PM   #913
Alloybender
Chucky I'm not sure how yours is so nose heavy. I'm using the turnigy 3000mah 40c's which are 40 grams per batt heavier and mine is spot on. The only difference I can see from your pics is my bec is on the bottom tray at the back.
Cheers
Steve
Alloybender is offline        Reply With Quote
Old 06-07-2010, 05:10 AM   #914
chucky21022002
Cheers
Steve
Steve, I found the culprit. It was the Fusuno canopy. The canopy is way heavier than the align ones. I will weigh it when I have the chance. I swapped canopy and guess what? It was bang on.
Old 06-07-2010, 10:59 AM   #915
stef110
movie of the fourth flight of my new 12s setup.
stef
stef110 is offline        Reply With Quote
Old 06-07-2010, 06:34 PM   #916
GB ian
Default 4025-630 12T TEMP
I am close to my maiden on the 12s 600e, what shoud I expect to see in terms of motor temp on a 3-4 minute break in flight?
My back ground is nearly all Nitro all them wires are scarin' me!!
GB ian is offline        Reply With Quote
Old 06-08-2010, 02:03 PM   #917
adroc3905
stef
Nice! Love the close up inverted hover.
TBS Discovery
Old 06-08-2010, 02:52 PM   #918
imloo3
Default another trex 600 using trex 700 tail boom and torque tube testing
the guy said just testing ,use 90% throttle
imloo3 is offline        Reply With Quote
Old 06-08-2010, 03:03 PM   #919
SkinWalk3r
any recommendations on what type of adapter to get to connect the two 6s batts to 12s ? anything from Readyheli ?
Old 06-08-2010, 03:46 PM   #920
climbing-n-flying
I haven't seen anything from rediheli, but at helidirect.com you can get one. Or just make one your self using these examples......
Deans:
http://www.helidirect.com/great-plan...ter-p-8712.hdx
EC3:
http://www.helidirect.com/battery-ha...ire-p-8006.hdx
you can also find them at heliproz also
http://www.heliproz.com/products.asp?dept=124
HDX-Align 450
Align 600
