Go Back   HeliFreak > R/C Helicopter Support > Align T-Rex 450 Electric Helicopters
Align T-Rex 450 Electric Helicopters Align T-Rex Helicopter 450 Series Electric Helicopters
Old 11-19-2009, 09:04 PM   #1
CDFrog29
Question AR6110E Problems... Brownout anyone?
I seem to be having brown-outs on my 450 pro. Another pilot friend of mine is also having problems. Just wanted to see if anyone out there has any glitches, brown outs, losses of power, any blinking lights on RX for no reason. Anyone notice that their GP750 gyro goes from green to red before or after?
CDFrog29 is offline        Reply With Quote
Old 11-19-2009, 09:11 PM   #2
superjoe83
ive also been having problems with my 6110E that i put in my Pro when i built it, it was suffering from random cyclic twitches, the motor would reduce power randomly for about a second. the light was never flashing after any of these incidents. I swapped it out for a 6100E and all has been fine since
T-Rex 250, 205D blades, stock otherwise, Hurricane 550 CF, 4020-1100, JR770T, 550mm G5 blades, T-Rex 450PRO All Stock, T-Rex 700LE All Stock, Pantera 50 waiting for more money T-Rex 500ESP all stock T-Rex 550 3G in the mail!
superjoe83 is offline        Reply With Quote
Old 11-19-2009, 09:34 PM   #3
kheinink
horizon hobby sent me one becuase my old dx6i needed recalled but i havent used it yet
kheinink is offline        Reply With Quote
Old 11-20-2009, 05:53 AM   #4
newbflyer101
I'm using the ar6110e on my Pro. No issue whatsoever. It actually links up faster than the ar6100. I dont think the receiver itself is the problem but the location of where you mount it.
mine is mounted on the outside of the frame.
Trex 550E 3G FBL
newbflyer101 is offline        Reply With Quote
Old 11-20-2009, 07:46 AM   #5
frogs84ss
I'm running the 6110e on my sport, mounted under the gyro tray. the only thing noticed was after spooling it up with no blades, on the bench to check for vibrations the receiver would be blinking. i never had lose of power or control. sense those three times i haven't had any problems. no it's only fair to mention i don't have much flight time but i did crash it three times 2 weeks ago and the receiver was not blinking after any of them, so i assume the receiver is not to blame.( just my poor flying)
if it's green, it's for me !
450 sport , 450m ,35g esc, 410m , 420 gp750,ar6110e, dx7, align 325mm woodies, 11.1v 2200 25c green batteries
frogs84ss is offline        Reply With Quote
Old 11-20-2009, 07:47 AM   #6
superjoe83
mine is outside of the frame also
Old 11-20-2009, 08:21 AM   #7
Abraxxas
I've been flying a 6110 (not the E) in my 450 SE without problems for about 2 months now, my elevator servo does twitch once in a while and I cant seem to trace it down but never a flashing reciever. I have it mounted on the rear of the floor plate with one antenna sticking straight back and the other protruding out the side of the heli right behind the rear edge of the carbon side frame and passing over the right boom support, that way they are both outside the actual frame.
Abraxxas is offline        Reply With Quote
Old 11-20-2009, 08:29 AM   #8
frogs84ss
Originally Posted by Abraxxas View Post
I've been flying a 6110 (not the E) in my 450 SE without problems for about 2 months now, my elevator servo does twitch once in a while and I cant seem to trace it down but never a flashing receiver. I have it mounted on the rear of the floor plate with one antenna sticking straight back and the other protruding out the side of the Helli right behind the rear edge of the carbon side frame and passing over the right boom support, that way they are both outside the actual frame.
thats how mine on my sport is one straight back and one out the side. i think my blinking light was a minor glitch sense it hasn't happened sense!. flying today I'll let you guys know if i have any receiver gyro issues
Old 11-20-2009, 09:51 AM   #9
SidewaysLS4
Random 6110e cyclic servo twitching here also, sometimes it does, sometimes it doesnt. I wish they still sold the 6100e, no troubles with any of mine
SidewaysLS4 is offline        Reply With Quote
Old 11-20-2009, 01:26 PM   #10
caralmar
I'm the other pilot CDFrog refers to in his post. I have reproducible problems with my setup, but cannot say definitively yet that it is the receiver. I can reproduce it on the ground. I spool up to 100% flat throttle, just a little above mid-stick and then start giving it rudder back and forth and eventually I get it to glitch. Red light on gyro goes on momentarily and the AR6110E blinks.
I have a Dimension Engineering SportBEC on its way to rule out the BEC from the ESC. I tried a CC 10A BEC (the blue one) and my servos chatter constantly with it, even though it was brand new. CC is sending me a replacement BEC. So if it is indeed losing enough voltage to brown out, then it must be the BEC and the new BEC should rule this out. If it still glitches with the new BEC, then I have to conclude it is the receiver.
AMA #934662
600ESP 12s - Scorpion 4025-630/CCHV110,Hercules BEC/8717's, GY520/JR8900G, Radix mains
FBL 500ESP - SK720 / I2 head, 500M, DS510s, Canomod, Radix mains, +-13 +-10, BEAST!
450 Sport - Align 430SP/CC Phoenix 45A ESC, GY401/DS520, DS410M cyclic, Turnigy 2200mAh 25C
caralmar is offline        Reply With Quote
Copyright © 2004-2009 - William James - Helifreak.com
