Old 11-23-2009, 10:57 AM   #1
Carter1345
Default Rebind?
When is it necessary to rebind? What changes can you make either on the heli or the tx that don't take effect until you rebind?
Blade 400 stock
Dx6i
G4.5 sim B400
CX 450AE V2 HS65MG, Turnigy 30A ESC, Hobbymate 3800KV motor, 401B
Carter1345 is offline        Reply With Quote
Old 11-23-2009, 11:07 AM   #2
mr2mkii
When you bind the RX to the TX the RX stores all the signal outputs seen. These are used when the RX looses signal. So anytime you change equipment, which changes the base nuetral signals, it's wise to rebind. If you alter equipment, and it requires no change in subtrim or reversal, then your fine.
While not required, I also rebind after I've "trimmed" the heli for stable hovering.
Blade mCX / mCPx / 130X / B400 HS-65MGs FBL CopterX w/3400g CCBEC 440H
B400 HG-5000 w/5083, CNC Head, HS-65HBs / B400 GY401 w/3400g, JR285s / B450X
T-Rex 600E / 600N Pro / Vortex 250 Pro
mr2mkii is offline        Reply With Quote
