Old 12-03-2009, 05:10 PM   #1
nnik
Default tail slider
Hi all,
newbie here (hover, forward flight), all stock, with two tail-related questions:
1) being on throttle hold, when I move the collective/rudder to the right and then back to the center, the tail slider moves to the left (seen from the back) as it should be but then it moves back to the center very very slowly (like being driven by a weak spring). Is this normal? If not, any ideas for a solution?
2) (perhaps a stupid question) When you refer to the centering of the slider, which part of the slider should be centered on the shaft.
Thanks in advance.
nnik is offline        Reply With Quote
Old 12-03-2009, 05:42 PM   #2
75scoutII
1st question depends on what mode the gyro is in. In rate mode, the tail slider will revert to center. In heading hold mode the tail slider won't center, until the gyro detects a rotation change.
Watch finless's 101 videos for more explinations of rate mode and heading hold.
2nd. I just make it to where theres equal amounts of space on either side of the tail slider.
Jason
2x Blade 400's, T-Rex 450 SE V2, 2x HK 450's, Blade CP Pro Brushless, Blade mSR
E-Revo Brushless Edition, Stampede VXL, HPI Pro 4, Mini Late Model, Mini Slider, T-Maxx, Micro-T
75scoutII is offline        Reply With Quote
Old 12-03-2009, 06:02 PM   #3
whoanelly
+1 on question 2,,just the same amount of metal showing on each side..Sokal has some great videos up at the the top of this thread you should also check out.
we were all noobs at one time so dont ever think your questions are dumb..thats what were all here for..
700LE : 105HZR AR7200BX JR8917 Multi gov , JR9503
600ESP : 100AMP Castle. Scorpion Motor . AMA #962896
400 Blade : Scorpion 2221-6 ,Castle ICE 50 Sonix Head and t
Align 450 pro V2 3G MKS DS95 MSR , 2 x MCPX (brushless C05 & HP05), Blade 130X.
whoanelly is offline        Reply With Quote
Old 12-03-2009, 11:04 PM   #4
nnik
Thanks! Yes the gyro is in HH mode so according to your reply its behaviour seems natural. I'll go through Finless and Sokal videos as soon as I find some time. Up to now I've watched only a few of them.
