Old 12-04-2009, 02:45 PM   #1
heli-on
Default 450 Pro Landing Gear on SEV2?
Aside from having to drill holes, anybody know if it will work? Is the frame spacing the same between the models, or do the ridges need to be ground off?
Want to get the Gorilla's Pro landing gear for my SEV2.
Thanks!
heli-on is offline        Reply With Quote
Old 12-08-2009, 02:47 PM   #2
heli-on
Tight, but do-able.
Wonder if they'll make them in yellow so I dont have to paint them. Kind of a PIA.
Old 12-08-2009, 09:05 PM   #3
reALIGNed
You can die them yellow with a product called "RIT" dye, and you can zip tie the skids on to the frame.
ALIGN Trex 100, 250, 450, 500, 600, 700, 800. OXY 3 (Tareq)
reALIGNed is offline        Reply With Quote
Old 12-08-2009, 09:55 PM   #4
heli-on
Rit dye doesn't work on black plastic. But, I just found out GG actually makes these in yellow. Grrrrrr.
I prefer to have the skids bolted to the frame. If the skids pop off you're certain to have a tip over. Bottom frames are cheaper than blades.
Old 12-09-2009, 09:02 AM   #5
reALIGNed
Sorry, I didn't realize you had black skids to begin with, I assumed they were white.
