Go Back   HeliFreak > R/C Helicopters > Aerial Videography and Photography > Realtime Video and FPV
Realtime Video and FPV Discussions of receiving video in realtime from the aircraft
Old 12-05-2009, 12:43 PM   #1
xpower180
Thumbs up FPV Test Hover
Finally got a chance to check if everything works in the air!
The original raw file is way better than YT, hey ho...
xpower180 is offline        Reply With Quote
Old 12-05-2009, 01:29 PM   #2
blade77
Default Looking good :)
Looking cool.My setup arrived today.Its all the same gear but wont be setting up until christmas (Its my santa pressie)- A few recommendations to complete my kit:-
What did you use in the end up to power the camera?Flight battery or seperate 500mah?
What did you use to view?screen or goggles
What did you use to record the vid for utube?
Now get that thing down to the field and lets see a flight video
blade77 is offline        Reply With Quote
Old 12-05-2009, 01:37 PM   #3
maxout
I'm planning on doing the same xpower180. I've got to pick my days now, we had our first snow yesterday and with that, the wind has picked up.
Frank
I held it in just like you said....from what tree?
Hirobo Shuttle, srb. Trex 450se V2, GY401, S9257, hs-65mg servos, 430XL Motor, 11v 2100mah, 325 cb Futaba 7cap Tx, RealFlight G-4.5, T-rex 500, 6sKP2600,GY401,9257, HC 3D, mCX,(2) HK 450's, telebee gyro, hxt900 cyclic.
maxout is offline        Reply With Quote
Old 12-05-2009, 02:19 PM   #4
xpower180
I'm using a 460mah 3 cell pack for the video, it sits on top of the flight pack, and the canopy still fits (it's also handy for good CoG).
I have goggles and a 7" screen (for spectators and/or backup if the goggles fail)!
For the video, I hooked the video feed up to my laptop.
When I get a chance, I'll post pics of my heli setup and groundstation.
Hope this helps?
Old 12-05-2009, 08:01 PM   #5
blade77
Super Job Xp180.I am getting the gear together and pictures of your setup would be great.The video looks great,Keep the posts coming I am getting excited about FPV now
Old 12-06-2009, 04:16 AM   #6
xpower180
Here are some pics of my setup and Groundstation (it's a work in progress...)
I'm waiting on the FPVPilot Extended Landing Gear, but it's on it's way!
ID:	127631   Click image for larger version
ID:	127632   Click image for larger version
ID:	127633   Click image for larger version
Old 12-06-2009, 04:34 AM   #7
blade77
I like that ground station - will the patch antenna work mounted to the case or will it go on a tripod?
I have the same kit but the tx antenna is a 3 dBi dipole antenna (omnidireccional) that came with the kit.
Will the whip give you extra range or is it just a weight saving device?
Old 12-06-2009, 06:45 AM   #8
xpower180
I've only done a short range test since mounting the patch to the case and it seemed fine, maybe someone on here could advise as to whether I should isolate the rear of the patch against the metal case?
The Tx antenna was switched from the supplied rubber duck to reduce both length and weight. Having not tested the system on a proper flight, I don't know whether there will be a range penalty with the smaller whip... we shall see soon (hopefully).
Old 12-06-2009, 11:51 AM   #9
savage 40
are you using the internal capture card for the Laptop? or are you using an external card? If exeternal which one? Man the video is very clear!
What tree? Oh, THAT TREE!
savage 40 is offline        Reply With Quote
Old 12-06-2009, 12:06 PM   #10
xpower180
Thanks, although the original file is MUCH better than the youtube compressed version!
I'm using this capture card, along with their (free) Media Center Software, on Windows 7.
Old 12-06-2009, 12:20 PM   #11
blade77
XP_ you must have been a very good boy this year - Santa has got you all the best toys and it aint even Cristmas yet
Old 12-06-2009, 12:26 PM   #12
xpower180
LOL!
Well some of the gear is for christmas (it had to be tested, right ), and the rest was bought with some long overdue overtime money!
I'd never have got it all together at the same time otherwise...
Old 12-06-2009, 01:14 PM   #13
blade77
LOL
It always needs testing for at least 3 weeks before Christmas :O)
Old 12-06-2009, 01:33 PM   #14
halley
Pretty much any dipole will definitely out-perform the monopole whip. You can make your own, but that size bird should have no problem with the rubber ducky dipoles. Obviously you have to balance the weight up front.
I am also concerned about having the patch attached to the aluminum sheet of the case's lid. It provides a reflective surface that may interfere with the best possible signal. A test inside the house isn't good enough... go to a park with a hill and tell your friend to walk to a distant corner with the camera/transmitter in hand.
Don't get me wrong-- your case looks awesome. Just wait until parts are proven before bolting and riveting.
halley is offline        Reply With Quote
Old 12-06-2009, 01:46 PM   #15
xpower180
Hally
Thanks for the advice. I'll be sure to do a decent range check before flying off into the distance.
I've got too much cash invested in this stuff to be careless!!
