Go Back   HeliFreak > R/C Helicopters > Rotor Blades
Rotor Blades R/C Helicopter Rotor Blade Discussions
Old 12-06-2009, 03:11 PM   #1
arago
Default Radix Users..........
I installed some 325mm Radix mains on my furion yesterday and noticed that they fit just a tad loose in the main grips. My question to all you Radix users is . . . has anyone used the 0.15mm spacers that come with the blades (they fit btw) or do you just run the blades straight up and tighten the grips down for a tight fit?
arago is offline        Reply With Quote
Old 12-06-2009, 04:19 PM   #2
tonyisenhoff
I've used both the 325's and the 430's without the spacers. I don't have to over-tighten to get an appropriate fit.
Tony
Blade CX2 (sold) -- Trex 450 SE V2 -- Trex 500 ESP -- Trex 600 NSP
Phoenix Sim -- Spektrum DX7
http://www.rcheli-usa.blogspot.com
tonyisenhoff is offline        Reply With Quote
Old 12-06-2009, 05:47 PM   #3
Skint Eastwood
I used the spacers that is what they are there for!
Skint Eastwood is offline        Reply With Quote
Old 12-07-2009, 10:32 AM   #4
Stolla
no spacers here
Old 12-16-2009, 01:36 PM   #5
heli-lover
Let's all observe a moment of silence for those blade companies that don't supply washers in their packages for those that DO choose to use them.
heli-lover is offline        Reply With Quote
Old 01-02-2010, 04:38 PM   #6
Ray K.
I don't use the spacers, but then again I've got plastic grips on my TRex, so they just compress down onto the root with no problem.
On my Pantera, though, I do use the spacers. Otherwise the grips would have to be squashed down so hard that I'm sure it would cause big, big problems.
Nice blades, though- I like them a lot and use them on both my birds.
-Ray
Fired up!
Ray K. is offline        Reply With Quote
Old 01-09-2010, 05:22 PM   #7
im4711
On the 450, 500 and 600 I do not use them since they simply would not fit. I would not be able to get the blades in with spacers. On the 700 they do fit -> actually without themI would not be able to get the blades tight enough.
im4711 is offline        Reply With Quote
