Old 12-06-2009, 07:59 PM   #1
rigging65
Default Motor polarity?
Ok, so I just swapped out from the stock motor to a 2221-8. Slick little sucker that -8!!
Got the bird all put back together and wound up the motor for a test and it ran backwards...huh??...ok, double checked my connections and the colors match the way they should (red-red, black-black, yellow-blue). hmmmm...
So I swapped the red and black wires and everything is good, the motors runs up fine and in the correct direction now. YAY! My question(s) this:
--WTF??? is this normal? Are some motors poled in reverse??
--I don't think there's a 'reverse' in the DX6i for the motor...how else can I reverse the poles?
--Am I gonna cause damage to anything with the wires reversed?
Little help here, please???
_______________________________________
B400: x3 65MGs, GP750/DS620, Align 35X ESC for a 2221-8, and a sportBEC...
HK450: Build in progress, x3 65MGs and a DS520 on the frame so far...
CopterX 450: Gonna be my Flybarless build!!
CX3: Soon to be a scale-ish Huey!
rigging65 is offline        Reply With Quote
Old 12-06-2009, 08:04 PM   #2
cyclemandavid
your good to go, nothing in you dx6i to revers.your not going to damage any thing.
cyclemandavid is offline        Reply With Quote
Old 12-06-2009, 08:17 PM   #3
Larry227
It's perfectly normal. Swapping any two wires will make it run the opposite direction.
Compass 6HV - SK540 - MKS HBL665/669
Trex 500 ESP - SK540 - 510's/BLS251
DX8 / Phoenix / Persistence
~"See the heli, fly the heli"~
Larry227 is online now        Reply With Quote
Old 12-07-2009, 12:49 AM   #4
supra6
Yes for us compulsive people it would be good if the manfactures used just one color for the wiring. I am so bad I have been known to change them so it looks pretty.
supra6 is offline        Reply With Quote
Old 12-07-2009, 03:55 PM   #5
rigging65
Cool, thanks. Seems silly there's no standard....
Old 12-07-2009, 04:16 PM   #6
xspare
It ain't silly, it's just not important. The few folks who truly need to know can measure the phase sequence, and perhaps even relate it to a GPS timing reference. Go look at the top of a power transmission pole/tower and come back when you can use the color code to tell us all which wire is phase A, B, or C.
xspare is offline        Reply With Quote
Old 12-07-2009, 05:43 PM   #7
rigging65
If it's not important, then why are the red and black wires coded at all? Why not just have two black wires and a yellow wire? Someone, somewhere thought it was important enough to differentiate the two wires.
Old 12-07-2009, 06:20 PM   #8
NCBladerunner
+1
AMA 836780
NCBladerunner is offline        Reply With Quote
Old 12-07-2009, 06:50 PM   #9
whoanelly
+2 ,,no need for the attitude...
700LE : 105HZR AR7200BX JR8917 Multi gov , JR9503
600ESP : 100AMP Castle. Scorpion Motor . AMA #962896
400 Blade : Scorpion 2221-6 ,Castle ICE 50 Sonix Head and t
Align 450 pro V2 3G MKS DS95 MSR , 2 x MCPX (brushless C05 & HP05), Blade 130X.
whoanelly is offline        Reply With Quote
Old 12-07-2009, 07:05 PM   #10
fast400
i have a motor with all black wire`s, how would you know how to hook that up right.
Crashs come easy Patience does`nt
retired the 3 year old blade400
fast400 is offline        Reply With Quote
Old 12-07-2009, 07:52 PM   #11
Bit-Man
ALL electric 3 phase ac type motors have this issue. It all depends on how the coils are wound when they are being made. If they are wound one way that will produce a pole that has the N and S and if they have the oppisite then the poles will be of coarse opposite. Sometimes the effort to check this is needed ( think generators in big manufacturing plants) but most all times it is a very easy quick check to energize the motor very briefly in order to check rotation.
There may be some kind of code but it is so lax that it is never adhered to because it it so easy to determine the phase like I have mentioned above.
It really is no big deal.
2x Blade 400 - 2x Copter X 450 - 3x Trex450 SE v2 - 1x CA'ed mSR - 3x MSH Protos 500 Carbon - Raptor E550 building! :glasses2:
Bit-Man is offline        Reply With Quote
Old 12-07-2009, 08:26 PM   #12
xspare
Hopefully I can explain it, clear things up, and let you accept it with peace of mind.
The microcontroller and switching circuits in the ESC need DC power (with the correct polarity) and would smoke if hooked up backwards; this is why you've got a red & black wire. The 3-phase switching in the ESC ends up connecting each motor lead to each battery lead, in sequence, and mixed up leads will simply cause the motor to turn in the other direction - no smoke involved.
It makes some sense for Horizon (to reduce customer support costs) to have colour coded wires on an RTF B400. Unfortunately, Scorpion doesn't know if you put their motor in a B400 or an EC135 where you want the head to turn in the scale direction. Scorpion also has no idea whether the pinion/prop/fan in any particular heli or plank points up, down, forwards, or backwards either. So the idea of forwards and backwards rotation is entirely dependent on your system, as it is with the power grid.
Most things in the hobby are way more complicated, time consuming, and debatable than swapping two motor wires to reverse the direction. So let's just be happy it isn't.
Old 12-08-2009, 11:01 AM   #13
rigging65
Now THAT is a good explanation....thank you!
Old 12-08-2009, 01:54 PM   #14
Carter1345
+1
Thanks! I also saw the all black wires on some motors and didn't understand why they had been done like that...
Blade 400 stock
Dx6i
G4.5 sim B400
CX 450AE V2 HS65MG, Turnigy 30A ESC, Hobbymate 3800KV motor, 401B
Carter1345 is offline        Reply With Quote
