Old 12-09-2009, 02:11 PM   #1
kcobello
Default Wire loom/braided
Hey Guys
I have my Trex 600 close to built. Electronics, linkage adj, etc. left to do. I see some photos of your build using braided loom to hide/protect servo cables etc. I picked up 1/4 split plastic loom but it seems to large. Whats size braided will fit and will 1/8" stretch over the servo connectors?
Or what do you recommend, I have no where I know of to look at it but online.
Kevin
kcobello is offline        Reply With Quote
Old 12-09-2009, 02:18 PM   #2
outhouse
its very easy to pop the ends off with a exacto knife lifting gently on the tab.
then use teh 1/8"
trex 450pro
trex 500 1400/bl60g, 15t, 6s, gp750/9257, 9650mg's,TT
trex 600E 600xl/bl75g, 6s, 10t, 750/9256, hs5625mg's, TT
trex 600N OS50hyp, hitori, mgp, 9451'sgy520/9256, TT
trex 700N 91sz, hitori, g600, 610's, 611/9256, TT
outhouse is offline        Reply With Quote
Old 12-09-2009, 02:19 PM   #3
nexgen
if you get some of the regular braided servo wrap, you can take the connector off the servo to easily slide the wire through, then put the connector back on.
Gaui 200 •Gaui 550 •Gaui X5
BeastX Castle Scorpion Hyperion Spektrum JR
The Front Porch, Nexgens Lounge
nexgen is offline        Reply With Quote
Old 12-09-2009, 02:26 PM   #4
kcobello
Thanks for the comments.
I like the braided loom, so 1/8" will do it if I pop the connetors off?
Old 12-09-2009, 02:27 PM   #5
TowPilot
3/16" or 1/4" would be easier to use
http://www.mcmaster.com/#sleeving/=4uylj2
TowPilot is online now        Reply With Quote
Old 12-09-2009, 02:32 PM   #6
outhouse
it worked great on mine, [450] just lut a small piece of tape around the exposed ends so they dont hang up working them through.
trex 450pro
Old 12-09-2009, 03:17 PM   #7
steve28
I had a question about this too , I picked up some braided wire loom to do this also . Problem comes up that the braided stuff is stiffer than the servo wire by itself making routing the wires more difficult . I wanted to shorten the servo wires . Getting the wire ends out of the black connectors is done with a knife but if I cut the wires shorter I lose the crimp end that they use . Can I get these crimp end bits someplace ?
steve28 is offline        Reply With Quote
Old 12-09-2009, 04:07 PM   #8
crflyer
Try here
http://stores.servosandstuff.com/-st...Categories.bok
crflyer is offline        Reply With Quote
Old 12-09-2009, 05:20 PM   #9
TowPilot
Sharp turns can be made but should be avoided when routing.
Yes, this limits the routing routes so to speak
For each heli, usually there is a sticky just for heli photos of that type in each heli specific thread.
View the photos to get ideas how others have routed their wiring.
I too, cut wires to length and put on new pins rather than bundle the longer wires.
I grouped some wires on my initial braid work. I do not recommend doing this. In the unlikely event you need to swap a component, you end up re-working these areas.
It does look extra clean in having one "run" of braid though. So make this choice knowing that is the downside to doing so.
Making your own servo terminations means doing cool things like making an extension the exact length to position a "bind" plug just where you want it.
Here you can see a female plug fixed to the bottom of the tail rotor servo using 3M foam tape.
Slightly lifting the tab with a hobby knife....
The side of the pin that is inserted facing the locking tab of the servo plug...
Oops... Sorry Slyster, didn't intend to bore you with the details
Last edited by TowPilot; 12-09-2009 at 05:25 PM.. Reason: gads... I thought I heard snoring...
Old 12-09-2009, 06:05 PM   #10
brian94066
cute dog
brian94066 is offline        Reply With Quote
Old 12-09-2009, 06:45 PM   #11
TowPilot
Originally Posted by brian94066 View Post
cute dog
Yes, that is so true, and I'm guess that Slyster's wife is happy that he is house broken...
Old 12-09-2009, 06:55 PM   #12
Slyster
Very true.. although that's not my dog this is! Jack and daughter
"It's not just a hobby... it's a lifestyle" - Pete ϟ
Slyster is online now        Reply With Quote
Old 12-09-2009, 07:07 PM   #13
TowPilot
"he" = "Slyster"
BTW, Jack is a well trained and wonderful dog!
