Old 12-13-2009, 12:12 PM   #1
CoolKD
Default Eflite Alu tail bearings
I just started getting a brutal high pitched vibration in the tail at full throttle after a rebuild.
The vibe comes and goes. 98% of the time it's there, depends if I speed up quick or slow.
The tail is always fine up to around 70% stick, but if the vibe sets in it stays even when I poll the stick down to 50-40%.
I'm almost sure its the tail case bearing that is not good.
Tail blades are Eflite carbons and are in balance, and the shaft/belt is also ok.
The thing is I cant seem to find what sort of bearings thats on the original Eflite Aluminium tail case upgrade. They look bigger then on the stock plastic case.
Any ideas?
Part number for the Alu tailcase EFLH1463A
Blade MSR, MCPX v2 & 400 3D NightRig
Align Trex450 pro. KDE FBL Head & BatTray,MKS DS95,FutabaBLS257,BeastX, ICE50, CC BEC, Scorpion6
Align Trex700LE N. LYNX Clush/Liner, Quark,Hatori SB20FH-2,O.S91HZ
CoolKD is offline        Reply With Quote
Old 12-13-2009, 01:48 PM   #2
Cailid
These are the bearings you need http://www.helidirect.com/advanced_s...1412&x=12&y=10
MCX, CX2, MSR
Blade 400, 500ESP, 500CF
Cailid is online now        Reply With Quote
Old 12-13-2009, 09:52 PM   #3
Ronbo
or try these abec 3 bearings. should be better?
http://www.helidirect.com/abec3-flan...3zz-p-1202.hdx
vbr,
Ron
Raptor R90, YS90, TT 680s, Radix, GY601
Blade 400-CC BEC stock ESC, HS65HB, 9257 with Spartan 760
Ronbo is offline        Reply With Quote
Old 12-13-2009, 09:57 PM   #4
ingrahal
If it turns out not to be the bearings take a close look at the grips and hub. I've had the same vibe and found it to be the hub once and bent grip screws, watch the blades when the vibe starts and see if the blades are out of track. Check by removing the blades and turning one of the grip screws while holding the hub and see if the other grip wobbles. Like checking for a bent feathering shaft on the main rotor.
B400, DS285MG x3, DS3400G/GY401, CC ICE Lite 50, HK2221-8, Align 335mm Woodies, CNC Tail hub/grips, DX6i Tx
Blade mCX,Blade mSR
Flying Helis since April 09 Have mastered FFF ckts and nose in landings. Starting on mild aerobatics.
ingrahal is offline        Reply With Quote
Old 12-13-2009, 10:21 PM   #5
1BADAIR
my bearings in that case lasted like 10 flights. switch to boca's but only used it like 2 flights after that. the bocas cost as much as the case did
TREX700LE-beastx,TREX 600LE-vbar,COMPASS 6HV-beastx,
1BADAIR is offline        Reply With Quote
Old 12-14-2009, 12:15 AM   #6
supra6
Another thing to check is the tail drive gear in the frame, tough to see with out removing it. The top plastic gear on this shaft will wear out and either split or seperate either way as it is going bad it will give the indications you speak of.
supra6 is offline        Reply With Quote
Old 12-14-2009, 12:53 PM   #7
CoolKD
Thanks for all the replies
If the original bearings is that bad I would realy start thinking of getting a Trex tail for it, but the thing is I just completed the upgrade of the tail to full Eflite alu. So it would be a realy waste of money to switch the hole thing out now.
The tailcase here costs 44,45$ here, and ewery thing else is much higher priced the in the states.
Do ReadyHeli.com have better bearings for this Eflite Tail? Would be nice since I have an acaount there, to bad I have to pay about 33$ just for the shipping to get it all the way to Norway.
As for the alu grips, I see one is out of track now. The center hub is just replaced and got no flights on it so it should be fine. I will take a closer look at the front tail drive shaft for wear and tear.
Old 12-14-2009, 01:31 PM   #8
Cailid
You can also get them from here. http://www.rc-bearings.com/catalog/index.php
They have a complete set of abec 3 bearings for a stock B400 as well.
MCX, CX2, MSR
Old 12-14-2009, 06:37 PM   #9
Norseman1
Default Cheap Blade 400 parts
Hi CoolKD
Sent you a PM on the cheapest Blade 400 parts I have found. Matching US prices in Canadian dollars on most parts and some even cheaper........
Regards
Paul
Norseman1 is offline        Reply With Quote
Old 12-14-2009, 07:37 PM   #10
fast400
you will end up swapping out the e-flite crap sooner or later, everyone i know that has used the e-flite complete tail includeing me has had it fail really quick.
the guide pin`s fall out of the pitch lever
the bearing fall`s out of the pitch slider
the bearings in the tail grip`s go bad very fast, and will not come out to be replaced.
the case doesnt stay tight on the boom, you`ll end up drilling a hole in it for a set screw to keep it in place.
all applies to the complete head setup as well, e-flite and copterX has the most cnc junk on the market.
it look`s nice, but doesnt last long at all.
Crashs come easy Patience does`nt
retired the 3 year old blade400
fast400 is offline        Reply With Quote
Old 12-14-2009, 08:34 PM   #11
Cailid
I've been using mine for a while now and I like it.
Never had the pins fall out of the pitch lever. The pitch slider wore out real fast so I put the plastic one back in though.
Haven't had any troubles with the tail staying in place on the boom. I use the metal boom and just put a bit of blue loctite on the tail. That seems to hold it in place fine.
MCX, CX2, MSR
Old 12-14-2009, 08:41 PM   #12
fast400
well you loctited the case to the boom, so you solved that issue.
you`re on borrowed time with the pitch lever, keep an eye on the guide pin`s for real.
you confirmed the pitch slider.
mine and many other`s useing e-flite cnc has had them go out within month`s.
my pitch slider, pitch lever, and tail grip`s have given out in 2 months top`s.
Old 12-14-2009, 08:49 PM   #13
Wiggles85
so is it better to just stick with the stock plastic parts?
Wiggles85 is offline        Reply With Quote
Old 12-14-2009, 08:54 PM   #14
fast400
honestly?
i would if you want e-flite part`s, but their are a few good after market cnc stuff out there, like the sonix`s.
i read many post`s on the e-flite cnc stuff being crap, but i had to try it anyway, it was junk.
the sonix`s cnc stuff is real nice, i have had it to. i sold it, the e-flite cnc went in the trash.
you will never know though unless you try it out for yourself.
Old 12-14-2009, 09:04 PM   #15
1BADAIR
after having every eflite alum part and wearing them out, I only recommend the alum flybar cage ends
Old 12-14-2009, 10:46 PM   #16
Tommygunn
I use a little of both...
I've got the tock plastic tail housing and use the CNC hub and rotor grips. you have to change the balls over to the smaller Eflite size, but it works great. I too had problems with the Eflite Alum crap. The only bearing I've had go out is in the motor.
550 Trex FBL, Beastx, Kontronix 100 Jive
500 Trex FBL, Beastx
450 Trex Sport
All flown with my DX7
Tommygunn is offline        Reply With Quote
Old 12-14-2009, 10:53 PM   #17
Ronbo
what about just using the the alu head block?
vbr,
Ron
Old 12-14-2009, 11:20 PM   #18
ingrahal
+1 I get less tail vibes with the aluminum tail grips and steel hub vs the plastic grips and aluminum hub. Tweaked one hub due to a crash and Fast400 is right about the bearings in the grips. I think you could make a tool to get them out but I replaced the whole assy. I also stayed with the plastic tail case, it has held up well.
Blade mCX,Blade mSR
Old 12-15-2009, 01:09 PM   #19
FMJB
I went through two Eflite plastic tail case's due to bearing failure.
First bearing failure was with stock Eflite bearings.
Second bearing failure was with ABC bearings.
So I went with the Sonix tail set up and so far very happy.
B400, S9257 tail servo, Gy401, HS65MG servos, Phoenix 35 ESC
FMJB is offline        Reply With Quote
Old 12-17-2009, 10:28 AM   #20
CoolKD
About getting the grip bearings out, add some heat to the ALU around the bearing you want to remove. Be sure not to get the heat in so deep that the bearing also gets warm, then the metal will expand too and you wont get it out. Just a tip
I'm getting the new bearings today(new set of Eflite's), so let you all know how it goes.
If the bearings and other stuff starts FU#%!! with me, I'm going for a full Trex tail.
Too bad about wasted money
