Go Back   HeliFreak > R/C Helicopter Support > Heli-Max Helicopters
Heli-Max Helicopters Heli-Max Helicopter Support
Old 12-17-2009, 03:49 PM   #1
aaron1230
Default Novus CP tail motor ?
The tail motor powers up before the main Blades causing the bird to drift left on take off and once 2 - 3 foot off the floor, makes it hard to orientate before running out of flight area.
The manual doesn't give much info any input of how to adjust would be great.
aaron1230 is offline        Reply With Quote
Old 12-21-2009, 04:47 PM   #2
phoenixheli
Read page 24 of your manual. It shows exactly what do do to compensate for this. It seems that your revo mixing or gain is not optimal. Get a small phillips screwdriver and follow the instructions.
CPv3, Axe 400, Exi 450, Franken Heli 450, mCPx, Swift 16, Blade 450x Thumbs Only!
phoenixheli is offline        Reply With Quote
Old 12-23-2009, 07:39 PM   #3
Mr.HillBilly
Yep that will fix you up.
Mr.HillBilly is offline        Reply With Quote
Old 12-25-2009, 12:23 PM   #4
Cman
Also check that the tail rotor is on tight, if it is not the gears will not always engage and it ends in blade replacemet. I have also found that the tail rotor shaft bends extremly easy. Has oneone found a better shaft? and a better way yo keep the tail rotor attached?
I used some plastic tupe from Glow aircraft throttle cable sheaths on my blade and Axe, but its all too big for this little thing.
Cman is offline        Reply With Quote
