Old 09-11-2006, 04:24 PM   #1
Dutchdude
Default how to "activate" idle up in a 7chp??
I am going over finless video's setting up my radio (Futaba 7chp) and I want to set up my idle up curves. I know were and how (thanks to the video's..) but in the manual it does not say how and were to activate the switch. I mean I think it is still "inhibited" (idle up 1 and 2, right now the pitch is the same as normal mode). Can not find were to activate it. Can someone point me in the right direction??
Thanks,
Daan
Dutchdude is offline        Reply With Quote
Old 09-11-2006, 05:18 PM   #2
z11355
Did you look in the TH-CRV menu item? It should say 'INH' for both when inhibited.
z11355 is offline        Reply With Quote
Old 09-11-2006, 06:10 PM   #3
Dutchdude
thanks for the quick answer, but when I go into TH-CRV menu I do NOT get like the manual says.. like this:
TH-CRV
IDL1-INH
IDL2-INH
I get
TH-CRV(N)
P5-100%
P4-75%
etc..
am I missing something?
Trex 700 (ok)
Trex 450se V2(ok)
Trex 250 (ok)
Protos (ok)
Old 09-11-2006, 06:34 PM   #4
z11355
I'm not overly familiar w/ the 7C but on MANY transmitters, you have to be in the
mode in question (ie. flip the mode switch to ID1 or ID2) to adjust the points.
Old 09-12-2006, 02:01 AM   #5
zflarez
Go into the advanced menu th-crv and then continue to press the down button past p1.
Wants that is enabled in order to set the pitch and throttle curves press mode in the advanced thr-crv menu and a "n" will change to a "1" in the top right hand corner proceed to set with the "1" displaying. If idle up two is also enabled hit mode again and the "1" will change to a "2"
Now set the pitch the same way except there is no need to enable anything since it has already been done. Throttle hold curves can also be set by hitting mode a few times.
Raptor 60
Evo 50
Trex 600
Raptor 30
zflarez is offline        Reply With Quote
Old 09-12-2006, 02:53 AM   #6
Dutchdude
Thanks zflarez! it worked...
Trex 700 (ok)
Trex 450se V2(ok)
Trex 250 (ok)
Protos (ok)
