Old 12-24-2009, 09:54 AM   #1
flerpie
Default Is 7.4V 800maH Lipo okay in a T250?
I don't have a T250 so I've never read the docs.
Here's what me and a friend saw:
His stock align ESC stopped making any kind of startup sounds, good or bad.
Yet his heli works great on 11.1v lipos.
Then he put one of my 7.4V lipos in it - fully charged...and the motor doesn't
spin up. Go back to 11.1v lipo and the heli runs fine.
So I need to make absolutely sure that a T250 is rated for 7.4v.
If that's the case then there may be something wrong with his ESC
considering that it doesn't make it's normal startup beeps either.
HK Best Of Custom 450s & 500
Build Different!
flerpie is offline        Reply With Quote
Old 12-24-2009, 09:58 AM   #2
heli-on
No
heli-on is offline        Reply With Quote
Old 12-24-2009, 05:16 PM   #3
minimalitia1
you need a 3s lipo.
TREX450V2-scorp -8,GY520,HS5056MG,S9257.TREX600NSP-OS50Hyper,S9452's,DS650,G5's.TREX600Sport-OS55HZ, A6020, DS620.TREX700NSP-YS91SR, DS610, DS650, 3G.RAPPY30-OS37,DS821's,GY401
minimalitia1 is offline        Reply With Quote
Old 12-25-2009, 06:49 AM   #4
dizzymarkus
+10 on the 3s batts
sometimes the beeps are softer -- thats normal (on 3s) it depends on where the bell lands in comparsion to the windings on the motor
Markus
dizzymarkus is offline        Reply With Quote
Old 12-25-2009, 10:46 PM   #5
stik.
3s with a 25 c 860mah
stik. is offline        Reply With Quote
Old 12-26-2009, 02:02 AM   #6
peterdk
when you plug in the battery (3s) and dont hear the beeps immediatly, try turning the main blades a bit and you will probably hear the beeps as the motor moves to the right spot.
Peter
ALIGN 550 E (fb, Quark, ccbec pro), 450 pro,
COMPASS ATOM 5.5 fbl Beastx. SPEKTRUM DX8
Eflite Mcp x (micro outside), Nine Eagles Solopro 2 (micro inside)
peterdk is offline        Reply With Quote
