Im not the best piolot and have gone through several front gears for the torque tube. I understand when even if its a small bump somthing has to give but ti would make sense to harden the front gears since they can be a pain to take off and leave the rear soft. Does any one make a after market gear set that is harder? Btw whats the hardest servo I can use for the tail so I dont stip them gears to?
you can't do anything about the TT gears stripping, it's a known fact that they can't handle the least amount of stress.
i also stripped my share of gears the first month and since then i became more aware where i spool up and land etc. and since then i did'nt stripped a gear untill now... anyway i'm going back to belt, i ordered the boom mount from i2 (bobOD on this forum) that will make replacing the gears from the belt or TT alot easyer + if you go back to belt anyway the problem is as good as solved...
SAB Gobblin 630 12s Vbar mCP-X + 130X + mCP-X brushless DSX9 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. follow us on facebook ! |
Why dont you just lengthen your tail fin, or screw a servo horn wheel on the bottom of it to keep your tail blades clear of the dirt
Outrage G5 Skookum Flybarless T-Rex 500esp V-Bar flybarless Outrage 550 - T-Rex 600 Nitro Pro To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
Where can I get a loger tail fin at? and the model #
If I got a longer tail then id need to get that little platic part that keeps the tail fin straight with out getting the whole thing. |
Here you go
http://www.helidirect.com/fusuno-neo...ew-p-13723.hdx http://www.helidirect.com/carbon-fib...00-p-13526.hdx
#6 |
Now can I find some way to find part # 500t057 since I that part will kep the tail straight and im alreay having problems with that piece? This is the small plastic 1 inch piece that has a single whole to line up the tail rotor perfect.
#7 |
This off topic but frog i love ur avatar Poison dart frogs ore my favorite!! I almost bought a couple but it was 50+ bucks per frog.
Trex 500 Esp, CC Ice 75, Hyperion 1600kv, Gp750, Ds510's , Ar6200, DS650 tail mod. DX7 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. Hyperion 250w 6s Charger, Hyperion G3 Battaries ParkZone T-28 w/ custom flaps+retracts, Ar7000 6s RCLander F-16 - To scared to maiden |
#8 |
the other thing you might want to do is a long tail fin along with some 600 landing skids this should pick you up quit a bit
#9 | |
I've kept them on and off for 20 years, I love the way they are so bold and not skittish like other frogs. They know they are toxic ![]()
#10 |
The T500 gorilla gear holds the tail up a little too, the rear is slightly taller than the front.
#11 |
Its better to strip the front gear which is a fairly easy fix and cheap, than to get a harder gear and send the problem to another part of the heli which will prob be more costly and a lot harder to change the damaged parts!!!
#12 |
What about a torque limiter that "gives" to prevent gear stripping or torque tube breaking? Does such a device exist?
#13 |
I %100 totally disagree with you. The rear gears would be so much easier to replace then the front. As an example the motor uses a metal pinion gear which will never chip a tooth but the nylon gear is cheap and they made it like that so only one gear would break not 2. Now why didnt align make a harder front gear then rear is beyond me becuase its a much bigger pain in the a$$ to take the whole boom dopwn then just a few screws in the rear end of the Torque tube. Just think about it, every time you crashed the rear you would always know it was the rear gears to go out. Then you could stock up on the rear gears knowing that they will go out every time and they are easy to replace. but then again what do I know
#14 |
I agree. I wish a manufacture company come up with an upgrade for those gears pronto. They are a pain in the neck to replace. The rear gears are much easier to replace. Let's not forget that the main gears are also made of plastic wish could be a breaking force point and they are very easy to replace as well.
#15 |
I have never had a problem with the gears the way they are stock
trex 450pro trex 500 1400/bl60g, 15t, 6s, gp750/9257, 9650mg's,TT trex 600E 600xl/bl75g, 6s, 10t, 750/9256, hs5625mg's, TT trex 600N OS50hyp, hitori, mgp, 9451'sgy520/9256, TT trex 700N 91sz, hitori, g600, 610's, 611/9256, TT |
#16 |
I have not seen anything like this for a Trex-500. However, my very old GMP Cobra has a 1.5mm steel shaft to the tail. It took a lot beat from me during the very first time of flying this helicopter in mid 80. I think the aluminum shaft of the TT can be replaced with a thinner (1.5 or 2mm) CF rod. Since CF rod is very flexible (twistable) in this small diameter, so let the CF rod taking the hard hit from our flying. This may save the TT gear. Well, I'll try this method next time.
