Old 12-30-2009, 09:49 PM   #1
Wurger
Default Thingy not lifting off the ground.
I have a thingy that contains doodads. The thingy's dealies will not get light on the ground when I go to full collective. What should I do / check ?
Wurger is offline        Reply With Quote
Old 12-30-2009, 09:51 PM   #2
Dicey
How many doodads does your heli have? Is the vroomy bit properly meshed with your whirly bit?
Working on RC Freak podcast: Now available on iTunes.
AMA CD
KBDD Team Pilot
Dicey is offline        Reply With Quote
Old 12-30-2009, 09:52 PM   #3
sethf8403
i would adjust your dingle hoppers...they should be parallel to each other all the way up your doohicky...
T Rex 250se--CC 25, scorpion 3900, hs65mg's, outrage 200 paddles, titanium turnbuckles, kevlar belt, quark/s9257, kbdd tail blades, Chinese weight mod, double thick canopy
MSR--cusker blade grips/loads of CA glue
sethf8403 is offline        Reply With Quote
Old 12-30-2009, 09:53 PM   #4
Dicey
but what if he has programmable dingle hoppers?
AMA CD
KBDD Team Pilot
Old 12-30-2009, 09:54 PM   #5
sethf8403
programmable dingle hoppers are a joke, spares cost so much! what kinda controlly thing do you have?
Old 12-30-2009, 09:54 PM   #6
DominicD
The Capi - HF Support
Make sure you use the manly hole in the programmable dingle hoopers for maximum doodad performance.
SAB Heli Canada / RotorQuest/Compass
Team KBDD
DominicD is online now        Reply With Quote
Old 12-30-2009, 09:54 PM   #7
Wurger
Okay the whatchamacallit seems to be setup okay as my widget turns the correct direction. My dinglehoppers only have one hole so nothing to worry about there.
Old 12-30-2009, 09:55 PM   #8
Dicey
so what about the vroomy bit? have you checked if the airy bit is clear?
AMA CD
KBDD Team Pilot
Old 12-30-2009, 09:59 PM   #9
Wurger
Im checking the vroomymajig and it seems okay.
Old 12-30-2009, 10:14 PM   #10
nexgen
maybe the whirly part doesn't have enough tippyness in it, so it isn't windy enough to the ground.
GAUI Field RepbeastXTeam Empire Hobby
Gaui 200 •Gaui 550 •Gaui X5
BeastX Castle Scorpion Hyperion Spektrum JR
nexgen is offline        Reply With Quote
Old 12-30-2009, 10:15 PM   #11
DVS
Did you check your thingamajig ?
DVS is offline        Reply With Quote
Old 12-30-2009, 10:29 PM   #12
Kustom
check the long thing with the threads on both ends or it oculd be the fluxcapastar. maybe you bernt the verbrator,
Kustom
2 trex 450's Donated for a good cause
Kustom is offline        Reply With Quote
Old 12-30-2009, 10:30 PM   #13
sethf8403
i bent my verberator once, doesn't seem like it should cost so much!
Old 12-30-2009, 10:43 PM   #14
outhouse
I think your thingy bearings are a we bit notchy and the doodads are out of track.
plus that there radio thingamajiggy isnt corunjulated to the wire jobbber in back end of the whammer's whirly department
trex 450pro
trex 500 1400/bl60g, 15t, 6s, gp750/9257, 9650mg's,TT
trex 600E 600xl/bl75g, 6s, 10t, 750/9256, hs5625mg's, TT
trex 600N OS50hyp, hitori, mgp, 9451'sgy520/9256, TT
trex 700N 91sz, hitori, g600, 610's, 611/9256, TT
outhouse is offline        Reply With Quote
Old 12-30-2009, 10:50 PM   #15
s0laris
Noobsters!
Your ClamaFugs are interfering with the Doohickies. Simply Drill a hole in the watchamacallic and lengthen the doodads by 12mm.
Its a common mistake
Outrage 550, Goblin 630, 700, warp 360, Dual BL Mcpx, 130x
**When you start to be in complete control reflexes are not a requirement.**
s0laris is online now        Reply With Quote
Old 12-30-2009, 10:50 PM   #16
Wurger
Someone suggested using a flizzlewazzle lock to keep it from moving this way my diddlies can be setup to the correct pitch? But I also heard that the dinglehoppers have to be aligned correctly to begin with?
The barfletuber is dripping the correct amount when the vroomy is at full power.
Old 12-30-2009, 10:58 PM   #17
Jason O'Connell
Formerly BarnStormer
Just check that it has at least 2 spinner arounder thingies.
"You can still call me Barn
Team Compass USA
ProStarHobby.com
Scorpion Power Systems
Jason O'Connell is offline        Reply With Quote
Old 12-30-2009, 11:04 PM   #18
Wurger
I just drilled into my DS760 whatchamacallit and now my widget spins in circles!
Old 12-30-2009, 11:05 PM   #19
Teej
Sounds like the ****ing ****er is ****ing ****ed up.
Teej is online now        Reply With Quote
Old 12-30-2009, 11:05 PM   #20
s0laris
Oops my bad. I meant drilling part of the mooglerboogler to give some clearance
