Closed Thread
Old 12-31-2009, 04:30 AM   #1
Edvard R
Default Align 3G - Hot off the press...
Received a nice present for Christmas this year - Santa showed up with the 1st Align FBL unit off the production line
Set up is ridiculously easy:
Contrary to other FBL systems, the Align system needs the radio in 120' swash mode.
Press the SET button while powering on - this brings you into the 1st setup phase. Here you set everything to zero. Adjust collective pitch to +/- 14' by adjusting the swash %. For cyclic, simply adjust the aileron cyclic pitch to +/-14', again by adjusting the swash %. Use the same swash % for elevator.
This completes phase 1.
Press the SET button to go to Phase 2 - setting the Elevator Limit. Simply move the elevator stick to full positive and negative travel.
Press the SET button to go to Phase 3 - setting the Elevator Direction. Check that the swash moves in the right direction. If not, reverse the direction by moving the stick to alternate the light from green to red (or vice versa)
Do the same for Aileron.
Swash done. Power off.
Power on (not holding the SET button). After power on, check that the swash moves in the right direction by tilting the heli. Swash moves in the opposite direction for both elevator and aileron.
Press the SET button for 3 seconds. This enters the tail setup. Simply set up the tail as you would the Align 760 tail gyro.
All done.
In the radio - set your roll rates by increasing or decreasing the swash %. Tail gyro gain is set like any other tail gyro.
Go fly.
The kit comes with a FBL head, sensor, control box, special servo wheels and a nifty "flybar" holder to check the pitch. At least you have a use for the flybars in your spare parts drawer...
Guys - this thing is the best thing since sliced bread. It flies awesomely. My only problem now is what to do with my SK360s and V-bars...
Here are some photos:
Name:	FL 760 1.jpg
ID:	131483   Click image for larger version
Name:	FL 760 2.jpg
ID:	131484   Click image for larger version
Name:	FL 760 3.jpg
ID:	131485   Click image for larger version
Name:	FL 760 4.jpg
ID:	131486   Click image for larger version
Name:	FL 760 5.jpg
Name:	FL 760 6.jpg
ID:	131488   Click image for larger version
Name:	FL 760 7.jpg
ID:	131489   Click image for larger version
Name:	FL 760 8.jpg
Edvard R is offline
Old 12-31-2009, 04:59 AM   #2
aussiemick
Awesome news.
I like the setup tool, or "fake flybar", get some use out of those spare flybars I am sure everyone has laying around.
Mick
aussiemick is offline
Old 12-31-2009, 05:48 AM   #3
Andyzboy
Looks sweet! Tthose two pots on the main unit are for the gain on the aileron and elevator controls, right?
Andyzboy is offline
Old 12-31-2009, 06:34 AM   #4
terrabit
Edvard, could you please measure the distance between the centers of the link balls on the blade grips at zero pitch for me?
Thanks!
terrabit is offline
Old 12-31-2009, 06:35 AM   #5
flybar-les
this looks very interesting !
i just bought myself a V-bar for my T500 but if i compare this align FBL unit the V-bar is very difficult to setup...
do you know a retail price yet ?
SAB Goblin 630 12s Vbar
mCP-X + 130X + mCP-X brushless
DSX9
www.rs-modelstore.be follow us on facebook !
flybar-les is offline
Old 12-31-2009, 06:39 AM   #6
Edvard R
Originally Posted by terrabit View Post
Hey, could you please measure the distance between the centers of the link balls on the blade grips at zero pitch for me?
Around 65.5 mm
Yes - flew it on stock 12 o'clock setting first and only adjusted the elevator pot by a tiny bit
Edvard R is offline
Old 12-31-2009, 06:42 AM   #7
Edvard R
As I know, the system only comes as a complete kit with FBL head. First available will be the 700 and 600 heads... Not sure what the price will be in the US, but the full kit will be very affordable... Did I mention the setup is easy? I am still tweaking my V-bar, but I am guessing it will just get replaced by this...
Edvard R is offline
Old 12-31-2009, 06:46 AM   #8
terrabit
Thank you! What's your impression so far? Have you flown the same or any heli with vbar? Any comparitive observations?
Edit: Nevermind on the vbar thing. I just read your post. Comparisons?
terrabit is offline
Old 12-31-2009, 07:01 AM   #9
Edvard R
Flying it is simple - as it should be. It feels significantly more connected than a V-bar and a SK360. It feels as a fly bar, only much more responsive and with more control and power...
I have V-bars and SK360s for sale if anyone are interested...
Edvard R is offline
Old 12-31-2009, 08:22 AM   #10
flybar-les
lol
do you have any idea when align is planning to make/bring out the versions for the 500 and 450 ?
i'm interested in this system for my 450 PRO, if this FBL system from align is simpeler and cheaper then my V-bar then i'm willing to swith to the align FBL to on my 500 to !
DSX9
Old 12-31-2009, 08:23 AM   #11
bahamadude
That quick !
Are you sure you want to sell those units right away ?
Hey how about get some more flights in for a more fair report.
I do agree that technology does improves over time, especially when we have existing units out there already.
bahamadude is offline
Old 12-31-2009, 08:24 AM   #12
tibtib
Does it have a cyclic heading-hold behavior ?
or is it the same behavior as a mechanical flybar ?
I mean, does it for example compensate a gust of wind which would modify the helicopter tilt with a traditional flybar ?
tibtib is offline
Old 12-31-2009, 08:58 AM   #13
Edvard R
lol
Judging by how Align has introduced products before, I am guessing the other versions will be following shortly
Originally Posted by bahamadude View Post
That quick !
For sure! - you're buying?
I haven't had a chance to fly it in really strong winds, and a 700 tends to be pretty stable as it is... It does track really well, but it moves around when you want it to. Have a look at the vids of Alan flying it - seems agile enough...
Edvard R is offline
Old 12-31-2009, 10:23 AM   #14
syn90
Has anyone ordered anything from RCheligears before. I checked them out and they are accepting preorders but it looks like they are not in the US. I really want to preorder these bad boys because it says they'll be in stock on Jan 8th and I should get them in a couple weeks after that I hope, so come February I could have both my trex600 and 700 converted and ready to go. But I am a little tenative as they will only allow me to pay via paypal and dealing with businesses outside the US can become a real drag. They have decent feedback on ebay. Are there any other sources to preorder from, or should I just wait until they are in stock here in the states?
syn90 is offline
Old 12-31-2009, 10:27 AM   #15
Edvard R
At most, you will get it a few days early - I would get it locally unless the price difference is significant...
Edvard R is offline
Old 12-31-2009, 10:30 AM   #16
MTBsuspEng
how much do you want for your vbar(s)???
TDR: on the waiting list for September 2011
Trex 500 ESP: RJX head, Mini V 5.1
450 Pro: RJX head, Mini V 5.1, 6s power
Blade MSR
MTBsuspEng is offline
Old 12-31-2009, 10:41 AM   #17
dwesnor
Does this thing have satellite Rx inputs or do you need a full receiver?
T-Rex 500 :: 450 Pro :: T-Rex 250 (a duex) :: Rave 450, 4S, 350mm & SK720
dwesnor is offline
Old 12-31-2009, 10:44 AM   #18
syn90
Ok, thanks for the advice Edvard R. I'll hang in there a little longer until I find someone here in the states that are stocking them. Man I can't wait!!
syn90 is offline
Old 12-31-2009, 10:54 AM   #19
rceccleston
It does not have an integrated receiver for wider compatibility, so connects via short leads to a full receiver.
T-Rex 700e 'Chrome Edition', Skookum 720, Turnigy , Scorpion motors, Align servos. DX8 with Turnigy 4000Mah Li-Po
rceccleston is offline
Old 12-31-2009, 11:19 AM   #20
mapleleafs
wow looks sweet can't wait to get one!
Vbar Trex 700, Vbar Protos 500, Vbar Logo400 Trex 450 Pro
mapleleafs is offline
Closed Thread
