Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters > 700 Electric Conversions
700 Electric Conversions Align T-REX 700 Electric Conversions
Old 01-09-2010, 08:23 PM   #1
Cameron_S
Default Scorpion HK-5020-450KV
Looks like Scorpion has a new motor for 2010 designed for 90 size electric helicopters. This looks like it will be a powerhouse. I believe this debuted at the AMA expo.
This is a big motor going by the listed dimensions. Weighs ~15 oz and has a diameter close the size of a coke can!
Specifications
Stator Diameter 50 mm (1.56 in)
Stator Thickness 20 mm (0.787 in)
No. of Stator Arms 12
Magnet Poles 10
Motor Wind 16 Turn Delta
Motor Wire 16-Strand 0.33 mm
Motor Kv 450KV RPM / Volt
No-Load Current (Io/10V) 1.21 Amps
Motor Resistance (Rm) 0.019 Ohms
Max Continuous Current 85 Amps
Max Continuous Power 3770 Watts
Weight 445 Grams (15.05 oz)
Outside Diameter 59.8 mm (2.35 in)
Shaft Diameter 5.98 mm (0.24 in)
Body Length 51.0 mm (2.0 in)
Overall Shaft Length 84.6 mm (3.35 in)
Max Lipo Cell 12s
Peak Current 120A (5 seconds)
Peal Power 5320 Watts (5 seconds)
http://www.scorpionsystem.com/catalo...0/hk_5020_450/
Cameron_S is offline        Reply With Quote
Old 01-09-2010, 08:53 PM   #2
MarkFlysHelis
59.8mm wide. That'll be a tight squeeze on the 700's. frames 60mm apart.
700E DFC V3 Quantum 4530, 8917HV,CC120HV,BeastX
TREX700LE- 105HZR,Hatori,8917HV,switch-glo/BeastX
Synergy E5- Pyro 650 on 10s, 8917HV, CC120, BeastX
MarkFlysHelis is offline        Reply With Quote
Old 01-09-2010, 09:12 PM   #3
Dogdocphil
OMG that looks totally sick! I suppose it would fit between the side frames. I am sure they made it with the TRex 700 in mind. With all the activity of people making their own 700E's with conversion kits, it only has to be a matter of time before Align comes out with their own kit!
Dogdocphil is online now        Reply With Quote
Old 01-09-2010, 11:28 PM   #4
Al Austria
DAYUUMMM! Sick is right!
~Allan Austria
Al Austria is offline        Reply With Quote
Old 01-10-2010, 12:33 AM   #5
helicraze
I wonder if this is the one Mr Mel tested? I think he said it did not really produce good results other than suck power.
Most likely the weak link in setups are the lipos and not the motors.
helicraze is offline        Reply With Quote
Old 01-10-2010, 04:58 AM   #6
QYT001
This one is cool Scorpion HK-5035-500 with 5400W
http://www.scorpionsystem.com/catalo...0/hk_5035_500/
QYT001 is offline        Reply With Quote
Old 01-10-2010, 09:29 AM   #7
Cameron_S
Yes that was another they debuted but its more suited towards Aerial Photography ships with heavy payloads. Plus it weighs a lot too.
Old 01-10-2010, 06:13 PM   #8
Dogdocphil
I think this motor will not fit in a TRex because it is wider than the side frame spacing by 1mm.
Old 01-11-2010, 03:41 AM   #9
QYT001
Did you, measure it? Outside Diameter for this motor - 61.0 mm (2.4 in)
Old 01-11-2010, 01:13 PM   #10
BobbySmith
That is a Hoss!!
B Smith
BobbySmith is offline        Reply With Quote
Old 01-12-2010, 06:51 AM   #11
Taipan
I measured my 700 frames, they're 61mm apart. This motor will fit.
Taipan is offline        Reply With Quote
Old 01-12-2010, 07:26 AM   #12
1banger
It's gonna be a tight fit for an outrunner. Can't wait to see someone mount one of these and see how it goes...
1banger is offline        Reply With Quote
Old 01-12-2010, 07:29 AM   #13
QYT001
I measured my 700 frames, they're 60.6 mm apart.
Old 01-12-2010, 11:02 PM   #14
Dr.Ben
1.54 pound motor weight. HK4035 is 0.88 pounds.
32mm mounting hole spacing.
Not really a drop in installation for the current motor mounts out there.
Ben Minor
Dr.Ben is offline        Reply With Quote
Old 01-12-2010, 11:06 PM   #15
Cameron_S
Ben Minor
Which one? Where did you get the 32mm?
Old 01-12-2010, 11:12 PM   #16
Dr.Ben
The 50mm motor's dimensions are under the specs on Scorpion's website.
The HK4035 series motors and the Neu's are 25mm spacing. The Pyros are 30mm. Thus this new motor shares no common motor mount spacing with what is out there now unless the holes perpendicular to the long axis of the model are slotted in that direction.
Ben Minor
Old 01-13-2010, 07:50 AM   #17
Cameron_S
I sent an email to scorpion and got this back.
Dear Cameron:
Thank you for your email. The HK 5020-450 is for the bigger 90 size helicopters and now available for backorder. It is work on Trex 700E conversion. Both HK5020 and HK4035 can both use on 700 class, but the HK5020 is especially design for conversion, and have higher torque and power, but heavier than HK4035 series. The hole spacing of HK5020-450KV motor is 32mm, and I have attached a dimension graph for your reference or you can go to http://www.scorpionsystem.com/files/..._dimension.pdf
HK5020-450
Best Regards
Richard
Scorpion Power System
Old 01-13-2010, 07:23 PM   #18
Dogdocphil
As we all know this is an outrunner! I guess I dont want to be the first one to try this motor. The tolerances will be VERY small. BUT if anyone uses this motor, Please post. I am two to three weeks out from getting my Neu Motor. I will fly the Hyperion 4035-400 this weekend and post my results.
Old 01-13-2010, 07:35 PM   #19
Cameron_S
Well the fact that is 32mm spacing a custom motor mount will have to be used.
Old 01-13-2010, 07:44 PM   #20
BobbySmith
Should be able to use the Pyro mount and make it work
Man dunno about this motor more torque means harder on packs and more weight to carry around
B Smith
