Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > CB100
CB100 Walkera CB100 Helicopter Support
Old 01-19-2010, 05:52 AM   #1
snowflakes
Default Tail brakes away when reversing flight
Hello fellow cb100-flyers,
I am getting through the dark-cold winter playing around with my cb100: Big fun!!
Wanted to get your opinion on following behaviour: When I send my cb100 away from me (fast) and then pull the stick back before it hits the wall: Then for some reason the tail makes a 90' counterclockwise turn. The gyro seems to have difficulty with this manouvre..
Any of you guys seen this behaviour? or even beter: Any solutions out there?
Thanks!
CopterX 450 _ T-rex 250 _ Walkera CB100
Gaui Hurricane 425 (under construction)
Spektrum DX6i
snowflakes is offline        Reply With Quote
Old 01-20-2010, 07:06 AM   #2
Snuggles
Yep my CB100 has the same behaviour but i think it has nothing to do with the gyro.
A motor driven tail simply cannot act fast enough to cooperate with the sudden torque change.
However if you secure the receiver unit (which contains the gyro) tighter to the frame by using a rubber band or something like that, the gyro becomes more accurate.
Snuggles is offline        Reply With Quote
Old 01-20-2010, 03:56 PM   #3
snowflakes
Thanks for reply, and tip! (heb ik vanavond weer wat te doen )
Spektrum DX6i
Old 01-20-2010, 10:41 PM   #4
shaggybirdman
rubber band the rx!? cool. i'll have to give that a try. my 4g6 has the rx zip tied to the frame.
cx2, mcx, T Rex 450 SA, GAUI 550, walkera cb100, 4#6, 4#6S, 4g6S, trex 450 clone, V911/FP100, DX7, DX8
never hold your farts in. they travel up your spine, and that's where s****y ideas come from.
shaggybirdman is offline        Reply With Quote
