| 600 Class Electric Helicopters 600 Class Electric Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar. |
i have a question for people who are using Align ds610s for cyclics.
when installing them on the Align servo horn does the ball link rub on the servo? |
I have clearance, not much but I can see daylight
MSR, MCPX, 450s, 600, 650, 700, 800, 900, 1000 Assorted Mix Fixed Wing. AMA # 972083 |
#4 | |
What I did find as a problem was ball links rubbing against the servo wheels. Servos are sitting too low and the links end up pointing just a tad outwards. I had to install one or two CF spacers between servo and the frame to get the links straight (parallel to frame) and stop the ball link ends rubbing the servo wheel. |
Just enough to get 2 strips of paper through
#6 |
Good observation,just checked mine,one hits the label enough to mar it up a bit.Cant really feel it dragging but it is.The other misses it .
#7 |
I had the same problem with my 600cf. Installed a set of the carbon spacers along with the plastic set I already had in there and now it's good to go. At least this is an easy fix..
#8 |
How does a spacer/shim between the servo and frame prevent the ball from rubbing on the servo?
#9 |
It's not the ball..the ball link..inorder for it not to rub it needs to be almost perfectly 90
#10 |
i have the same issue. having read Nighflyers frequently asked questions thread i put some spacers tell the rods were at square to the frame. the odd thing is that one side took 2 spacers and the other only took one. i checked the bell cranks and they are the same distance from the frame so the only thing i could think of is that the servo horns sit further down on the servo. i have not confirmed this but i cant think of anything else. with the spacers i now have clearance. but what i did not like was i had to move the elevator arm over a bit to make those arms clear. now that is not centered. my question is how far off is going to make a difference as far as cyclic response? it has been pouring here so i have only got to hover her in the garage so i cant tell much.
TRaeside Blade CX2 - T-Rex 250 T-Rex 450 - T-Rex 500 CF HIROBO Shuttle ZX - E-Smart 600 All Metal - Gaui 200- Vision 50 - T-Rex 600ESP |
#11 | |
#12 |
Just like you said to
and as for the elevator i am still in the grooved out section but it is 2mm closer to the left side of the bird then the right.
#13 |
On mine with the align 610 servos the ball links rub the case pretty bad, I had to put a small washer inside the servo wheel to space the wheel out about 1mm from the servo so the ball link would clear the case without rubbing it. I will go check to see if the linkages are square and see if that will fix the issue. If not, I may try ordering a set of Quick UK servo wheels to see if that helps. The ball links clear with the washer in the servo horn itself, but not the fix I really want to live with since I give up about 1mm of spline doing it this way.
#14 | |
--Kevin
Trex 500 I2RC swash/Radix/BLS153/Quark/DS520/AR7000/ICE50/Neu1706H/1.5Y Trex 600E-Pro QUK/Radix600/BLS255HV/Quark/BLS251/AR7110/ICE280HV/HKIII4035-530 Trex 700LE Align 91H/SB20/Radix710/BLS451(8V)/DS760/BLS251/AR7100R/QUK clutch/tail |
#15 |
It is very very very tight. I cannot put two piecs of paper between it. You need to remove the plastic cover from the Align logo. You don't have this issue with Futaba servos. Maybe you have also noticed that the DS610s do not lign up correctly in the holes. The holes are measured for Futaba sized servos.
T-Rex 500E - JIVE 80+ LV + MINIPYRO 20-08 / BLS153 / CGY750 / BLS251 T-Rex 550E DFC - JIVE 100+ LV + PYRO 600-12 / DS610 / V-Bar / BLS251 T-Rex 700E DFC - ICE2 HV 120 / BL700H / CGY750 or V-Bar / BL750H |
#16 | |
--Kevin
#17 | |
#18 |
There's no standard for servo output splines, right? Hitech, Futaba, JR, etc. all seem to have different tooth counts and shaft sizes for each servo class. Is Align advertised to be the same as Futaba?
#19 | |
basically everyones fix is to put 2 carbon fiber servo plates behind the servo. this way it is parallel with the bellcrank... i think? |
#20 |
I did try spacing them out, and it still binded either way. I found the fix and it took all of 1 minute to make it happen. The align ball links have a spacer built into them at the bottom, this extra 1.5mm added on to the bottom of the ball causes it to rub the align servos when using the align servo wheels. I took my dremel and recessed the plastic servo wheel where the ball link sits so that built in spacer on the ball link goes down into the plastic about 1mm when you tighten it down, and now I have about 1mm of clearance between the servo and the ball link. Kind of feel like an idiot for not thinking of this in the first place.
