Old 01-19-2010, 11:45 PM   #1
UAV_PILOT
Question Which tail servo to use Align DS420 or DS520?
Hey guys I am getting my new 450 sport this week and I am trying to decide which is gonna be the best tail servo to use on it. I have both the DS420 and DS520. I know the 520 has more torque but the 420 is just a tad bit faster. Can anyone help me out? I will be running 6 volts and I do hard sport flying, light 3D like flips, loops and a few tic tocs.
Blade 450 X
UAV_PILOT is offline        Reply With Quote
Old 01-19-2010, 11:49 PM   #2
Wolfpackin
DS520
Jonathan Livingston Helicopter
Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.)
CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG.
T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades.
Wolfpackin is offline        Reply With Quote
Old 01-20-2010, 03:06 AM   #3
rcpower
May I recommend Futaba S9257? as this is align thread
rcpower is offline        Reply With Quote
Old 01-20-2010, 07:15 AM   #4
UAV_PILOT
Yeah but I have these two servos already and I am not going to use anything else.
Blade 450 X
Old 01-20-2010, 07:17 AM   #5
UAV_PILOT
So why is the tail servo in a different location on the pro? On the sport it's on the tailboom. The pro uses the 520 and the sprot uses the 420.
Blade 450 X
Old 01-20-2010, 04:00 PM   #6
rotodingo
The 420 is faster only on paper... Use the 520 if you can.
rotodingo is offline        Reply With Quote
Old 05-09-2010, 05:57 AM   #7
EmRen
Would the DS420 work with the Pro? Or is it too small to fit that new tail servo tray?
EmRen is offline        Reply With Quote
Old 05-09-2010, 12:15 PM   #8
Rustynail
DS520
Rustynail is offline        Reply With Quote
Old 05-10-2010, 09:51 AM   #9
garyji
I've not had good luck with the DS420. Never tried a 520 and use 9257's.
G.
T-450 Sport FBL, T-550 V1 FBL, Red Goblin 700. Goblin 500. 350 QX. Bunch of little Blades, and Planks. DX8, Retired Full scale Jet Plank Driver, U.S. Navy Ret.
garyji is offline        Reply With Quote
Old 05-14-2010, 09:29 AM   #10
nashus2002
I use 420 but ever with weighted tail grips the servo heat up and at the end of the pack i losse tail autority.
To much stress for the 420. i upgraded to 520, and rock solid when full collectif and hard piro. Go for the 520
TREX 450 SPORT 14T, scorpion-8/ICE50 GP750+DS520 DX8
TREX 500ESP spartan QUARK+DS650
IF AT FIRST YOU DON'T CRASH, TRY, TRY AGAIN.
nashus2002 is offline        Reply With Quote
Old 05-14-2010, 04:00 PM   #11
Ganchillo
Always thought the DS520 was the same as the 9257 ore something like this. Nevertheless
+1 on the DS520
Ganchillo is offline        Reply With Quote
Old 05-14-2010, 04:19 PM   #12
Spork01
Fear the Spork!!
I wouldnt use either one. 9257 or mks ds8910 for the win.
Oxy3+ , XK K110 and XK K120
Spork01 is offline        Reply With Quote
Old 05-14-2010, 06:57 PM   #13
snjbird
I have seen Bert rip it up with his totally stock sport super combo? So I think either will work... but If I had both in the spare electronic case, I would use the DS520, I have one on my beater 450 and it works great with the Align gyro...
snjbird is offline        Reply With Quote
Old 05-15-2010, 05:26 AM   #14
JAG1
ive got a DS520 on my 450 pro and 500,works great with a spartan quark!
Align 700L TOP Spartan Vortex VX1n
Align 550DFC V3 Spartan Vortex VX1n (the dogs nuts!)
Blade 180CFX
Futaba 8FG
JAG1 is offline        Reply With Quote
Old 05-15-2010, 09:10 PM   #15
Jerry.K
Take this test, remove the main blades then spin up the heli with the tail rod disconnected and try to move the rod by hand. You will install the larger servo.
Jerry.K is offline        Reply With Quote
Old 05-16-2010, 06:09 AM   #16
teef_au
The 450 Sport comes with the tail weight mod built into the heli, therefore the DS420 is strong enough. My sport has 50+ flights on it now and never an issue with tail authority running the 420. If it was me, I would use the 420 on the Sport, it's what the super combo comes with anyway and I would save the 520 for a 500 size heli.
"It is said that the big thing on top is a rotor - it's not it's a cooling fan for the pilot. We know this is true because if it stops spinning you can actually watch the pilot sweat."
teef_au is offline        Reply With Quote
