Old 01-27-2010, 01:45 AM   #1
zzr1
Default Switch Wheel Servo?
I just received Align 3G FBL recently. I already have QuickUK Servo wheel on my Trex 700E KDE. Manual say Align servo wheel 24.4mm horn diameter. I measured QuickUK servo wheel diameter the inner hole about 30mm. should I stick with it then adjust it? I have other one quick uk wheel servo H1120 25mm inner hole diameter. its same diameter. Im thinking buy two more H1120 25mm.
Thanks in advance!
zzr1 is offline        Reply With Quote
Old 01-27-2010, 10:28 AM   #2
steph280
The 24.4mm diameter is there for a reason, not just to reduce the throw, but also provide more leverage to the swash. I have not tried larger diameter, but I don't see why you can't use it other than the servo working a little harder.
steph280 is offline        Reply With Quote
Old 01-27-2010, 10:48 AM   #3
MrMel
Switch to smaller, it WONT fly good with bigger wheel and you will just overstress the servos & regulator.
(too high mechanical gain with bigger)
http://heli.dacsa.net
MrMel is offline        Reply With Quote
Old 01-30-2010, 01:10 PM   #4
zzr1
Thanks! I replaced Align servo wheel on my trex 600 Esp. Im still building on my Trex 600 and 700E KDE. I have 3 Quick UK wheel measured 24.5 mm. Installed on Trex 700E KDE. I will post pics soon
Old 01-31-2010, 04:28 AM   #5
Primus
Can you give us a product number for those? I am looking to switch mines too.
JR 11X | Powerlab V2 | Phoenix RC Sim
LOGO 400 VBar | LOGO 500SE VBar | Trex 600N LE VBar
Primus is offline        Reply With Quote
Old 01-31-2010, 03:31 PM   #6
zzr1
Quick UK H1120 but you select color
Old 02-01-2010, 06:28 AM   #7
mikmerl
Avoid using metal arms on servos with metal gears. In the event of a crash the servo gears will become damaged and that gets very expensive.
Best to have the arms as sacrificial items they cost almost nothing in comparison..
"nothing is foolproof because fools are so ingenuous"
Logo 600SE, Vario EC135 Benzin, Bell 47g II Benzin, BO 105 big Benzin, Benzin trainer, T-Rex 600NSP V-Bar, 500ESP 3G, 450 Pro, 250, Beam 450,
mikmerl is offline        Reply With Quote
Old 02-03-2010, 03:52 AM   #8
hundemann
Quick UK say, they are 25mm, not 24,5 mm. Don't know if it really matter at the end..
http://www.quickuk.eu/products/189/g...aba_h1120.html
hundemann is offline        Reply With Quote
