Go Back   HeliFreak > R/C Helicopter Support > Outrage Velocity 50 Nitro
Outrage Velocity 50 Nitro Outrage Velocity 50 Nitro Helicopter Factory Support Forum
Old 01-27-2010, 09:55 PM   #1
EO19
Default Velocity w/ RC Booya Quick Release Canopy mounts
Here are a few pictures of my Velocity with a set of RC Booya Quick Release canopy mounts. These are a set for a 700N that I used aluminum spacers on to get the proper length. It worked out well. I can quickly and easily get the canopy off and on.
ID:	136429   Click image for larger version
ID:	136430   Click image for larger version
ID:	136431   Click image for larger version
ID:	136432   Click image for larger version
EO19 is offline        Reply With Quote
Old 01-28-2010, 10:08 AM   #2
BenHeli
Very nice. The front thumb screws are annoying. This should be a sticky.
Team South Bay/Carson/PV
BenHeli is offline        Reply With Quote
Old 01-28-2010, 11:09 AM   #3
fsusmithc2
I like the function of these mounts and it's good to see they will work on this application. Pretty much the same concept as the quick release I have on my keychain. I know that the parts are well machined and work great but I just don't think they're worth $40+ for the set. But that's just my take on it.
AMA 879592 - IRCHA 3241
fsusmithc2 is offline        Reply With Quote
Old 01-28-2010, 05:26 PM   #4
tony whiteside
What is the spacers from?
I'm getting me some, it might be 40 bucks, but I'm also saying bye bye to grommets
priceless!
tony whiteside is offline        Reply With Quote
Old 01-29-2010, 05:16 AM   #5
Pulento
Looks like Vibe 50 spacers.
http://www.helidirect.com/jrmixingle...v9-p-16664.hdx
6HV, BLS451, Quark+MKS BLS990, Jive 80HV+Compass 540KV
3D+, Savox 1258TG, Spartan DS760+MKS BLS990, OS55HZ+Funtech B320
Rave ENV, Savox 1267MG@6.6V, BeastX+MKS BLS990, YS91SR+Hatori SB19
All controlled by a DX8
Pulento is offline        Reply With Quote
Old 01-29-2010, 06:59 AM   #6
kazager
I'm wondering if the larger diameter of the post will keep the breakaway tabs from breaking as they are meant to? Any thoughts?
kazager is offline        Reply With Quote
Old 01-29-2010, 07:05 AM   #7
Foxden
Don't they mount to the frame with a 3mm bolt? that should still allow the breakaway tab to do its job.
I just went back and took a close look Kaz, ya know it would be close as the diameter of the spacer appears to be covering most of the breakaway tab, I'm sure the tab would snap but it may also damage the frame as there is not much of a gap between to allow the small tab to bend or break away cleanly between.
Clyde Fox
Port Charlotte, FL.
Team Rotorworkz/Outrage
Foxden is offline        Reply With Quote
Old 01-29-2010, 03:22 PM   #8
Eric Brandenburg
Probably wouldn't be too hard to dremel the frames a bit so the canopy standoffs have room to flex without touching the frames.
Give me a lever long enough and I'll move the world...
):> Team Helifreak!
Eric Brandenburg is offline        Reply With Quote
Old 01-29-2010, 05:41 PM   #9
Foxden
I wonder if the cone spacer for the boom support upgrade would work, using the taper end against the breakaway tab will definetly allow the tab to break away as designed, just currious if the length is too long to use as a spacer
Clyde Fox
Port Charlotte, FL.
Old 02-09-2010, 09:18 PM   #10
EO19
I changed the front and rear spacers. I used extra finishing caps turned inward for the front and the spacer from the Align 700 Canopy support (HN7078) for the rear. Solves any issue their might have been with the breakaway tabs.
ID:	138679   Click image for larger version
ID:	138680   Click image for larger version
ID:	138681   Click image for larger version
Old 02-09-2010, 09:26 PM   #11
tony whiteside
nice!!
Old 02-13-2010, 08:44 AM   #12
BobbySmith
This is a great mod Eric showed me this when he did it and it works perfect
B Smith
BobbySmith is offline        Reply With Quote
Old 06-13-2010, 03:28 PM   #13
burton8012
so you used the align spacers for the front ones also right?
burton8012 is offline        Reply With Quote
Old 06-13-2010, 04:27 PM   #14
Helico-pteron
+1, do the key chain mod for $10 since it is the same thing.
To be honest, there are a lot of lazy heli pilots in these parts. I just don't find screwing in four thumb screws to be rocket science. It's more than simple and takes less than 30 seconds.
Lynx Team Pilot
Grand
RC Field Rep
BEASTX
Helico-pteron is online now        Reply With Quote
