shortly after takeoff my heli loses power. at first i thought i put on a very low battery. but i tried a fully charged one and same deal. it spools up fine but within 20 seconds i lose headspeed. motor rpm drops. is this a commom fault of this align esc???
Stock Tarot FBL DX7 |
no its more like lipo
trex 450pro trex 500 1400/bl60g, 15t, 6s, gp750/9257, 9650mg's,TT trex 600E 600xl/bl75g, 6s, 10t, 750/9256, hs5625mg's, TT trex 600N OS50hyp, hitori, mgp, 9451'sgy520/9256, TT trex 700N 91sz, hitori, g600, 610's, 611/9256, TT |
they are fully charged lipos with maybe 5-6 flights each.
I have not heard of the Align 35X causing that issue but it's not out of the question.
What size/capacity batteries are you using and how long were the 5-6 flights? Make sure the main rotors spin freely when you turn them by hand, you should get at least 3 full revolutions when you spin the head. Post your 35X programming.
Zen and the Art of Helicopter Maintenance Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.) CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG. T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades. |
im going to go back through and re program.
this is how i plan to set it up.. BRAKE- DISABLED TIMING- MID TIMING VOLTAGE PROTECTION- HIGH AIRCRAFT- SOFT START HELI (NO GOVERNER) THROTTLE RESPONSE- MEDIUM not sure about the settings. i have a 430L 3550kv motor should i run high timing?? governer mode locks throttle at one speed correct??? would i benefit from faster throttle response???
#6 |
I'd run mid timing and high throttle response.
1-2-2-2-3 is my setup.
#7 |
wow. pretty sure i had mine set on the medium response..i will stretch her legs tomorrow in the daylight and post results.. think my my problem is solved may have accidentally put the brake on.
#8 |
Also take off the idler pully as your belt may be getting jammed, soon to snap!
"Sort your head out and fly with your heart" Trex 450 SE V2: 9257 tail, Spartan Quark, HS65mg cyclic, DX7-AR7000, NEU 1107h/2y, Jazz Esc, Trex 550 FBL: Jive 100+LV, KDE/NEU 1907H/1/N42, Vbar 5.3, Futaba BLS 251 |
#9 |
ok fixed. idler pulley?? hah who still uses that?
