Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > E-Sky Helicopters > HBFP V1/V2
HBFP V1/V2 E-Sky Honey Bee V1 & V2 Fixed Pitch
Old 01-29-2010, 06:36 PM   #1
branden1832
Default DD tail rotor size?
so i am getting a xtreme DD tail rotor kit and was wondering what size GWS prop i should use with it. My guess is the 4025 or should i go with somthing a bit more pitchey like a 4530 or a 4540. My setup is stock except for a xtreme swash and xtreme skids.
branden1832 is offline        Reply With Quote
Old 01-30-2010, 01:09 AM   #2
Viet-Lama
Are you running a V1 or V2?
Get several props, they are only like .90 each from TowerHobbies.com
The smaller props work better on a lighter bee. If a smaller prop also seems to work as well as a larger one then use the smaller one. It will run more efficiently and the motors life will be extended.
If your running a V1 try a 4020, 4025 and 4030 if a V2 then 4025 or 4040 should work best. If you start adding weight to a V2 then id suggest a 4530
First two numbers is length in inches, second two numbers is the pitch in degrees.
Every time I crash I wonder, why didnt I get into RC tanks.
Viet-Lama is offline        Reply With Quote
Old 01-30-2010, 07:25 PM   #3
branden1832
thanks vl the 1 thing i do no is prop sizes from my 3d foamies. Always apreicate the knowlage
Old 01-31-2010, 12:57 PM   #4
Viet-Lama
Opps, me made a takey.... 4025 to 4040 should have been 4030 to 4040
Your welcome Branden
Old 01-31-2010, 09:08 PM   #5
FLThreeFiveZero
Ive looked around and I cant seem to find 4020 or 4030 props at any of the suppliers I can think of (Ive found 3030's, 4025's, 4040's, and 4530's). Ive tried BP,Tower.......so many I cant remember now.
VL, or anybody where are you finding the 20's and 30's at?
J.R.
Sent from my Laptop using "Hunt and Peck"
FLThreeFiveZero is offline        Reply With Quote
Old 02-01-2010, 07:45 AM   #6
Viet-Lama
Got mine at BP and Tower myself, that was many months ago though. The props you listed are great, youll find a good one in that diverse group so dont stress over it.
Old 02-01-2010, 10:30 AM   #7
FLThreeFiveZero
Good deal, Ill go with what Ive got.
Thanks,
J.R.
