Old 02-04-2010, 11:02 AM   #1
wjvail
Default Tail Gears
Howdy all... I've used the MA closed gearboxes for decades without problem and for the last couple of years had a open box on my Stratus. Yesterday while cruising around I started hearing a clicking sound. After landing I found the output gear on the tail had lost a tooth. It surprised me because I really was just tootling round at 1,450 rpm head speed watching the parts rotate. Yea I did some pirouetting but nothing like I've done in the past. Any ideas?
I've ordered a set of the "MA123-96 - MACHINED GEAR SET FOR OPEN CASE" ( http://www.ronlund.com/Merchant2/mer...&Category_Code= ) These are the right gears, correct?.?. Anyone had problems with the upgraded gears? Any advice for a long life?
I got lucky with this failure and landed without incident. And at close to $50.00 for a replacement set of gears I'd like to not have to buy these too often. I'm hoping someone tells me this is a one time, maintenance free, complete fix for this in-flight failure and I can fly reasonably assured I won't loose tail drive in flight. Any help?
Bill
ID:	137671   Click image for larger version
"Well, Nothing bad can happen now."
wjvail is offline        Reply With Quote
Old 02-09-2010, 10:37 AM   #2
wjvail
Are those crickets chirping?
Old 02-10-2010, 03:55 PM   #3
Laurens
I haven't seen this yet, because I'm almost only reading the electric section. I haven't had enough time on the new tailgears, but I've never had them break. So I think the new gears are a lot better so far.
Logo 800/Jeti DS16
Laurens is offline        Reply With Quote
Old 02-11-2010, 08:46 AM   #4
[X]Outlaw
I've been using the new tail gears for a couple months now with no problems
[X]Outlaw is offline        Reply With Quote
Old 02-14-2010, 07:04 PM   #5
Peter
Only times I've had that happen is after a tail blade and the planet have kissed ; even a gentle kiss has been enough too
I usually adjust the gear mesh after 3 flights with new gears , then forget about them !!
Peter .... Furion 6 FBL ; E,N and G Whiplash FBL ; 2 Spectra G FBL ; Stratus FBL ;MA Extreme+E Razor+N Razor +Fury 55 FBL;xcell 60+xcell 70: TSA 700N & G; TSA 600N Pro & Platinum ; All BeastX ; guided by XPS .
Peter is offline        Reply With Quote
Old 04-30-2010, 10:22 PM   #6
kenh
It looks like the gear got hot enough to sort of melt????? I think we have gone backwards by going to an open gear case. I don't care what kind of material you use gears need some kind of lube. Even if they run dry some kind of cover seems like a good idea to keep the crud off of them. Dirt and grit gets embedded in the gear and then all you have is sandpaper.
kenh is offline        Reply With Quote
Old 05-03-2010, 07:48 AM   #7
Brian James
The Machined Gears are much stronger. Make sure the gear mesh is set with zero backlash, and re-adjust after a few flights, and you should be good to go for a long time.
Zeal Rotor Blades
Team Horizon Hobby
Brian James is offline        Reply With Quote
