As the title says ,is anyone having luck with home made chinese weights?
I would like to know the weight and placement if you want to share. I know Heim`s weights are great i had a set until damage.The problem i have is that when i order from the UK i always get hit with duty etc.The last set i got was double the cost when i paid the duty etc! it is too much. |
I'm having luck with no CW... Good gyro+good servo= don't need'um
No Plankers were injured in the making of this post! TOY BOX contents Mcp x, 450 Pro VBar, 500 VBar, 12S 600CF VBar... Mikado Logo 6003D VBar Proudly flying KBDD, MKS, Castle, Scorpion and some planks too To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
I am using a 3500g on tail.
I am sure that i read the 500 needs loads of force to move standard tail setup. Thought the 3500 was borderline. |
Nope.... My 3500 and Spartan setup can do any 3D maneuver without issue, it goes fast backward, it piro flips and can do piro funneling eights, rolling circles front and backward. Now I can't do all that, but I had a Pro friend fly it, and I saw it do all that!
I just made my own by replacing the standard screws that hold the tail blades into the grips with some slightly longer ones and added some nuts at either end. With my standard Align DS520 servo it made a huge difference.
#6 | |
ha! you had me all jealous till you got to the "pro friend" part! ![]()
Thank god i have snowboarding to keep me occupied when its too cold to fly! To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#7 |
Nope not me, I can fly pretty fast backward, but you really don't know what the heli can do, till you see a guy like Alan or Bert fly it!
This is how I fly it!
#8 |
DIY here also. Just adjust what bits you put in until you get an easy pull with self-centering still there...
#9 | |
ok, i'm jealous again.
#10 |
Team Taco VP
Remember, Chinese weights are not there to make the tail fly better unless your servo is over worked with the tail design. On the 500 most tail servos can handle the load.
They are there to reduce the loads on the servo which DO exist regardless if it "flys just fine". In my opinion reducing the servo loads is just good sense all around. Servo may last longer and amp draw from your BEC is much better for it. Bob
"Don't Taco My Pack Dude!" To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#11 |
Here are some photos of my home made solution. Hardware from ModelFixings.co.uk Total cost for some M3 SS Cap Screws and nuts was £1.60!
