Old 02-12-2010, 04:02 PM   #1
maRRRco
Default 250SE Tail drift with spartan quark
hi all
i have a problem, my new 250se with spartan quark have a tail drift to right of 5░ in 1-2 minutes, the hely is new as the tail, perfect, with push rod not flexing
spektrum dx6i, gain 65%, uniball of tail servo at 6 mm, hyperion ds11 gcb 0.05 sec
i use 1 mm foam pad, i fix 5 cm of gyro wires
i don't know what i can do
thanks
maRRRco is offline        Reply With Quote
Old 02-12-2010, 05:37 PM   #2
MJO
I have the same issue with my 250SE except I have the Sparton 760. The tail drifts about 5 degrees in about 45 seconds. It does however hold the tail firm when giving maximum collective.
MJO
MJO is offline        Reply With Quote
Old 02-12-2010, 06:36 PM   #3
sethf8403
i just put the quark on my se yesterday and it's flying perfect, i used just 1 thin pad, because i was told more than that makes it wag, my gyro is set to 62 in my dx6i...is your servo horn centered? what servo do you have?
sethf8403 is offline        Reply With Quote
Old 02-13-2010, 11:27 AM   #4
maRRRco
MJO
mmm, the same problem, do you have find a solution??
it fly perfect, but in hover the tail drift of 5 degrees in 1 minute
servo hyperion ds11 gcb 0.05 sec 2kg 1520us 270hz
Old 02-13-2010, 11:31 AM   #5
zeeflyboy
I would suggest you have some vibrations you need to track down...
If a gyro like the quark is drifting, it is most likely to be due to vibration masking the drift it in my opinion. I assume gain is as high as you can get it without wagging?
zeeflyboy is offline        Reply With Quote
Old 02-13-2010, 10:51 PM   #6
QueadlunnRau
I'm glad to hear some people with the best tail gyro and the new SE are having tail drift. (Makes us non-se buyers not feel so bad. ~_^ )
For my non-se with clone 401 gyro and DS290G servo, when my heli starts to drift, I give it a good whack on the sticks for rudder doing a quick piro and the drift goes away.
Kinda like when a baby cries, you shake em enough and they stop ... err wait I didn't mean that.
QueadlunnRau is online now        Reply With Quote
Old 02-13-2010, 11:35 PM   #7
shield
Like previously mentioned vibration could definitely be a factor. Also make sure your not using any rudder sub trim. As far as setup goes I always set my tail with some pitch and hover it in rate mode first, then I switch over to HH mode. I'm using the stock gyro/servo combo and my tail is rock solid.
T-rex 450SE V2, 250SE / Blade CX2, mCX, mSR, SR / Walkera 5G6, 4#3B, 4G3, CB100 / Piccolo Pro / Hornet II / HBK 2
shield is offline        Reply With Quote
Old 02-13-2010, 11:35 PM   #8
MJO
I will have to look into a vibration issue. I must say it does not really bother me all that much I am more curious than anything. I run a JR 290 with a Futaba T7C and sparton 760. My gain is 7%. around 10% or higher I get a wag. As I said before even at 7% with full collective the tail is solid.
MJO
Old 02-14-2010, 12:30 AM   #9
Ah Clem
I have a Spartan 760 on my V1 (which has all the SE upgrades).
Also a 3500G tail servo and, of course, KBDD tail blades)
Absolutely no drift, no wag, and a very solid performing tail.
I agree with those that suggested that there might be a vibration issue.
The cable to the gyro might be a bit too restrained as well.
Old 02-14-2010, 01:30 AM   #10
GreenCello
It's also a good idea to rebind your receiver after any changes to your tail center or after a new set up. The gyro may be expecting one center and the set up or receiver is using another causing drift.
GreenCello is offline        Reply With Quote
Old 02-14-2010, 03:24 AM   #11
Matt Nasca
+1
GAUI NX7 - GAUI X7 - GAUI X5 - GAUI NX4 - GAUI GX4 - GAUI X4 II - GAUI X3 - GAUI X2 - All on VBar 5.3 Pro
Team GAUI USA / Empire Hobby / Scorpion Power Systems / Optipower Batteries / Cyclone Blades / Savox / YS Engines / VP PowerMaster / JR
Matt Nasca is offline        Reply With Quote
Old 02-14-2010, 02:09 PM   #12
maRRRco
but with a 20$ dollar gyro the tail doesn't have any drifts
the version SE is perfect, with best gyro is so more, not have any problem of drift
my gyro has a problem?? bohhh
is a mechanical problem?? no, my tail is as from manual
is a setup problem? no i used the quark manual instruction
the ely is stable, tracking perfect, noting visible vibration
is all new, never a crash
what is???:t hinking
Old 02-23-2010, 08:16 AM   #13
maRRRco
other opinion, i'm very bored
Old 02-23-2010, 11:11 AM   #14
EtheAv8r
Yeah, go back to your "20$ dollar gyro the tail doesn't have any drifts" and enjoy flying your 250.
EtheAv8r is offline        Reply With Quote
Old 02-23-2010, 11:28 AM   #15
Starcruiser
I wonder what the dead-band is on the gyro you are using is? I think this would contribute to the drift issue most definitely. the 3500G had no dead-band thus will correct for any drift of the servo due to mechanical forces. the JR ds290 has the same 0 dead-band.
I want to find out what the DS420 has as a dead-band.
I looked and cannot locate any info on the align servo's relating to dead-band. I think that coupled with tail linkage slop will cause the drift we have in the 250 tail.
Upgrading the tail with metal bell crank, better grip bearings and a CF control rod will improve control and reduce drift, I think adding the weight mod and using a tail servo with 0 dead-band would fix most if not all tail issues. I am almost all the way there myself, tail servo and weight mod's are about all that is left. Now do not get me wrong my tail is pretty solid but does experience some drift albeit minor, I have the bell crank coming today so I will find out more this weekend when I fly her again.
Weather is supposed to be above freezing, mid 30's, so I will be out buzzing around
Carl
Trex 550E FS Vbar Pro 5.2- EXI-450T Mini Vbar Pro 5.2 - EXI 450T BeastX - Trex 250SE - mCPx v1 Hp05 & HP06 w/HP03t tails - AMA #952544
Starcruiser is offline        Reply With Quote
Old 02-23-2010, 11:42 AM   #16
exit44rc
Default Re: 250SE Tail drift with spartan quark
I have seen other people who use rate mode to set up their gyro and then switch to HH. Why do you do this?
Pr˘tos 500, Nano CPx
exit44rc is offline        Reply With Quote
Old 02-23-2010, 07:25 PM   #17
maarset
It is because you want the tail to be mechanically perfect. If the tail doesn't drift in rate mode then the gyro doesn't have to work as hard. Some gyros require you to setup in rate mode with no drift. It doesn't have to be perfect with no drift in rate mode.
maarset is offline        Reply With Quote
Old 02-24-2010, 08:19 AM   #18
psilo
So if your tail was perfect with a $20 gyro why spend $170+ on the Quark???
What tail servo are you using. The DS420 was appalling with my quark and I could not get it to hold without wag or drift. Changed tail servo and now it is solid as a rock.
Have you tried ca'ing the gyro tray in on 1 side as mine was causing a slight vibe.
T-Rex 500 ÁBeast, 450 Pro (soon to be ÁBeast) & a Compass 6HV
And a P51D plank......SSssssshhhhhhh!
BMFA & RCHA Member
[B][COLOR="Blue"]
psilo is offline        Reply With Quote
Old 02-26-2010, 01:45 PM   #19
maRRRco
because with a 20$ gyro the tail is perfect only in hover lol
while with quark is perfect in all, less that in hover
i try to use align gel with align band to reduce vibration
i set the gyro in rate mode then i switch to avcs
i try think and thin pad, but nothing
tail is new and also the model
Old 02-26-2010, 05:22 PM   #20
psilo
So which tail servo are you using?
BMFA & RCHA Member
[B][COLOR="Blue"]
