Go Back   HeliFreak > R/C Helicopter Support > Walkera Helicopters > 4#6
4#6 Walkera 4#6 Helicopter Support
Old 02-16-2010, 07:15 PM   #1
helisplat
Default 4#6 binding problem
Hello,
I've just received my Barebones 4#6 today from Chinese Jade and tried to set it up on my 2801 PRO. The helicopter will not bind to the transmitter. I have tried reversing the throttle channel and lowering the trim but will still not connect. The Rx just keeps blinking. There are no setup instructions to setup the 2801 PRO with this helicopter. Can anyone provide me some instruction on how to solve this problem? This Rx is supossed to be compatible with the 2801 PRO. The only other thing I can think of is a faulty Rx, but I could be doing something wrong as I have never setup one of these fixed pitch birds before or Walkeras for that matter, as my 4G6 was already setup. Do I set the swash for 1 servo, etc, etc???. Other settings??? Any and all help you could provide me on these birds would be greatly appreciated.
Helisplat
helisplat is offline        Reply With Quote
Old 02-16-2010, 07:22 PM   #2
john aeras
You have to set the 2801pro to 2402 mode.
Some people have a problem for every solution...
john aeras is offline        Reply With Quote
Old 02-16-2010, 07:30 PM   #3
helisplat
There's a 2402 mode? Where do I change this. Thanks for the quick reply.
Old 02-16-2010, 07:38 PM   #4
3d-wanna-b
Nope. Theres a 2801,2601 and a 2401 mode.. Pres the ENT button scroll down to STICK press ENT scroll down to COMPTB press MODE +R or -L until you have 2401 mode showing on your screen then press ENT and your done. As for swash setup I figure you would set it on 2 servo since you only have 2 servos on the swash. Hope this helps..
Beating the air into submission!!!!
3d-wanna-b is offline        Reply With Quote
Old 02-16-2010, 07:44 PM   #5
3d-wanna-b
Dont you mean 2401?
Old 02-16-2010, 08:00 PM   #6
john aeras
Originally Posted by 3d-wanna-b View Post
Dont you mean 2401?
My typo mistake! I was trying to correct but my PC was acting up!
Thanks!
Old 02-16-2010, 10:52 PM   #7
shaggybirdman
this has the same rx as a cb100 right?
cx2, mcx, T Rex 450 SA, GAUI 550, walkera cb100, 4#6, 4#6S, 4g6S, trex 450 clone, V911/FP100, DX7, DX8
never hold your farts in. they travel up your spine, and that's where s****y ideas come from.
shaggybirdman is offline        Reply With Quote
Old 02-17-2010, 01:18 AM   #8
3d-wanna-b
No,
The cb100 has the older 2406C, 2406A. The 2406A RX is replaced by the programmable 2605A so you can program the CB100.. The 4#6 uses the 2428 rx. You can use the 2609 rx instead of the 2428 in 2801 mode and that will let you get into all of your programming on the 2801 Pro, other wise youll have to bind in 2401 mode if you use the 2428rx.
Old 02-17-2010, 07:06 AM   #9
Steve Joblin
Walkera's are kind of "finicky" when it comes to binding... You need to line up the battery plugs with the heli plug almost connecting them, but not having the metal actually make contact. The heli should be on a flat surface standing upright. Now turn on the transmitter and as quick as you can, plug in the battery to the heli (you should be able to plug it in quickly as you already lined up the plugs). Don't touch the heli during the initializing and binding process.
Steve Joblin is offline        Reply With Quote
Old 02-17-2010, 07:56 AM   #10
3d-wanna-b
Mine are not "finicky" I guess. I plug my battery in first then turn on the radio (2801 Pro). As fot it being on a flat surface I turn the heli over to plug in my batt then I sit it on the floor then I turn on the radio and all works fine.
Old 02-17-2010, 07:15 PM   #11
helisplat
I finally got a chance to try the 2401 mode for binding and everything worked great. Thanks to everyone that replied. The 4#6 is a dream to fly and a lot more docile than my 4G6, just what I need for in the house during these cold winter months. I always start the battery connector in the slots before turning on the Tx. It's the only way I can get the batt plugged in on time. The eyes aren't what they used to be. Now if I could just get the ##**##**#*%^*@&&**@@** ball screwed into the "tail blades rocker" on my 4G6 (same as 4#6). Any tricks or suggestions????
Old 02-17-2010, 08:06 PM   #12
Steve Joblin
could you drill the hole out a little and use some CA to glue it in place rather than having the threads hold it in place?
Old 02-17-2010, 10:01 PM   #13
3d-wanna-b
The way I do it is I take my x-acto knife and use the very tip and just cut around the hole on the very top to enlarge it a little and everything works fine for me. The screw starts fine and no need to use glue since you only enlarged the top of the hole.
Old 02-18-2010, 09:19 PM   #14
helisplat
I ended up trying both ideas. I used a 1/16" drill bit to chamfer the hole slightly and the ball screwed in quite easy. I applied a drop of CA to the threads and the butt end Hopefully this can hold it in place for a while. I've lost two of these on somewhat hard landings. The ball just strips out and disappears. Thanks again for the ideas.
Old 03-15-2010, 06:01 AM   #15
wilsontommy
Default Binding issues
I hjad the same problem and was resolved by connecting my heli battery first, put heli onto a flat surface and then turn on your trx. beeps and binds no worries. Make sure you have trx set to Stick mode 2 and put left throttle stick right down. good luck
wilsontommy is offline        Reply With Quote
Old 01-05-2011, 07:49 PM   #16
mostinc
Thanks 3d-wanna-b for the help...I was wondering as a newbie to 2801 pro just how to do it. I thought it would have a menu of all Walkera products and you just pick one. Never thought of just using the receiver model...but then again how would I ever know to use the 2401 selection for the 2428rx. Is there some source doc for this?
mostinc is offline        Reply With Quote
Old 01-12-2011, 09:31 PM   #17
Air Vaca
For installing the ball ends, I chuck them in the demel and turn it by hand. It won't squirt away from the chuck when you apply a little pressure, either.
regards,
Bill
Air Vaca is offline        Reply With Quote
Old 02-05-2011, 07:41 PM   #18
Martydev
I have a 2402 tx will it bind with 4#6 or will i have to replace it .
Martydev is offline        Reply With Quote
Old 02-06-2011, 04:27 AM   #19
jackeb
The 2402 will be fine with the 4#6.
Regards.
jackeb is offline        Reply With Quote
Old 02-23-2011, 09:33 AM   #20
Air Vaca
see my post above for installing balls.
