Old 02-21-2010, 11:22 PM   #1
Brushless2401
Default What are the advantages of an "S" pitch curve?
Maybe some one could explain the "S" pitch curve setup to me and the advantages or disadvantages of this setup. I had seen mention of this setup in another thread some where and was woundering about this setup and if I should give it a try.
Thanks in advance you guys and girls always have a great insite into this hobby!
Brushless2401 is offline        Reply With Quote
Old 02-21-2010, 11:30 PM   #2
DominicD
The Capi - HF Support
It makes the collective more sensitive around midstick.
SAB Heli Canada / RotorQuest/Compass
Team KBDD
DominicD is offline        Reply With Quote
Old 02-22-2010, 12:16 AM   #3
JasonJ
Or less sensitive around mid stick if you do it backwards S style
Velocity 50 FBL w/Beastx, T-rex 500ESP, 450 size scale UH-1N, T-Rex 450, mCPX BL, mCPX, Traxxas QR-1 micro quad, JR X9303, Realflight G3.5, AMA# 923167, Vice Prez Farragut Flyers
JasonJ is offline        Reply With Quote
Old 02-22-2010, 03:43 AM   #4
timewerx
Wow, why did I never thought of that! And I hate banging the throttle axis!
I don't 3D yet, but I'm not comfy at the rudder when the throttle is almost up just to keep the heli flying. And my hands aren't big so I feel better with more sensitive controls so I don't have to bang the sticks.
timewerx is offline        Reply With Quote
Old 02-22-2010, 05:32 AM   #5
Globs
A backwards S is like a DIY expo on collective, but with only 5 points. I'm hoping 7 points becomes the norm soon but it appears not.
Radios: DX7, RD6000(
Electric: Cypher 3D, Skya 250se, CX450ae/Hughes 500D,
Century Bell 47II (Hawk), w Z30a
Nitro: Hirobo Shuttle Plus, 450se Flasher, Walkera 4#3b.
Globs is offline        Reply With Quote
Old 02-22-2010, 09:44 AM   #6
michael503
a simple curve of 0-20-50-80-100 will give a noticable, but not drastic change. Rolls will become easier, as will some other maneuvers
-Michael
michael503 is offline        Reply With Quote
Old 02-22-2010, 10:18 AM   #7
skunkworx
It gives your collective a little more 'pop' when you start getting into collective moves (aka- tic/tocs, dust-offs, etc...). It loads up the disc quicker, so you just give it a short jab, then back off the collective and it gives you that snappy response you see the pros doing. You can do it without the S-curves, but you have to move your sticks a whole lot more and tends to make the move a little less precise/sloppier.
Tim - Atom 500, 6HV, 3D+, eAurora
KBDD TEAM PILOT
Compass support/Nankin Hobby.com
--Si vis pacem, para bellum--
skunkworx is offline        Reply With Quote
Old 02-22-2010, 10:37 AM   #8
Superior
I HAVE NO CLUE ON WHAT YOU GUYS MEAN SO ON A 5 POINT PITCH CURVE WHAT WOULD IT LOOK LIKE AT 0-25-50 AN SO ON
Trex-450 sport .....Trex 500
Raptor Titan 50 ys 56.ds610+650 gy520
T-rex 600 pro fbl scorpion 4035-560 CC hv 80
beastx ds610+650 all on 10s
Superior is offline        Reply With Quote
Old 02-22-2010, 10:42 AM   #9
DominicD
Not necessarily. The "Pros" tend to use +-15 collective and pump the collective to get quick stops and starts.
An S curve is neither good nor bad, it is simply a way to change the collective feel of the heli. I personally do not like it as it makes piro flips alittle less smooth.
Team KBDD
Old 02-22-2010, 10:43 AM   #10
michael503
Originally Posted by michael503 View Post
a simple curve of 0-20-50-80-100 will give a noticable, but not drastic change. ---
see above
-Michael
Old 02-22-2010, 11:36 AM   #11
steve28
I like using S curves on collective pitch .(0,17,50,83,100)
With a straight line an upright hover will be at around 3/4 stick inverted hover will be around 1/4 stick .
With the S curve Im using upright hover is somwhere in between mid and 3/4 stick and inverted hover is a bit more than 1/4 stick .
Hovering obviously still requires the same number.of degrees pitch you can just get there with less movement of the stick around center .
steve28 is offline        Reply With Quote
Old 02-22-2010, 11:48 AM   #12
life2short1971
It sounds like another method of expo to me. Is that correct?
Scott
Trex 500 / /3026-1600/CC Ice75 /3G /Ds510's/Torsion 430 fbl's
Trex 450 pro/HK2221-8/ Ice 50 /HS-5065MG/325D's/Kbdd's
life2short1971 is offline        Reply With Quote
Old 02-22-2010, 12:02 PM   #13
DominicD
It is expo for collective.
Team KBDD
Old 02-22-2010, 12:25 PM   #14
life2short1971
Scott
Old 02-22-2010, 01:18 PM   #15
skunkworx
That's where I heard it from first, so I suppose it could go either way. I know a few that use both. It's just a tool to get a different feel out of the sticks (kinda like EXPO or D/R). To each his own though
KBDD TEAM PILOT
Old 10-09-2011, 04:38 AM   #16
loubrianagustin
hi guys can anyone tell me about a S pitch curve and its value for each curve? thnx
1.
2.
3.
4.
5.
6.
7
loubrianagustin is offline        Reply With Quote
