Old 02-23-2010, 11:55 PM   #21
uaeboy_1981
thx alot MrMels i wait this for long time that good if u write list what they need to setup vbar
MrMels
uaeboy_1981 is offline        Reply With Quote
Old 02-24-2010, 02:30 AM   #22
Angler
Videos are great, thank you Mel.
I have a 2 questions (T-rex 700, Vbar, mikado head, DX7)
When I use DX7 setting from Vstabi, my collective is reverse (on preset file for 700), I checked the channels, I think they are OK.
Should I reverse channel from TX of from software?
Second is about swash leveling
I level my swash on setup menu, but when I go to normal menu I have about 5 mm tilt on collective towards to nose. Should I have same level on both setup or normal mode?
Murat
Angler is offline        Reply With Quote
Old 02-24-2010, 02:32 AM   #23
MrMel
V-BAR Guru
TX Calibration should be correct, always!
Use Collective Reverse checkbox if needed under Setup->swash->expert.
When you go out of setup mode = Control loop is enabled and all bets are off, only in setup mode = level swash and that's ok.
MrMel is offline        Reply With Quote
Old 02-24-2010, 03:11 AM   #24
uragano47812
Very good job!!
I will wait for some more explanation on advanced parameters like Integral and Integral limit.
Compass 7HV - Vstabi 5.3Pro
Trex 600 EFL Pro - MiniVstabi 5.3Pro
MiniProtos 3s - MSH Brain
uragano47812 is offline        Reply With Quote
Old 02-24-2010, 05:03 PM   #25
MrMel
V-BAR Guru
new Episodes are up (to 16)
Be aware its much technical mumbo jumbo in these last episodes as I go over the mainscreen and all expert parameters.
Don't fall asleep
Old 02-24-2010, 06:46 PM   #26
aliboy
EDIT: OK I found the new software at the V-stabi site and got all I wanted!!! Please ignore my question below (should have done more research before asking!!!).
MrMel - I noticed that on your videos you have a large number of presets. I have very few on my V-bar. I also noticed that in Set-up step 4, Swash, you have the picture of the sensor in the heli. I tried an online update, but nothing is new, and no more presets. How do I get these?
My PC software is v. 4.0.17
V-stabi controller is v. 4.0.20
Thanks, Al
aliboy is offline        Reply With Quote
Old 02-24-2010, 06:59 PM   #27
terrabit
Thanks MrMel! YOU are the man!!!
terrabit is offline        Reply With Quote
Old 02-24-2010, 08:07 PM   #28
krayzejava
Don't fall asleep
Love the tech mumbo jumbo! V-bar is a techys dream.
One question on the main rotor video, maybe I missed it and you mentioned it but how do you go about setting the main rotor gain?
Are you going to cover in a later video?
Cheers Tim
Mikado L400 6s - 9650, BLS251, Kontronik 60LV V-stabi
Mikado L500se 6s - BLS451, BLS251, Kontronik 100LV V-stabi
krayzejava is offline        Reply With Quote
Old 02-25-2010, 05:36 AM   #29
MrMel
V-BAR Guru
Main rotor gain is set by the slider (the one to the right off the 3).
What value totally depends on headspeed, dampers etc, but in a same way as tail gyro, raise it, if you get wobble at stop, you need to lower it.
Old 02-25-2010, 06:44 AM   #30
MrMel
V-BAR Guru
Episode 17 is up where I finalize the setup and check pitch, phasing etc (also included how to spot phasing issues on the field)
Will pause a while now as I will leave for a week, then I will continue with tweaking
Old 02-25-2010, 08:29 AM   #31
scaglio
Thumbs up
Thank you very much Mr. Mel. For a vbar beginner like me your videos are really helpful.
Massimo Scaglioni from Italy
scaglio is offline        Reply With Quote
Old 02-27-2010, 12:39 AM   #32
mikmerl
Fredrik this is excellent work.
These videos cleared up quite a few “grey areas” for me.
Thank you for going to the trouble.
"nothing is foolproof because fools are so ingenuous"
Logo 600SE, Vario EC135 Benzin, Bell 47g II Benzin, BO 105 big Benzin, Benzin trainer, T-Rex 600NSP V-Bar, 500ESP 3G, 450 Pro, 250, Beam 450,
mikmerl is offline        Reply With Quote
Old 02-27-2010, 03:25 AM   #33
WillJames
Very nice work MrMel!!
Thank you!
William James
If you fly you are going to crash.
WillJames is offline        Reply With Quote
Old 02-28-2010, 05:32 AM   #34
nightflyr
Very nicely done MrMel
In watching your video's I found a hidden problem and was able to correct it.
Very informative !!
MSR, MCPX, 450s, 600, 650, 700, 800, 900, 1000
Assorted
Mix Fixed Wing.
AMA # 972083
Old 02-28-2010, 09:35 AM   #35
EricW
Thank you for sharing all this and putting in all that work!
Very generous Fredrik.
One day I got stung, and now I love rotor sounds...Team RIGIDHELI.COM
T-Rex 700N Pro, Compass 7HV ult., MSH PRÔTOS
EricW is online now        Reply With Quote
Old 03-01-2010, 08:49 AM   #36
whytlotus
For me, these couldn't have come at a better time. I really appreciate the time and effort and sharing with the community here. Being a newbie to the VStabi, I'll feel a lot more confidant when time comes to maiden.
whytlotus is offline        Reply With Quote
Old 03-01-2010, 02:47 PM   #37
Angler
One more question,
I use gear channel in mix2 (DX7) to cut my engine, but at the same time Vbar using it to change banks.
I coppied same settings to all banks, but I wonder if it interrupts something in Vbar.
Old 03-01-2010, 02:49 PM   #38
MrMel
V-BAR Guru
Just make sure Bankswitching isnt turned on (Set to Bank 0) and it wont be used in the VBar.
Old 03-04-2010, 02:04 PM   #39
desert_flyer
Many, many thanks - these are very helpful....
desert_flyer is offline        Reply With Quote
Old 03-06-2010, 10:26 AM   #40
lavi
COOL
IMO, far better then Mikdo's Vids.
Thank you !
And... watch out Finless, MrMel is right behind you
lavi is offline        Reply With Quote
