Old 02-24-2010, 03:19 PM   #1
Khiledim
Unhappy Problems with t-rex 450 sport
Hi,
I have some weird vibrations problem with my sport.
It only vibrates in normal flying mode during hovers.
It started to vibrate after some time out of the box - had no crash before!
I tryied to locate the problem by changing different parts,so I chaged shafts,
blades,dampeners, lower&uper mixers,blade grips,grip's bearings,
main gear & one way. I also played with thrittle curves and no succes,
so i think it can't depend of rpm's...
Here's the short video with it.
Khiledim is offline        Reply With Quote
Old 02-24-2010, 03:36 PM   #2
d_adam
not depend of head speed but it happens during hover in normal flight? nonsense
You said that when you increased throttle curve, it still vibrate ? ... when you increase enough the curve will be the same as idleup so non sense x2
increase your throttle curve....
Best regards,
Adam
Tornado Fuel, JR Radio,
d_adam is offline        Reply With Quote
Old 02-24-2010, 03:45 PM   #3
Wolfpackin
Look at that...two guys from Poland.
+1 on possibly low headspeed.
What are your throttle & pitch curves and what size pinion?
Did you check or replace the main and feathering shafts?
Those can bend on just a hard landing.
Zen and the Art of Helicopter Maintenance
Blade 400: E-flite 420H/35X ESC, AR6100e, HS65HB x 3, G401B/DS290G. (Ret.)
CopterX 450AE V2: 430XL/35X ESC, AR6100, HS65HB x 3, LTG2100T/HSG-5084MG.
T-Rex 550E V1 Classic Flybar: 600MX/BL70G, AR6200, DS610 x 3, Quark/DS650, 16t/520mm blades.
Wolfpackin is offline        Reply With Quote
Old 02-24-2010, 03:47 PM   #4
d_adam
he did mainshaft from plasticine
Best regards,
Adam
Old 02-24-2010, 03:49 PM   #5
Khiledim
Yes, sure i took it from your t-rex 700.
Don't make offtopic in my thread anymore please.
As i wrote beafore of course i have tryed to change both shafts. Same results.
New align engine with pinion 14, thro curve 0-55-90 right now in normal - tryed higher also.Same results.
Old 02-24-2010, 03:53 PM   #6
life2short1971
Scott
Trex 500 / /3026-1600/CC Ice75 /3G /Ds510's/Torsion 430 fbl's
Trex 450 pro/HK2221-8/ Ice 50 /HS-5065MG/325D's/Kbdd's
life2short1971 is offline        Reply With Quote
Old 02-24-2010, 03:55 PM   #7
d_adam
No worry, I will buy new one for YOU !!
OK Stop my friend I think, you are very nervous
Who can help him ? Is here a psychiatrist ? Joke
OK, ok ....
I forget that It isn't polish forum
Best regards,
Adam
Old 02-24-2010, 03:59 PM   #8
jaywhy
That type of vibration is referred to as `porpoising` (like the animal) - and it's from either too low of a head-speed or something too tight like the blade grips. Maybe something in the tail drive too, but I'm not positive about that.
jaywhy is offline        Reply With Quote
Old 02-24-2010, 03:59 PM   #9
eDeK
d_adam,Why you are saying it now,in his thread rather to help him in real.
Stop trolling.
eDeK is offline        Reply With Quote
Old 02-24-2010, 04:48 PM   #10
Aussie_phoenix
Thumbs up
Try changing the normal throttle curve to 0-80-100 and normal pitch curve to 40-50-100 then see how it goes.
Trex250 Phoenix25, DS410 GP750 5084 AR6110
Trex450SEV2TT 4S Scorp-8 Phoenix45 CC10 Spektrum H3000 MKS-DS95i AR7200BX
CopterX450ProTT 4S Typhoon2218 Phoenix35 HS65MG GP750 MKS-DS95i AR6100
Trex600E 8S 1910H/1Y HV85 5625MG Gy611 S9256 AR7000
Aussie_phoenix is offline        Reply With Quote
Old 02-24-2010, 04:50 PM   #11
zen
Khiledim—
the heli in the video shows the typical movement when there is not enough head speed. Instead of 55% at mid-stick go to 80% or more. No less than 70. If you dial it up to that range the up-and-down motion of the tail ought to stop.
The other factor is the size of the pinion gear on the motor. 11 tooth for hovering and basic maneuvers, 12 tooth for more aggressive upright flight plus loops, rolls, and flips.
To give you some idea I fly a 450 SE (V1) with a 12 tooth pinion on an Align 430 L motor. The throttle curve at center stick in both normal and idle up is 85%. At zero pitch (center stick) the head speed is 3,000 RPM, dropping to 2,800 or a little less when it lifts off.
Regards,
Glen
Trex 450 SE V2
T-rex 500 ESP
zen is offline        Reply With Quote
Old 03-01-2010, 08:07 AM   #12
yakflyer
some good info here, but I agree, it sounds like headspeed to me as well. I had tweak my throtle curve @ 1-3 to be a few points more. May suggest u check the programming on yr esc? I am wandering if yr spool up is too fast??? Just an idea to look at. I adjusted my settings to allow a sofTer start up and a little patients for the head speed to spool up.The only thing I am trying to figure out now is a slight drifting I experience during hoover. trimming dosent correct it. any suggestions fm those great minds here will be appreciated.
yakflyer is offline        Reply With Quote
Old 03-01-2010, 11:08 AM   #13
FlyingHigh 450
+1 on taking the headspeed up.The Trex 450 Sport has a very stiff head and needs alot of headspeed,mine ran awesome with no vibes or wobbles at 0-60-75-85-100 and idleup was a flat 85%.
Started the hobby in Feb of 2008
FlyingHigh 450 is offline        Reply With Quote
Old 03-01-2010, 01:06 PM   #14
yakflyer
Here's a thought, is there any possibility your belt is not set to the correct tension? I've notice mine would do that if it was too tight.
Check and see & save a few more $$$
Old 03-01-2010, 04:18 PM   #15
teef_au
This thing is a sport, so unless he bought a custom pinion it has a 14 tooth coupled to a 3550KV motor. IT can develop enough head speed but as others have said the throttle curve is way too tame and this is not the first time I have seen a properly set up sport suffer from this.
Bottom line - 0 - 80 - 100 is not unreasonable. Normal pitch curve of 40 - 50 - 100 is also what I use.
"It is said that the big thing on top is a rotor - it's not it's a cooling fan for the pilot. We know this is true because if it stops spinning you can actually watch the pilot sweat."
teef_au is offline        Reply With Quote
