Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > SR
SR Blade Helicopters (eFlite) SR
Old 02-26-2010, 11:14 PM   #1
TonyRumore
Default DX6i Settings for the SR?
I'm a newbie, so I am not going to attempt to run my new SR on my DX6i....but I know one of you FREAKS is going to hook me up.
If you have some DX6i programming worked out for the SR, I would like to see it.
Tony
TonyRumore is offline        Reply With Quote
Old 02-27-2010, 04:05 AM   #2
AKD001
I'd be interested as well! (When the time comes, at least).
AKD001 is offline        Reply With Quote
Old 02-27-2010, 08:47 AM   #3
cedron
I would be too interested. I tried the settings for a cp pro 2 well they dont work so please do not try them. Maybe I had a wrong setting but I dont think so, everything moved in the direction it was supposed to move. Well anyways I crashed big time. I was powering down and the blades had almost stopped and the SR took off like a rocked forward and into a wall. Blades maybe grips too, main gear, tail boom, boom motor, rotor all gone now. Also I called HH and the tech told me they are going to have a programming manual out this summer for the dx6 and dx7. Everyone have fun
cedron is offline        Reply With Quote
Old 02-27-2010, 02:29 PM   #4
AKD001
Very intriguing news. It seems like it would be good timing for them to make another marketing push to novice SR owners to sell more DX61 and DX7s.
...(though I'm sure one of the experts here will have already posted some potential settings to work with in a few days, not a few months).
Old 03-01-2010, 12:58 PM   #5
LegndarySaiyan
I started trying to make a model in my dx6i last night. I had problems getting collective to move correctly one servo was opposite the others altough its aileron control was correct. I finally sorted all the movements out by reversing pitch and running negative swash mix. I'm setting up for 0 degrees pitch at half stick but i'm still have problems getting it to lift where i want it to. I have to run way to much mechanical pos pitch to get it to lift correctly. Either way I still have to work on both my mechanical pitch and radio pitch curves curves until this thing flies closer to my 400. Once i get set I'll post my settings then if you want to soften them you can just do so with dr & expo. Anyone else having pitch issues similar to mine let me know. Only so much negative pitch is available before the swash plate is at maximum height.
-Phillip Johnson, AMA #954735
LegndarySaiyan is offline        Reply With Quote
Old 03-01-2010, 05:05 PM   #6
cedron
Smile
Ok I bit the dust and had a Very Good heli pilot prgram my dx6i radio for me. Now it flies like a champ. Here are the settings he prgramed for me.
D/R Expo:
Aile 1 - 70% + 30% expo Aile 0 - 100% + 20% expo
Elev 1 - 70% + 30% expo Elev 0 - 100% + 20% expo
Rudd 1 - 80% + 30% expo Rudd 0 - 100% + 20% expo
Travel Adj - all set to 100%
Sub Trim - All set to 0
Throttle Curve:
Norm Pos -
L - 0%
2 - 45%
3 - 60%
4 - 75% H - 100%
Stunt Pos -
L - 100%
2 - 88.5%
3 - 75%
4 - 88.5%
H - 100%
Pitch Curve:
Norm -
L - 42%
2 - 46%
3 - 50%
4 - 75%
H - 100%
Stunt -
L - 0%
2 - 25%
3 - 50%
4 - 75%
H - 100%
Swash Mix :
Aile +60%
Elev +60%
Pitch -35%
Under the Setup List:
1) In the reverse menu Reverse the Rudd and Pitch settings
2) Under Swash Type - Select CCPM 120
I Started flying with these settings and love them. I did change the exp from 30% to 15% its just my preference seems to make it a little more reponsive. Let me know what you think! Have fun
Old 03-01-2010, 08:43 PM   #7
LegndarySaiyan
Did you or your LHS adjust the blade pitch and swash linkage at all or did he just tune the tx for the stock setup? Those settings look pretty close to what I've come up with but the pitch curves won't work for me if your mid stick pitch is still 7 degrees in normal flight mode.
Old 03-02-2010, 04:36 PM   #8
cedron
All adjustments were made on the radio. Nothing was done to the heli itself
Old 03-02-2010, 09:34 PM   #9
mattia
is this setup good for 3D?
mattia is offline        Reply With Quote
Old 03-02-2010, 11:06 PM   #10
Daddy
Cedron
Thanks a million : ) How does these setting compare to the stock TX? IE, do you think the expo in stock TX about 30%? Forget low rate...it's like 90%!
Daddy is offline        Reply With Quote
Old 03-03-2010, 05:37 AM   #11
sidi996
Default Gyro Menu DX6i
Hello Cedron
Thank you for the DX6i Settings. You don`t use Gyro menu? When gyro set from transmitter 50% - 100%, it`s HH mode?
Thank you
Dieter
sidi996 is online now        Reply With Quote
Old 03-03-2010, 05:02 PM   #12
cedron
Mattia - You can try this for 3D. I don't do 3D so it is hard to say how it will do. It was programed though by someone that does do 3D. Hope that helps.
Daddy - The Settings are close to the stock in my opinion. I have already changed my expo to +15%. Just my preference
Dieter - I am really only hovering right now so I really do not see a need to use the gyro settings in the radio. By the way what part of Germany are you in? I lived in Mainz for 2 years. Dan
Old 03-03-2010, 07:06 PM   #13
cedron
OK I have hooked up the gyro lead wire and have the gyro in the radio set to 75%. Seems to work pretty good there. Might tweek it some more not sure.
Old 03-03-2010, 08:50 PM   #14
Daddy
Thanks, I'll give mine a go at those settings. Good to hear you hooked up gyro to ch 5. I have my B400, same gyro, set at <50% and 65%. I find that when I first start up if I toggle 3 times (reset gyro) the tail holds much better on take off...don't know why, just that it works for me. Will try on SR when I get some time ( work : (
Ken
Old 03-03-2010, 08:56 PM   #15
KCMike
Where does the gyro plug in on the Rx (I can't recall which port).
My YouTube Channel: http://youtube.com/DarthTedd
Xbox Live - TheBiffTannen
KCMike is offline        Reply With Quote
Old 03-03-2010, 08:57 PM   #16
Rikybo
Ken
Ken,
I HAVE to remember that you are using the DX so when I pry my wallet open in the coming months I may impugn upon your kind nature!
Regards,
R/B
"Trust, then verify"
Rikybo is offline        Reply With Quote
Old 03-03-2010, 09:16 PM   #17
Daddy
Originally Posted by Rikybo View Post
Ken,
Regards,
R/B
No problem R/B...BTW, a DX6i comes with a B400!...There's that gunshot again.....
Ken
Old 03-03-2010, 09:19 PM   #18
Daddy
Channel 5 which is the second from the right when looking at it from behind (and it's the one that doesn't have anythig plugged into it.)
Don't plug it in on the open spot to the far left, this is for binding and BEC.
Ken
Old 03-03-2010, 09:26 PM   #19
KCMike
Ken
I gotcha. I knew it wasn't the BATT port, but couldn't recall what the port on the second from the right was.
Old 03-03-2010, 09:31 PM   #20
Rikybo
u
Ken
You HAD to say THAT!
Wife is gonna KILL me!
r/b
