Old 02-27-2010, 03:45 AM   #1
spartan2381
Default CP II and Small field
The field I fly at is on the small side and it has trees to the left, and open space to the right. Is there any way to configure the CP II for this environment?
spartan2381 is offline        Reply With Quote
Old 02-27-2010, 05:33 AM   #2
pril250
Yep!
Blade400
pril250 is offline        Reply With Quote
Old 02-27-2010, 07:22 AM   #3
nightflyr
I fly mine in my yard so you should be ok
Old 02-27-2010, 12:35 PM   #4
pril250
Seriously though there is no facility to relate control of the surroundings. All it knows is whether there is sufficient temerature differential ground to sky to operate or turn off.
Cold overcast day=stay home or take control.
Blade400
Old 02-27-2010, 01:36 PM   #5
n6nev
As I understand it, the main sensor "sees" 4 directions horizonaly to maintain a recovery to level..On the bench I can put my hand in front of a sensor and cause the swash plate to move... The main sensor has a 6 degree view of the horizon, but I have flown in my yard next to the hose and fence, trees, cars, with little or no interference. Larry
"You can always tell a pilot,but not much"
Gaui X 5 Phanthom 2
n6nev is offline        Reply With Quote
Old 02-27-2010, 01:44 PM   #6
spartan2381
Very cool thanks for your help guys.
