Hello , i just ordered them and i want to ask if there is a video or a thread about setup all this together. Is it easy to do it ? because i'm only three months in electric helis and i love my trex 500.All my other helis just stay in the ground.
Thank you all, George. |
finless has a CC85 hv vid were he goes through setup with the castle link. That should help out a little.
Vergnugenstabi [adj.]pleasure/stability The enjoyment and feeling you get when flying a vbar. [farg-new-gen-stab-e] CF Logo 600SE.. Robert A. Team HAIYIN |
i'll check it out ,thanks.
No problem, where do you plan on mounting your esc? I have my esc mounted infront of the motor on my 450, but I want to build the 500 with the esc on the side. Every time I see a team align heli they have the speed controller mounted on the side of all of their helis. So ima try that this go round..
i have the esc in the side but i don't know about the scorpion wires if are ok. Does anyone have the same combo to give me a list with the setup?
#6 |
Search the ice forum and you'll find setups listed there. Plus alot of other useful info. The CCIce has its own forum on here.
Scott Trex 500 / /3026-1600/CC Ice75 /3G /Ds510's/Torsion 430 fbl's Trex 450 pro/HK2221-8/ Ice 50 /HS-5065MG/325D's/Kbdd's |
#7 |
i can't find it !!!
#8 |
Well I thought they did. Here is where most of the ice info is saved.
http://helifreak.com/forumdisplay.php?f=34 I can try and help you also. I have a ice 75 and a scorp.1600.
#9 |
I have my esc on the right side and the wires ruuning from the motor down the inside middle of the frame and out the hole near the back on the right and plugging into my esc.
#10 |
Thank you guys very much , i will need your help.
#11 |
AMA # 927862 Trex 500 FBL esp Kontronik Jive 80LV / Scorpion 1600kv - JR 3517mg cyclic - BeastX / Futaba BLS 257- Compass Tracx FBL head JR9303tx / AR7600rx |
#12 |
Another question, what battery is the best for this set up for hard 3D?
Thank you. |
#13 |
The 6s 30C 2650 turnigy is a popular reliable option. Hyperions of the same or slightly larger are also nice. You can fit up to a 3200 I believe but you start getting nose heavy over 3000mah.
#14 |
Until now i fly with 3000 20c & 3000 30c turnigy and i am very pleased i'll hope that's ok with my new set up.
#15 |
Can i use the 3000 20C for my set up or i'll destroy my battery or anything else ?
#16 |
No it'll be fine for setup.
#17 |
Thank's ,about at the end of the week if the weather is good i'll try it.
#18 |
Hi guys, i want to ask you about setting rpm in gov mode. I put 6cell =22.2v , 15t pinion 162 main gear ,1400kv - 10 poles and the ice75 tells me that my headspeed for proper governing is 2460. how can i put 2750 headspeed ? can i change the number in volts or something else?
Thank you. |
#19 |
The CC software is conservative in it's HS calculations, but you do need to take their recommendations into consideration, as the controller will govern the HS at a constant down to 3.7V per cell. So that means constant HS from a freshly charged battery all the way down to discharged voltage under load.
I run the same setup and use 2600 rpm and it works perfectly with only a few 100% throttle hits towards the end of the flight. Be warned hard on batteries so make sure you have at least 35 to 40C packs, otherwise your packs will last only about 40 cycles.
TRex 250 BeastX, Trex 500-Vbar 5, Henseleit TDR, Banshee -VBar 5 All Kontronik ESC Hyperion 1420, Mega Power Gemini Chargers! JR XG11 Old hand at Planks To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#20 |
Thank you i'll try it!!!!!
