Old 03-13-2010, 11:40 AM   #21
Blackbird1
In order to have 2750rpm headspeed with governor the only way is to increase pinions tooths? Has somenone running 2750HS with governor? any good set up for the ice?
Thank you again.
Blackbird1 is offline        Reply With Quote
Old 03-13-2010, 12:59 PM   #22
life2short1971
I run 2700 with the 1600 scorpion and a 14 tooth without issue. I personally think thats topped out.
Scott
Trex 500 / /3026-1600/CC Ice75 /3G /Ds510's/Torsion 430 fbl's
Trex 450 pro/HK2221-8/ Ice 50 /HS-5065MG/325D's/Kbdd's
life2short1971 is offline        Reply With Quote
Old 03-13-2010, 01:10 PM   #23
Blackbird1
Will a 17t pinion with the 1400 i have work out?
Old 03-13-2010, 01:29 PM   #24
life2short1971
I have a feeling you'll eat your batteries alive but it will on paper.
Scott
Old 03-13-2010, 01:52 PM   #25
Blackbird1
So you are saying to stick with the 15t and 2600HS?
Old 03-13-2010, 10:08 PM   #26
life2short1971
No try 2700 hs with a 15 tooth. Then pull the graph and see how much time the governer spent at 100% output.
Scott
