Old 03-08-2010, 04:12 PM   #1
Holmquist
Default Straight 2s Rx pack wiring question
I am going to run an unregulated 2s on my velocity with all HV outrage servos. So between the V-bar "being used as primary Rx" and the Rx batt I want to put a JR on/off switch, my question is to connect the Rx batt to the JR switch lead can I cut off the servo style plug and solder on a deans? And if so the JR switch has a pos. neg. and sig. wire since the battery only has a pos. and neg. what am I supposed to do with the sig. wire? Thanks
Austin
PULLIN PITCH
DX7s, SBACH 342
Holmquist is offline        Reply With Quote
Old 03-08-2010, 08:01 PM   #2
wolfdown
I think you can just ignore the signal wire. The switch is connected to the positive (red) lead if I remember correctly. Also, no problem changing the connectors. Just make sure the switch, wires, and connectors can handle the current you're planning on passing through it.
If there is anyway you can go without the switch, I recommend that.
Rush 750 w/ Xera 4530-500 (12T), YGE160HV, WR S.BEC, Torq 9180/9188, AR7200BX
Outrage 550 w/ Scorp 4020-1390 (13T), YGE120, CC BEC Pro, Quark, MKS BLS980, Futaba BLS451
Last Rebuild: 10/15/12 (O550)
wolfdown is offline        Reply With Quote
