Old 03-12-2010, 09:18 AM   #1
Darth Nigel
Question Making woodies fit the Sonix head - safe????
I installed my Sonix cnc head on my much-repaired Blade 400 last night. After getting all the fiddly bits aligned, I discovered that the woodie Eflite blades (EFLH1415A) don't fit; neither do the CFs.
However... if I take off the wee black plastic "shoulder" pieces, I can slide the wooden blades in.
Is this a good idea?
Are the shoulder pieces just to provide thickness or are they structural?
Am I in (more) danger of the woodie shearing at the mounting hole?
(I have seen TwistFish's link http://www.helifreak.com/showthread.php?t=198434 but didn't want to derail that thread)
Darth Nigel is offline        Reply With Quote
Old 03-12-2010, 09:53 AM   #2
Cailid
Never heard of anyone using the eflite blades without the plastic piece. I think you'd be better off using the align woodies. They're thinner than the eflite as well as better quality for the same price.
MCX, CX2, MSR
Blade 400, 500ESP, 500CF
Cailid is online now        Reply With Quote
Old 03-12-2010, 12:29 PM   #3
schoep
If you take the plastic off you should first up all of your insurance!
CX2,MSR,,R/C weapons pod, Camera pod, Scale Hughes 500 W/Blade 400 mech, HK450, HK500CMT
schoep is offline        Reply With Quote
Old 03-12-2010, 12:38 PM   #4
n6nev
Default blades for the Sonix head $3.62 pair
http://www.xheli.com/60p-pro-3252.html
this works great for me
1 HT FPV Quad ,naza, fatshark "You can always tell a pilot,but not much"
n6nev is offline        Reply With Quote
Old 03-12-2010, 12:42 PM   #5
whoanelly
+1 any blade should work except the eflite woodies,,i wouldnt,,especially if you dont have a dental plan..
700LE : 105HZR AR7200BX JR8917 Multi gov , JR9503
600ESP : 100AMP Castle. Scorpion Motor . AMA #962896
400 Blade : Scorpion 2221-6 ,Castle ICE 50 Sonix Head and t
Align 450 pro V2 3G MKS DS95 MSR , 2 x MCPX (brushless C05 & HP05), Blade 130X.
whoanelly is offline        Reply With Quote
Old 03-12-2010, 12:47 PM   #6
rowdyjoe
I had a very bad experience with plastic blades last year and haven't used them since. Evidently, there was a hairline crack at the blade grip bolt hole and it separated when the heli spooled up for flight. Both blades came off at high head speed. Fortunately, nobody was hurt but, it scared the #@$#$ out of me.
I've been buying fiberglass blades from eHirobo for approx. $6.50 a pair (plus shipping) and have had good luck with them. They will require balancing but, they are more durable and worth the money.
RJ
RJ
rowdyjoe is offline        Reply With Quote
Old 03-12-2010, 03:15 PM   #7
Tommygunn
Do not remove material from the blades. Major potential for structural failure.
I had the same issue with my cnc sonix grips. Even the Align 335 Pro woodies were tight. However, most CF blades fit perfectly. I don't bother with the Eflite woodies. Bad blades.
What I did was take a dremel to the grips and removed about .001 - .002" from each side of the grip. Measure it before and during the removal process and take only the minimum amount needed off equally. I have three sets of Sonix grips and two of the three needed this done. The third seems fine. Why? Dunno.
550 Trex FBL, Beastx, Kontronix 100 Jive
500 Trex FBL, Beastx
450 Trex Sport
All flown with my DX7
Tommygunn is offline        Reply With Quote
Old 03-12-2010, 08:12 PM   #8
Darth Nigel
Thanks for all the input. I may be out the cost of some blades but it's probably cheaper than restorative dentistry.
Cheers
Nigel
