Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mSR
mSR Blade (eFlite) Micro SR Helicopters Information and Help
Old 12-15-2010, 07:04 PM   #221
PIMPMYMSR
What kind of Airwolf canopys are available as i saw there are a few and which one is better quality?
PIMPMYMSR is offline        Reply With Quote
Old 12-16-2010, 02:09 AM   #222
AirwolfRCpilot
Hi there down under! Welcome to the Airwolf mSR thread.
As far as I know the Airwolf mSR fuselage is the only Airwolf fuselage which was really engineered for the mSR mechanics. It has unique features such as the battery holder integrated ADF POD (the famous rocket launcher), the release on impact system that saves both fuselage and mSR mechanics on impact, etc.
About the quality of the material: it's hand build and made of vacuum formed high impact PS which is a durable material which gives the possibility to repair easily with plastic model glue and to add details which come from cannibalized 1:48 scale plastic kits like scale landing gears, nose tubes, etc.
What else could you possibly expect about a fuselage?
AirwolfRCpilot is offline        Reply With Quote
Old 12-18-2010, 03:41 PM   #223
Jaryd107
My helicopter flys for about 1 minute. Would you guys recomend the turnigy 160mah batteries???
Are there any other batteries i could use...i currently use and eflite 150mah but its kinda old.
Jaryd107 is offline        Reply With Quote
Old 12-18-2010, 04:04 PM   #224
AirwolfRCpilot
Looks like your battery is really dead, the E-Flite 150mAh has about the same flight time as the Turnigy 160mAh. A battery of this type in good condition should give you about 5 minutes flight time. Me I use both types and the performance is similar.
Old 12-23-2010, 08:30 PM   #225
Varc
Hey AirwolfRCPilot! When yea gonna get crack'n on the 120SR Airwolf? I really want one bad! It'll look so awesome with my red alloy from RKH. Plus, I think it'll have a much better chance than the MSR.
I wouldn't mind being a guinea pig for yea!
Looking forward to it, take care and Merry Christmas!
Blade MCPX BL
Rakon MCPX BL
Rakon MCPX V1
Rakon NCPX-TDR, DX7. Rakon Rep.
Varc is offline        Reply With Quote
Old 01-02-2011, 05:53 PM   #226
AirwolfRCpilot
Thanks Marc! And many happy flights in 2011 to everyone!
About the 120 SR the COG will be OK with the new shape but one thing keeps bothering me: the elevated tail of the 120 SR. Does anyone knows if there is a flat motor mount available similar to the SR version of microheli http://www.microheli.com/images/MH-SR3025_a.jpg
With the elevated motor mount it looks just not scale enough for me...
Old 01-04-2011, 11:12 AM   #227
Varc
Good question, I haven't thought of the tail. Look's like you might need to invent something for the fuselage.
Blade MCPX BL
Rakon MCPX BL
Rakon MCPX V1
Old 01-05-2011, 02:52 PM   #228
kalvinklein
Hi, where do I buy this.
kalvinklein is offline        Reply With Quote
Old 01-07-2011, 08:52 AM   #229
AirwolfRCpilot
I see you already found the way to my inbox AirwolfRCpilot@hotmail.com
Thanks!
Old 01-07-2011, 12:59 PM   #230
bumer
Thanks!
Hi!
Do you happen to know whether your Airwolf canopy fits to a Nine Eagles Solo pro. It looks fairly similar to a mSR.
bumer is offline        Reply With Quote
Old 01-07-2011, 01:55 PM   #231
Mgy
Thumbs up I Received My Babywolf Fuselage!
AirwolfRCpilot is the best! I received my replacement babyWolf fuselage yesterday and it's nearly perfect! I didn't even have to do any cutting to make it fit my mSR. The first one had the slot in the tail in the wrong place and the motor hole for the one without the end cap. But not to worry! AirwolfRCpilot promptly replaced the fuselage with one of very high quality and even paid for return shipping. The babyWolf fuselages are shipped very well packed and are backed by excellent customer service. Here is a picture of my completed Airwolf ready to fly. I'm just waiting for my DX7 to charge before her first flight.
I made the first flights with the Airwolf. Flew 4 battery packs using Common Sense 150 mAh packs. Had to hand launch which was tricky until I got her dialed in, crashed a few times during this but no damage. Once I got her setup with the DX7 things were much easier. She is very stable in flight. I mostly hovered around until I got the hang of it then some FF. She handles very nicely once dialed in and flies approximately 5 minutes on a charge.
I would like to take off and land on a table. Does anyone know where I can get some reasonably priced semi-scale landing gear?
Mgy is offline        Reply With Quote
Old 01-08-2011, 08:33 AM   #232
AirwolfRCpilot
Originally Posted by bumer View Post
Hi!
Hi there, maybe it can be adapted to it but the Airwolf mSR has been developed to fit the mSR mechanics. The battery holder, the fixing for the rods etc. are perfectly matched for the mSR, not for the nine Eagles Solo pro. Thanks for asking
Old 01-08-2011, 08:49 AM   #233
AirwolfRCpilot
Hi, thank you so much for your comments! Glad you like my babywolf
for the mSR ultimate I used a 1/48 scale landing gear of a plastic model kit, that's the perfect scale for this fuselage. Of course they are very fragile and I don't think they can survive hard landing without being suspended like on the Airwolf mSR Ultimate. maybe you can try to find a 1/48 scale Airwolf or bell 222 kit and canibalise it. Another possibility is to use thin steel wires and a small plastic wheels but that's up to your creativity
Old 01-15-2011, 02:31 PM   #234
suprteck
will this fit the mcx2?
suprteck is offline        Reply With Quote
Old 01-16-2011, 01:36 PM   #235
AirwolfRCpilot
You might be able to adapt it but the fixing points are really made for the mSR so it won't just click into it's position like it does on the mSR. Maybe it's a good reason for you to take the next step: the mSR
Old 01-27-2011, 04:33 PM   #236
AirwolfRCpilot
Default Airwolf mSR R2 Concept
Hi there Guys, it's been a while since my last post but it doesn't mean my brain was on non-active
I came up with a new concept for the landing gear which is more simple, 0.3 grams lighter and even more durable than the Airwolf mSR Ultimate retractable gear setup: The Removable Retracts Concept or simply the Airwolf mSR R2 Concept.
Some data:
  • Total weight fuselage including retracts: 8,5 grams only
  • Total takeoff weight Fuselage + mSR + 120 mAh batt retracts on: 33,2 grams
  • Total takeoff weight Fuselage + mSR + 120 mAh batt retracts off: 32,5 grams
  • Flighttime with 150mAh batt and with retracts on: 4 minutes
  • Cruising at 75% to 80% Throttle with retracts on
  • Cruising at 70% to 75% Throttle with retracts off
Enjoy the pictures
ID:	204335   Click image for larger version
ID:	204336   Click image for larger version
ID:	204337   Click image for larger version
ID:	204338   Click image for larger version
ID:	204340   Click image for larger version
ID:	204341   Click image for larger version
Old 01-30-2011, 05:58 AM   #237
AirwolfRCpilot
Default Airwolf mSR R2 with extra mods
Since the AIrwolf mSR still is my favorite fuselage I love to challenge myself to make her look like the real lady. So I give you a glimpse of what's possible when you mod your own mSR fuselage. Take a look at the in-air-refuel pipe, the venturi pipes and the fuel caps. Hope this inspires you guys!
For your info: the weight with all the mods is at 9,0 grams at the moment.
I'd like to see pictures of your Airwolf mSR mods here, or maybe I could open a new thread on Airwolf mSR mods to let you show your own creativity based on the Airwolf mSR fuselage...
ID:	204790   Click image for larger version
Old 01-30-2011, 06:10 AM   #238
AirwolfRCpilot
Default Important info on the mSR mechanics
Sometimes people are complaining about having not enough power or flighttime on their mSR. I own several mSR's and on one of them I noticed the same problem: it had shorter flighttimes and was less responsive but I found out why!
The main gear was too tight on the main shaft. if you slide the main gear down for 0,1mm (just a tiny little play you'll notice the performance of your mSR mechanics go form 80% to 100%! On the Airwolf mSR as described above the throttle position was 10 to 15% less and the flighttime increased. It might also be the reason why some mSR's suffer from main motor or 5.1 problems. Hopes this piece of advise can help some of you
Old 02-03-2011, 05:09 PM   #239
Varc
Awesome bird AirwolfRCPilot! Awesome! But you know what's next? MCPX!
We'll definitely need an Airwolf for that baby! Think about it, a micro flybarless Airwolf!
Nice work on the landing gears, actually look's better than your original concept. Do they still go up and down semi-automatically?
Still looking forward to your 120SR version, but next we need a body for the MCPX!
Sweet!
Blade MCPX BL
Rakon MCPX BL
Rakon MCPX V1
Old 02-04-2011, 03:22 AM   #240
AirwolfRCpilot
That mCP X looks great but it seems it has a similar kind of elevated tail as the 120SR. That kind of tail keeps me from making a nice looking tail for the airwolf fuselage. With the motor above the tail it looks just ugly, it needs to be more scale. If the mCP X uses the same tail the only solution might be to find a plastic mold maker who can make a flat tailmotor holder to use with the scale fuselage. If the tail is less elevated the mCPX fuselage might come sooner than the 120SR. But first I'll have to save some to buy an mCPX...
As for these R2 gears: they don't go up, You can simply take them off to have the retracted look as you can see in the pictures. Simple as that, more durable, lighter and cheaper to make.
