Go Back   HeliFreak > R/C Helicopter Support > Blade Helicopters (eFlite) > mSR
mSR Blade (eFlite) Micro SR Helicopters Information and Help
Old 03-24-2010, 01:22 PM   #21
Varc
I still want one, but still don't got no MSR. Plus, I'm still unsure of the added weight being an issue here.
Blade MCPX BL
Rakon MCPX BL
Rakon MCPX V1
Blade NCPX, Rakon NCPX-TDR, Future NQX owner! DX7. Rakon Rep.
Varc is online now        Reply With Quote
Old 03-26-2010, 02:53 PM   #22
AirwolfRCpilot
Just add 5 gram to your new mSR and see if she can lift it. For a mSR in good shape it shouldn't be a problem. As I told you before: in case you need more thrust use the CNC blade holder and give the main blades a little more angle. But once again try the 5 gram trick before you do any mods.
For your information I'm working on an ultimate Scale Airwolf with scale landing gear, turbo's, nose antenna's, side guns etc. by using a genuine Airwolf mSR kit and a plastic Airwolf model. Everything will be scale and since it will be quite fragile due to all the details I'll use this one for easy demo flying. High speed and stunt flights will only be done with my sturdy original one w/o all the extra details.
AirwolfRCpilot is offline        Reply With Quote
Old 03-26-2010, 05:39 PM   #23
Heli-n00b
Kinda off topic: Got the Airwolf complete first season this week, watching it as we speak.
Heli-n00b is offline        Reply With Quote
Old 03-26-2010, 05:45 PM   #24
AirwolfRCpilot
That's the spirit!
Nothing more exiting then watching an episode and fly your Airwolf mSR right after this.
Old 03-27-2010, 09:42 AM   #25
Varc
I've got all three seasons. Don't bother with the fourth, rumor is it sucks!
I'd love to see your fuse with the extra details!
One reason why I love my CB180Q, it's a beautiful Airwolf with all the proper details in it and it flies perfect! Just wish I could some how retract the gears on it.
Blade MCPX BL
Rakon MCPX BL
Rakon MCPX V1
Old 03-27-2010, 03:17 PM   #26
AirwolfRCpilot
Stick to the 3 first seasons, the other episodes are just cheap spin off's with recycled material, don't even look at it, it will spoil the other episodes.
Let's get back to topic now
Old 03-28-2010, 04:14 AM   #27
AirwolfRCpilot
Default Airwolf mSR Ultimate preview
to the loyal subscribers of this Airwolf mSR thread I present a sneak preview of the Airwolf mSR Ultimate under construction. Here you can see the detailed turbo's and the retractable nose gear. The nose gear is perfect scale and, best of all: it really retracts!
ID:	147870   Click image for larger version
ID:	147871   Click image for larger version
Old 03-28-2010, 10:18 AM   #28
Varc
How in the hell are those tiny thing's going to retract? Are the main's going to be done as well?
This is going to be even sweeter! Can't wait to see updates! I love updates!
Blade MCPX BL
Rakon MCPX BL
Rakon MCPX V1
Old 03-28-2010, 01:12 PM   #29
AirwolfRCpilot
Since there are no free channels on the mSR mechanics the retracts are operated by hand. Yes the main landing gears are gonna be retractable too but they're a little more complicated so I'm still working on this issue. The aim is to make it fly with the guns (and the ADF pod) extended but leave the choice for the landing gear up or down. Just for your info, this Airwolf mSR ultimate is not going to be available for serial production since the fuselage is exactly the same except for the details which are gonna be done on this unique case.
Old 03-28-2010, 03:08 PM   #30
Varc
Well I figured that. What extra would it cost for you to replicate one of these "Ultimates" for me?
Blade MCPX BL
Rakon MCPX BL
Rakon MCPX V1
Old 03-28-2010, 04:50 PM   #31
RĒzĒ
hmm perhaps a sensor of some kind could be used to retract. for example if the heli was a foot or less from the ground, wheels down. otherwise wheels up...
RĒzĒ is offline        Reply With Quote
Old 03-28-2010, 05:01 PM   #32
Varc
His point is because of the MSR's receiver, there is no way to add an extra servo for retracting it. Plus, all those mechanical bit's and the servo system would be much more weight that the MSR does not need. I think what he's doing so far is pretty awesome and doesn't need anything fancy.
Blade MCPX BL
Rakon MCPX BL
Rakon MCPX V1
Old 03-28-2010, 07:01 PM   #33
RĒzĒ
never say never. where there's a will there's a way
Old 03-28-2010, 08:14 PM   #34
Varc
Again, all this would be more weight the MSR can do without.
Blade MCPX BL
Rakon MCPX BL
Rakon MCPX V1
Old 03-28-2010, 08:51 PM   #35
RĒzĒ
again, so what? people have done worse.
Old 03-29-2010, 06:10 AM   #36
AirwolfRCpilot
I'm affraid Marcwolf is absolutely right, the lightest servo plus a sensor would at least be an additional 4 grams plus 1 gram additional hardware plus 1,5 gram for the details would make the total weight over 38g. that's about 35% heavier than the original setup. I'm affraid it won't take off anymore and if it still does I do question the flightbehaviour and the limited flighttime.
Manualy operated retracts and details only add about 1.5 gram, this is still acceptable.
Old 03-29-2010, 08:27 AM   #37
RĒzĒ
then I guess it would require a motor upgrade
Old 03-29-2010, 10:05 AM   #38
Varc
I'm not sure if there is a motor upgrade suitable for the MSR. I did see somebody hack to death the frame and custom fit a brushless motor, but from what I've been told brushless doesn't really give more power, just makes it more efficient. If your going to go with a more powerful motor, different electronics package and what not, you might as well build the helicopter from scratch in which case it'll no longer be an MSR anymore.
Blade MCPX BL
Rakon MCPX BL
Rakon MCPX V1
Old 03-29-2010, 10:07 AM   #39
drshakalo
bigger motor means bigger batteries. i mean if you really need all that why don't you get a 500 with a 9 channel receiver. then you have all the power you need i happen to like the idea of retractable gear even if they are manual. its about looks when its flying gear up is gear up weather its manual or auto it still looks the same. i think its cool that 1 they are creating scale gear for it and 2 that they do retract
Blade 400/mSR/SR/Align 450 pro/Align 250/ Walkera 4#3b
drshakalo is offline        Reply With Quote
Old 03-29-2010, 10:15 AM   #40
Varc
I agree, keep the MSR simple or it'll loose it's charm.
I think what AirwolfRCPilot is doing here is just perfect. Nothing else is needed.
I'll save the retracts/lights for my 450.
Blade MCPX BL
Rakon MCPX BL
Rakon MCPX V1
