Go Back   HeliFreak > R/C Helicopter Support > Antique Out of Production and Vintage Helicopters > NextD - Rave 450 and 90
NextD - Rave 450 and 90 CJY Rave 450 and 90 Helicopter Kit - ND-YR-K001
Old 03-15-2010, 05:05 PM   #1
Janosax
Question Stubz to flybar angle
Hi all
what's the exact angle between the flybar and Stubz paddles?
Hard to translate from french to english... stock paddles are aligned with the flybar, Stubz are not.
My set is not exactly in symetry with the flybar, one paddle has more angle than the other one. Flybar is straight from end to end, I checked it, so I need to bend one extremity to have Stubz symetrics.
Thanks for help : )
Jean
Janosax is offline        Reply With Quote
Old 03-16-2010, 06:23 AM   #2
Janosax
The angle is not the incidence, which I've set to 0 of course.
When you look at the heli from the top, Stubz are not aligned with the flybar, they are a little bit oriented to the back. This is this value in degrees I really need to know.
Hope I'm more clear : ))
By the way how does this angle affect stability and vivacity? As stocks paddles are not as fast and are fully aligned with the flybar.
Thanks for help : ))
Old 03-16-2010, 11:25 AM   #3
Sky Dancer
Hi Jean,
Can you post a photo?
Don C
Sky Dancer is offline        Reply With Quote
