| 2.4G Futaba Radios Futaba 2.4G Radio Help and support forum |
I was flying a new T-Rex 600E yesterday with a small receiver pack (NiCd 4.8V 600mAh) and suddenly, the motor turned off. Fortunately, it was only 5 feet off the ground, so I auto'd without problem.
Afterwards, the rx pack was at 4.71 volts, so I think the receiver has a low voltage cutoff at 4.7v. I can't nail this down for sure, since the R617FS has no manual. Can anyone verify this? It was nice that I only lost the throttle channel, and not cyclic/collective. I've since installed a CC BEC Pro, and the problem hasn't returned. Yet. Last edited by jacobmarble; 03-17-2010 at 11:52 AM.. Reason: Receivers do have LVC. |
There is a video by another comapny that shows both their Rx and the Futaba working down to almost 3V
If you still had servos then it was not the Rx, if it goes you have nothing... I would suspect your ESC had an issue, either that or the throttle channel of the Rx, check yopour connections first
Dave Goblin 500, Vbar, BLS153, BLS251, Kontronic Jive & Piro MutliWiiCopter Scarab Stealth Armour, Scarab TriiKopta, Scarab Octa, Scarab Vampire |
The Futaba R617FS does cut the throttle at low voltage
But it should not kick in at 4.7v - should be much lower
Rave 450 | Lepton | Logo 400/500/600 | Aeolus | Sceadu | Freya | Avant FX | Raptor G4 Gryphon field rep |
Another theory here. I'm using 3x Align DS610 and a DS650, plus the GY401. The DS610s are very high torque servos, so they draw a lot of current. Could it be that the pack was substantially lower than 4.7 when the cutoff happened, and then the pack bounced back after the load was gone? I checked the voltage maybe 30 minutes after the flight, so there was certainly time for it.
then why did the servos keep working after the motor stopped, Its teh ESC or the Motor
#6 | |
#7 |
The servo will stop working before the Rx does
#8 |
The Capi - HF Support
Don't even get me started on how wrong that vid is.
SAB Heli Canada / RotorQuest/Compass Team KBDD Spreading capibara awareness since 2006 To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. |
#9 |
HFG, I am with you...
But i does show how low an Rx batt can go
#10 |
When the voltage reaches a predefine (low) level, the RX will cut the throttle but continue to operate (while possible)
This will be very evident to the pilot who will need to perform and emergency auto On the higher end RX's this can be disabled or also enabled on other channels I don't know what the voltage trigger is, I assume it's below 4v
#11 | |
I have verified that LVC did indeed kick in.
First, page 40 of the 7C-2.4 manual describes failsafe, including "Battery FailSafe" at the bottom of page 40. Quote:
Second, the rx battery that gave me troubles on Monday hasn't yet been charged, so I got it out this morning, unplugged the ESC throttle and BEC supply, and plugged in an HS-45 servo to the throttle channel and the rx pack. Before this test, the battery was sitting at 4.98V. Powered up, the voltage immediately drops to around 4.0V and continues falling fast, so I can watch the throttle (illustrated by the HS-45) behave normally for ~30sec, then go to 0%. The green light on the R617FS starts blinking red-green-red-green. A few seconds later, things get crazy as the servos start moving erratically, and the pack is showing well below 3.8V. So, the throttle being cut was caused by low voltage cutoff. I will now change LVC from 0% to something like 65% so that it's very obvious that I need to land, and at the same time have enough to land safely. Thanks for everyone's input. |
#12 | |
In the failsafe menu, the POS setting controls where to set the servo when the RX looses contact with the TX The RX LVC is hardwired to close the throttle at a set voltage On the R6008FS/HS you can turn the throttle LVC off or on On the R617FS - not sure if you can turn throttle LVC off
#13 | ||
#14 | |
You have not understood the manual or the difference between F/S and LVC
Try reading this again Quote:
You can set a throttle servo position for that incident but not for the LVC Why don't you set the F/S throttle setting (50%) and then repeat your bench test with this problematic battery You will then see that when LVC takes effect - it closes the throttle
| Tags |
| low voltage cutoff, lvc, r617fs |
