Old 03-17-2010, 07:19 PM   #1
rollinsr99
Default Need help on setup 3g trex 600 with ar7100r
Ok i am so confused right now..lol I have built the kit and now am on the servo setup.I know that i need to get everything 90 on the arms following the directions for all the link lengths.Here is what i got AR7100r reciever,align servos,align 3g setup,9303 radio.Im not sure where to plug all the wires into. pics,diagrams hell come over and help..lol I am just baffled right now. I think the reciever is confusing me that it has a regulated and non regulated ports
"You never know how strong you are until being strong is the only choice you have"
rollinsr99 is offline        Reply With Quote
Old 03-17-2010, 08:32 PM   #2
jondabear
cyclic servos go pluigged in to the 3g unit. Servo signal and power wires from 3g will b labeled . plug these into the unregulated portion of the rec. Tail servo goes into the 3g cu. rudder and gain wires go pkugged into the rec. on the regulated portion. Throttle servo, regulated portion. DO NOT use the "gear" output for anything except for maybe a sig. for a switch glo. use aux 2 for gyro gain. Set up radio in menu accordingly.
I know this sounds sparse but if ya let me know as u get to certain steps, ill help ya get through it.
jondabear is offline        Reply With Quote
Old 03-18-2010, 03:31 AM   #3
rollinsr99
Ok so if I got it right the 3g can handle the full volt from a 2 cell lipo? So only thing that gets put on the regulated side is the throttle and the signal wire ( gain adjustment) fron the gyro. You woulnd happen to have a pic or diagram of this would you ? Lol I am going to use a switch glo also.. Thanks for helping me
Old 03-18-2010, 05:32 AM   #4
kevinbourland
You have exactly the same set-up as I do, Switchglow and everything. I love that switch glow!!! I will take pics tonight and run through the settings if you wish!
kevinbourland is offline        Reply With Quote
Old 03-18-2010, 07:21 AM   #5
rollinsr99
Radio too?yes that would be Sweet that will get me in the air quick I'll be on tonight thanks you guy rock
Old 03-18-2010, 05:14 PM   #6
jondabear
Camera took a dirt nap. itll get replaced by the evening on fri.
Old 03-19-2010, 05:45 PM   #7
rollinsr99
just checking back to see if you guys have those pics
Old 03-19-2010, 07:07 PM   #8
rollinsr99
Old 03-19-2010, 07:53 PM   #9
kevinbourland
Here is a pic for the 7100r switch glo and 3g in a 600
Switch glow on the Top, unregulated portion of rec.
Then Aileron Right forward servo
Then Elev. Aft servo
Then skip Gear
Then Left forward servo Pitch
Then Throttle servo
skip gear
Then Rudder servo
Then rudder sensitivity
Engine sensor center back of 7100r
Old 08-08-2010, 01:15 AM   #10
ncunno
hi how are you?i was looking at a comment you have made on a post about a AR7100 RX you have said NOT to use the gain channel for the gain on the gyro but you didnt say why i was just trying to find out why you cant use it?any help on this would be great
thanks very much
nick
ncunno is offline        Reply With Quote
Old 08-08-2010, 01:31 AM   #11
ncunno
any help would be great i have one i need to set up
nick
Old 08-10-2010, 01:54 AM   #12
FrozenOne
Also curious about the gear channel comment. Are you using an x9303 Jondabear?
700N LE - 3G, 91HZ-R, SB-20FH-2, AR7100R, Edge 693FBL
600NSP - 3G, 55HZ, B320, 8717, 8900G, AR7100, Edge 603FBL
450 Pro & 450 SEv2 Stock Setups
450 SEv2 - SK360, MiniG, HKII-2221-6, CC 60, Edge 325FBL
250 SE - GY520, 290G & 250 Orig Stock Setup ---- JR 12x/Spek DX7se
FrozenOne is offline        Reply With Quote
Old 08-10-2010, 05:46 AM   #13
HiroboFreak
The gear channel on the AR7100R is used internally for Governor/Limiter speed adjustment.
Page 15 >
T-rex 700n VBar 5.3 Pro | T-rex 700e V3 VBar 5.3 Pro | JR DSX9 Limited
Team RCBits | Team Lynx
HiroboFreak is offline        Reply With Quote
Old 08-10-2010, 02:22 PM   #14
FrozenOne
Ahh I should have remembered that from setting mine up but it's been a while. Ty for the answer.
