Old 03-19-2010, 08:53 AM   #1
4n6days
Default How can I keep my tail blades off the ground?
I'm running KBDD tail blades and they stick out about 1mm below the vert stab. I had a ping pong ball glued on there before, but I'm ready for a less silly looking solution. Ideas? Solutions?
"For in six days,
the LORD made heaven and earth,
the sea, and all that in them is" --Exodus 20:11
4n6days is offline        Reply With Quote
Old 03-19-2010, 09:02 AM   #2
Daman691003
change the tail blades... or make a 500 tail fit fit on and dremel it down to size just guesses i have never done it.....
Daman691003 is offline        Reply With Quote
Old 03-19-2010, 09:03 AM   #3
lildjloop
flying the heli keeps the blades off the ground.
Trex 500 ESP - Vbar
Trex 550E - Mini Vbar
JR X9503
lildjloop is offline        Reply With Quote
Old 03-19-2010, 09:42 AM   #4
snjbird
snjbird is offline        Reply With Quote
Old 03-19-2010, 09:45 AM   #5
Wrench 54
Take a old flybar/pushrood/piece of pianio wire as small of dia needed and bend you an extendtion and att it to the tail fin, I would probley also bend a 90 at the upper part and drill a small hole in the fin and put it in the hole then use thread with ca/expoxy and wrap the wire to the fin nice and neat to give it strength sand it and paint over it to make look nice, most would just buy a larger fin and go that route-----Wrench
Wrench 54 is offline        Reply With Quote
Old 03-19-2010, 11:00 AM   #6
jockstrap
You could use a 450 pro stabilizer - they are a bit longer than the V1/V2 ones as the pro tail blades are a fraction longer.
But I had pro tail blades on my V2 and they still were not longer than the stabilizer?
Why do you need such long tail blades ???? why not use standard ones and avoid all the issues? After all, the top 3D pilots were using them fine not long ago so I really can't see the need for such long blades unless you want to give Mr A.Szabo a 3D challenge ...
DX7 Mode-1 | T-Rex 250 | EP200 V2 | Tricopter | Quadcopter
450 pro 6s fbl | 450 pro beastx | Schweizer 300C Gasser Scale |T-Rex550e vbar | Aeolus 50 beastx
HeliX T-Rex700 fbl Gasser beastx | HWC600 321puh Gasser fbl sk540| Henseleit TDR vbar
jockstrap is offline        Reply With Quote
Old 03-19-2010, 05:55 PM   #7
markleyland
I use low profile gorilla gear on the front and regular on the back which keeps the tail in the air and looks pretty cool too.
"Sort your head out and fly with your heart"
Trex 450 SE V2: 9257 tail, Spartan Quark, HS65mg cyclic, DX7-AR7000, NEU 1107h/2y, Jazz Esc,
Trex 550 FBL: Jive 100+LV, KDE/NEU 1907H/1/N42, Vbar 5.3, Futaba BLS 251
markleyland is offline        Reply With Quote
Old 03-19-2010, 05:58 PM   #8
jondbennett
Team Taco Member
Lightbulb Spacers
If you have any of the little frame spacers that go between the outer and inner frames, you can put a couple under the back landing struts between the struts and the frame.
Actually, any little spacer will do. Also, it does not take much.
Jon Bennett (AMA #836296)
T-Rex 450S CF: HKII 2221-8, BL35G, GY520, HS65MGs, R617FS, Futaba 7CH (2.4)
Align Metal Head/Tail, Align 325 woodies, 1191s K&Bs, S9257
Planks: US Aircore Trainer 40, Acromaster, Tiger 2 Kit, RealFlight G5
jondbennett is offline        Reply With Quote
Old 03-20-2010, 03:48 AM   #9
Andy01
+1 - the GGs work well, and are pretty close to indestructible.
Colin
Vario Long Ranger 700e
Seahawk 600 - work in progress
Atom 500
Trex 450 SA hybrid
Andy01 is offline        Reply With Quote
Old 03-23-2010, 08:40 PM   #10
dropem05
A few guys I fly with put T-rex 500 skids on thier 450's to keep thier tail blades out of the grass. I believe you just drill a couple of new holes in the struts. It makes the whole heli sit a couple of inches higher. It looks pretty cool too. Give that a shot. I am about to get some for mine as well.
MCX, Lama v4-xtreme,Guru Z fixed pitch belt drive-brushless, Honey Bee King2 brushless -xtreme and Align parts. HK450, EXI 450,HK500,T-rex 500
dropem05 is offline        Reply With Quote
