Go Back   HeliFreak > R/C Helicopters > Painting and Airbrushing Tips / Techniques
Painting and Airbrushing Tips / Techniques Painting and Airbrushing Tips / Techniques
Old 10-15-2006, 01:56 AM   #1
byhsu
Default What kind of paint for my Canopy?
Hi:
I just got a clear canopy from Align. Now I would like to paint it. I know that most likely the paint will go inside, since the plastic is clear and it probably will act as protection for the paint. What type of paint to I need to paint this canopy and where could I get it?
Thank You.
byhsu is offline        Reply With Quote
Old 10-15-2006, 04:07 AM   #2
kgfly
I use the Tamiya lexan paint, normally sold for painting the inside of R/C car bodies. It bonds to the plastic without an undercoat and is quite flexible so doesn't crack or flake off (at least not so far).
I painted mine on the outside as I am too lazy to do it from the inside. I then used 3 coats of Tamiya clear coat after I applied the stickers.
Process:
1) Sand with 1200 wet+dry or grey scothbrite to remove all shine
2) Wash with mild soap to remove all dust and oil/grease from hands. Dry thoroughly.
3) Apply multiple light coats to build up the colour. No sanding between coats. Allow to dry 24hrs
4) Apply stickers. Allow to dry 24hrs
5) Apply 3 top coats, no sanding between coats. Allow to dry 24 hrs.
Kenneth
* MSH Protos Stock motor/15t/Align75/Align DS510/GL730+DS520/7s A123 2300
* TRex450CF/430L/12t/CC45/HS65mg/L2100T/KP 3s 2200 25C or 4S LiFe
Previous rides: HX242, W5-4, TRex450(HDE), TRex450(SE), QJ-EP8v2, BCX2 ,Logo10, Hurricane550
SIM: Phoenix (previously also Reflex/XTR, ClearView, RF, FMS)
kgfly is offline        Reply With Quote
Old 10-15-2006, 11:31 AM   #3
Ken448
You let stickers dry for 24 hrs???????????????
And you are waiting a bit too long to apply the clear coat. 48hrs after color is quite a bit without scuffing it first. Lexan paint usually dries to the touch in 30 mins, and is cured within a few hours. You are far too patient LOL
Ken
S/E MI
Did I mention my T Rex is afraid of heights?
Ken448 is offline        Reply With Quote
Old 10-15-2006, 02:59 PM   #4
byhsu
KGfly:
Great looking canopy. Did you have to cut something from underneath the canopy? I noticed you cut a hole on the sides.
Also, I want to paint the inside, so the paint won't get scratch up. do I need to sand the inside first? or can I just wash the canopy and dry thoroughly before I apply the spray paint?
Thanks.
Old 10-15-2006, 03:16 PM   #5
flymike
I normaly dont like just blue but that metalflake lookes great.
Earthlings are such strange creatures !@#
flymike is offline        Reply With Quote
Old 10-15-2006, 04:29 PM   #6
jgunpilot
kgfly,
Great looking canopy. What type of landing gear cross tubes are those?
jgunpilot is offline        Reply With Quote
Old 10-15-2006, 05:26 PM   #7
kgfly
Thanks for the compliments guys
bhsyu:
The white canopy is all I have ever worked on. It has grooves for those cutouts in the cheeks and under the chin. I don't think they are mandatory. They let some air flow through the canopy to help cool the battery/ESC. I'm not sure how effective or important that is. The chin cutout can also be used for getting access to the battery connector, depending upon your electrics layout and cable lengths.
I have never seen the clear canopy myself but I think that if the inside surface is shiny then the paint won't stick properly and it will need to be sanded. I guess at worst, if the inside paint job doesn't work out you can always do an outside paint job to cover it up. Painting from the inside does have the advantage of not getting outside scratches and having the natural gloss finish of the shiny plastic. I guess there is a small risk of scratches from the battery, cables/plugs or the mounting posts. Working with spray cans rather than an airbrush, I just don't have the skills or patience to paint on the inside, it's a rather small canopy after all.
If you end up painting from the outside on a clear canopy I imagine you will save paint if you put a white coat down (either on the inside or outside) to give a solid base for the colour. This isn't needed on the white or yellow canopies which are opaque anyway.
Be sure to post a photo back here when you are done so we can admire your work
jgunpilot
They are home made. See this thread: http://helifreak.com/viewtopic.php?t=17877&highlight=
Kenneth
Old 10-15-2006, 06:14 PM   #8
Efliernz
Kenneth, it looks great.
How is the orietation of the blue canopy against the sky (or it is always cloudy in Mebourne). I'm going to try your painting system on the window section of my yellow canopy only with the blue flake. The yellow makes a huge difference on a cloudy day compared with the basic white + stickers.
I broke my original 1 year old canopy two weeks ago. I was going to paint it... and then there were too many pieces of it
Pete Trex600 HC 3A cameraship
Trex600 AL GY401, DX7, LV-alarm,
Trex700 FBL HC Rigid cameraship DSX9, LV alarm
Check out my gallery for my low-volt alarms exported world-wide - http://efliernz.googlepages.com/home
Efliernz is offline        Reply With Quote
Old 10-15-2006, 06:41 PM   #9
Squirrlybird
It isn't good for clear canopies, but what works for me is the permanent marker approach.
First I color it in like my 3 year old daughter, then I go back and dab at it to remove all the streaks. Works lik a champ.
[img][/img]
Squirrlybird is offline        Reply With Quote
Old 10-15-2006, 09:10 PM   #10
Efliernz
Squirrlybird
excellent idea, :idea: :idea: :idea: I will get my 9 yo daughter to do it for me
Old 10-15-2006, 09:13 PM   #11
kgfly
Thanks Peter
How is the orientation of the blue canopy against the sky (or it is always cloudy in Melbourne). I'm going to try your painting system on the window section of my yellow canopy only with the blue flake. The yellow makes a huge difference on a cloudy day compared with the basic white + stickers.
Cheeky bugger Orientation seems to be my biggest problem. It doesn't blend in to the sky at the distances I fly (< 30m). It's either a dark silhouette if against the light or sparkly blue with the light behind me. I try to always fly with the light behind me. Mosty though at the moment I tend to save the blue canopy for indoor use and fly my dayglo orange training canopy for outdoors.
I presume you are not going to cut out the windscreen section, just paint it, which should work fine. I used the Tamiya metallic blue. I don't think painting the smoky windscreen would work too well as it is so thin and flexible.
Kenneth
Old 10-15-2006, 09:43 PM   #12
Efliernz
Cheeky??? At least didn't mention the wind or trees , oh. sorry...
I haven't cut out the canopy. I'll just paint it as you say (or use a marker). Especially now that I am throwing it around, I don't want to spend hours working on it to look pretty.... it still breaks...
Old 10-15-2006, 10:30 PM   #13
vadimr
Process:
What kind of a landing gear is that?
vadimr is offline        Reply With Quote
Old 10-15-2006, 10:47 PM   #14
kgfly
They are home made from a design by Tonke. See this thread: http://helifreak.com/viewtopic.php?t=17877&highlight=
Note: Get his second set of plans from near the end of the thread, they have a correction.
Kenneth
Old 10-16-2006, 02:07 AM   #15
Efliernz
Squirrlybird
It worked, it worked.
Black marker on yellow looks awesome and shiny
Old 10-16-2006, 02:19 AM   #16
kgfly
Photos Peter, we want photos :glasses2:
Kenneth
Old 10-16-2006, 03:11 AM   #17
Efliernz
Photos, well here it is. Still has original tail feathers from 12 months ago. I'll get the yellow set this week. Almost a stock XL HDE + 450TH.
It loops well Kenneth :glasses2:
Old 10-16-2006, 05:28 AM   #18
kgfly
Looks good Peter. Is that with a clearcoat or just au naturale ?
I see you chose not to cut out the cooling holes in the cheeks either. Is that an aesthetic choice, a functional one or just couldn't be bothered ?
Original tail feathers, now that's an achievement indeed. I gave up replacing mine. I have just the centre of a horizontal fin as the mounting point for the boom stay clamp and an aluminium-reinforced vertical fin that has survived many a tap on the ground now.
Kenneth
Old 10-16-2006, 12:10 PM   #19
byhsu
I am having trouble finding paint for the clear type canopy, as I don't know what material it is, anyone have any ideas? I got the canopy part # HS1068 Thanks
Old 10-16-2006, 02:04 PM   #20
Ken448
http://www2.towerhobbies.com/cgi-bin...p?&C=RHF&V=PAC
Pactra Polycarb you are painting clear Lexan
Ken
S/E MI
