Go Back   HeliFreak > R/C Helicopter Support > 700 Class Nitro Helicopters
700 Class Nitro Helicopters 700 Class Nitro Helicopters manufactured by Align, Tarot, SYMA, Airhog, Chaos, HK and similar.
Old 03-28-2010, 09:08 PM   #1
BadBear
Default flybar cage
Hey Guys I just finished my new 700 LE I notice the flybar cage has the slightest bit of movement all the parts are correct and everthing is tight is this normal if you grab the flybar it has a bit of movment side ways very little but its there.....
BadBear is offline        Reply With Quote
Old 04-01-2010, 07:23 AM   #2
rcer04
no movmet on my flybar rock solid
rcer04 is offline        Reply With Quote
Old 04-01-2010, 08:44 AM   #3
cation3
Yeah, you have to squeeze the flybar cage together when you tighten the set screws. That will eliminate all play. I had this same question about a year ago....
-Drew
cation3 is offline        Reply With Quote
