| Flight Stabilization Flight Stabilization |
Well, as I had posted before, on Saturday I flew inverted with no problem. Sunday I updated to v.1.40. Today Monday I went flying did 2 level flights without incidence.
By this time on my 3rd flight, the Sun was almost reaching the horizon, no clouds, 2/3 miles wind, 74 degrees temp., all systems go. I made high inverted hover, as well as high inverted FF and sideways.I climbed and returned to level flight. Then I descended to in order make a low circuit and land. As I was making a fast left turn, to begin heading my way, the heli suddenly switched to a perfect fast forward inverted flight, getting me completely desoriented, since I never expected such a move to take place. It was so quick that when I noticed the heli going down, I just reacted with positive pitch and you can imagine the end of the story. I really don't know what to think, since there has been another similar incident already posted a few days ago... Now it's late, I am tired and don't want to think how much money getting flying again will cost me.
Swift 16 w/7S A123 CopterX 450 w/A-123 Futaba 7C 2.4 - Co Pilot II Previous rides: HP Black Hawk 450 Esky Esmart 600 |
Sorry to hear about that dude, I know when things go wrong, it happens so fast, your left in a daze saying WTF just happened.
Hope you get your heli back in the air soon, FCA
My fantasies of flying a Heli, is better than the reality. To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts. JR X9503.FunJet Ultra, Scimitar, Stryker F27C and Q, DogFighter, mCPx |
Sorry to hear, and after things were going so well for you. Hope you find the reason for what happened
T-Rex600-ICE100,WR10ABEC,Scorp4025-1100+17T,Kasama head,QUK Swash CNC Tail,G-Force blocks,3152,DS760+BLS251,DX7+AR7000,FM. Blade400-CC ICE50,Scorp2221-8+12T,Sonix Head&Tail,5A BEC,HS65HB,Quark+3500G,AR7000,Align Carbon blades,TRex500 Skids,Flymentor. |
Locitur, I know the feeling of WTF type crashes which I had a few. For now I suspect the culprit being my radio DX6i rather than CP2. In all cases, the helis just all of the sudden veer downwards. It has never happened when the helis are high up but happens at lower altitude hence no time to recover but the helis do not obey my stick input when the crashes occure.
#5 | |
Sorry for the crash... I'm a newb and I know how it feels. My first crash was "landing " it with -12 pitch full throttle down.. it was getting close to a fence and I thought better land it... i was wrong |
#6 |
Tribe3,
I was already on level mode; nevertheless if the CP II is in inverted mode, but the heli is not inverted, it will not arm and will continue to act as in level mode. Thanks everyone for their encouraging words. I think it will take some time to get in the air again, since money right now is not at hand... But what makes me think is if I can really continue trusting in this system as it is or there is a bug in the new version that causes this to happen. I never inverted the heli at that stage of the flight and less being that close to the ground. Some other pilots who were watching thought I had inverted the heli and was bringing it back in low altitude FF...so stable and quick the heli inverted itself. Perhaps the position of the Sun a few degrees over the horizon "confused" the vertical sensor and made it think it was inverted and flipped over to return to level flight...I don't really know, but a similar thing happend to another member (Teej) that posted a similar situation a few days back.
Swift 16 w/7S A123 CopterX 450 w/A-123 Futaba 7C 2.4 - Co Pilot II Previous rides: HP Black Hawk 450 Esky Esmart 600 Last edited by Locitur; 03-30-2010 at 09:35 AM.. |
#7 | |
It may well be as you described where the sun was positioned, or perhaps a faulty vertical sensor. I would contact FMA and inquire about having your unit tested.
MSR, MCPX, 450s, 600, 650, 700, 800, 900, 1000 Assorted Mix Fixed Wing. AMA # 972083 |
#8 |
Locitur,
One question if I may.. exactly how do you have the CPII setup on your Tx? On a slider or 2 way or 3 way switch?
#9 | |
I have it on a 3 way switch - in the Futaba 7C FASST. When CP II is off I have autotrim in 6 degrees. After the crash I checked the radio to confirm that I had not swichted CP II off after doing inverted flight, and I confirmed the switch was in the level mode. I have begun assessing the damage and getting ready to rebuild as soon as I can!
#10 |
Do you have recovery set up?
#11 |
#12 |
Might want to contact FMA about your unit,
but after reading your post again it looks as you were banking the heli took it as approuching inverted attitude and fliped inverted on you, with out see it this is only a guess, but it may have to do with the way you Tx is set..ATV's Just a guess mind you but worth a look
#13 |
Mmmm, I doubt it because I had already switched to level flight mode, and if it had been in inverted mode, since I was flying level the CP II would not have armed inverted and just stay in level mode.
Perhaps the Sun's position close to the horizon and a temperature inversion close to the ground might have triggered a vertical attitude confusion... Nevertheless I will send the unit to FMA so they can see if there is anything there. CP II is a great system and really makes flying easier and enjoyable.
#14 |
This is true..but with this kind of technology, comes the gray area's
#15 |
I have already sent my CP II to Howard so they can check it.
The cost of spare parts to repair my Swift 16 are already over 50% of the price of a new Swift NX...I will have to analyze what step to take. What is certain is that I will be grounded for some time ...
