Old 03-30-2010, 11:03 PM   #1
frank26all
Default need help fast
I just received my trex 600 from a trade and it has a bec and I'm not used to binding a rx that has a bec,could someone PLEASE tell me how to bind the ar7000 to my dx7 ,it has the bec ,100amp esc stock brushless motor .thankssss
frank26all is offline        Reply With Quote
Old 03-30-2010, 11:19 PM   #2
frank26all
Default binding trouble
bump so I can get started
Old 03-30-2010, 11:53 PM   #3
Force3
Plug in the NiCad battery pack that came with your Tx using the switch harness supplied plug the binding plug to the extra leg of the harness and bind as per the manual.
Force3
Force3 is offline        Reply With Quote
Old 03-31-2010, 12:38 AM   #4
frank26all
Default problem solved
thanks force3,I don't have any mauals but I figured it out,I'm used to the 450 having a place on the rx for a bind plug and the esc in the throttle port.I realized my esc has no output for the rx so I put the rx battery pack in the throttle port and bind plug in the battery port and poof there it was. thanks anyway for the help.
