Old 04-01-2010, 04:39 AM   #1
tonyblade
Default Which motor for 12s?
Hi guys, just wanting some advice on what motor I should invest my hard earned on, it's a scorpion I want but do I get the 4025-630 or the 4035-560?? Or is there another on the way. I would like a good headspeed to do 3d, my 600 is running around 2150- 2200 and like it, but don't like 6s! I have read all the pages on 12s on a budget and the 4025 630 kv seems like the one to go for but want to make sure. I will be using the cc85 hv esc and am wanting to purchase these over the holidays, so any advise is appreciated, thanks tony.
trex 600 12s! 451, 760+251. trex450v2. 700 nitro, 760+251, 610,620,91h,hatori938,kasama header, 700 le gp750+650, 610,620,91h align pipe.12fg
tonyblade is offline        Reply With Quote
Old 04-01-2010, 06:10 AM   #2
hmurayam
I have installed 4025-630 along with 13T pinion on my 600ESP and I'm getting 2000rpm @90% and 2200rpm @100% throttle.
No way I can bog it. I've heard somewhere, however, that you get even more power from the 4035 but you'll need more juice from your packs.
__________________________________________________ ________________________________
700E / CC160HV / BeastX
600ESP-12S / CC85HV / Scorpion 4025-630KV / V-Bar 5.1
Scale Cobra Mini Titan
hmurayam is offline        Reply With Quote
Old 04-01-2010, 10:04 AM   #3
tonyblade
Thanks hmurayam, what do you set your timer for? Am sure the 630 would be plenty powerfull enough for me, but you know what it's like, always looking for the latest and best!! Well unless some other guys chime in it looks as though it's the 630kv scorpion. Thanks tony.
Old 04-01-2010, 12:34 PM   #4
Whopper Chopper
On an impulse, I bought the Z-Power Tonic-x Z50A 780kv.. Has anyone had any experience with this motor on 12s?
Specification:
No Load : 1.7 Amps
Max Current: 60 Amps
Diameter :48.8mm
Length :60mm
Shaft Diameter: 5mm
Max Eff: 83%
Poles: 8
KV: 780
Weight: 352g
Input power: 6-12 cells Li-xxx
Whopper Chopper is offline        Reply With Quote
Old 04-01-2010, 02:26 PM   #5
Brett74
I am getting a 4025 550kV custom wound from Scorpion, they will be coming out standard soon, the advantage of the lower kV is that the motor pinion can be bigger which helps to avoid stripping and also the lower kV motors are said to be "torqueir" , a new word for something with a lot of torque ! I have also read that the lower kV motors are more suited to being governed because of this said torque, I will post on this when my stuff arrives and let you guys know.
Goblin 770 4540 395 Sig 16S YGE 160UHV VBar (gov)
Goblin 700 4530 540 LE 12S Ice 2 160HV VBar (gov)
Brushless MCPX
Brett74 is offline        Reply With Quote
Old 04-01-2010, 03:54 PM   #6
nightflyr
Been using Neu 1915, 1917, 1920 and the new KDE/Neu 1917, all perform quite well
nightflyr is online now        Reply With Quote
Old 04-01-2010, 05:07 PM   #7
tonyblade
Thanks Brett, your reply is interesting I might just wait until that lower kv comes out as I think I would be using the governer. Tony.
Old 04-01-2010, 10:02 PM   #8
caralmar
I tached mine just today! 4025-630 running 13T pinion, on Turnigy 3000mAh 35C packs, got 2300RPM at the start of flight and 6min later was still at 2050RPM. That's perfect for me! This is on a 100% flat curve.
Scored a little over 2100 on a 90% flat curve.
After 6min flights, still have plenty of juice to land and be under 80% rule.
Rush 700 * Trex 700N x 2 * Trex 600Pro * Goblin 570 * 450L Dominator - V-Bar on all
AMA #934662
caralmar is online now        Reply With Quote
Old 04-02-2010, 12:33 AM   #9
tonyblade
Hi caralmar, 6 minutes sounds good to me, can I ask are you happy with the 630 kv ? Tony.
Old 04-02-2010, 04:41 AM   #10
tonyblade
Also just realised the 4035 630 kv has a 6 mm shaft, so would this be any better than the 4025 630 which only has a 5 mm one? Still don't know which one to get! Help.
Old 04-02-2010, 11:13 AM   #11
caralmar
Tony, I'm thrilled with my current setup. I'm just doing some mild 3D as my skills progress, but do enjoy flying aggressively, fast, and doing lots of high-collective stuff, and so far, so good. The setup is powerful enough for anything I've thrown its way.
As far as the 5mm vs. 6mm shaft, I thought someone else said its hard to find pinions for that 6mm shaft. The 5mm shaft with the Mikado 3012 or 3013 pinions works flawlessly. Just make sure you have a really good mesh with the gear and you'll never strip it. Too bad you're not in FL, or I'd let you see how good this 600 flies!
I think the 4035 630 is supposedly a 3d monster motor, but you'll drain your packs very quickly and not have good flight times. I think I read in the 12s thread that there was an LHS (grandrc I think) that had one of these setups for 3D and they were getting 3 min flights. That's no my cup of tea! I want to fly for a good 6min per pack, since I only have 3 of them!
AMA #934662
Old 04-02-2010, 12:27 PM   #12
azheliguy
caralmar, I can not find any 6mm pinions. I put a 6mm shaft in my 4025-630 and now no shafts. May have to put the 5mm back in.
T-Rex 600 ESP 12s, V -Bar 5.0 , Scorpion 4025-630, 610's, 8900G, CCIce 80HV, Hercules Bec
azheliguy is offline        Reply With Quote
Old 04-02-2010, 01:03 PM   #13
caralmar
Yeah, that's what I thought. Hey, I haven't forgotten about you or the 3rd bearing block thing. I lost the PM you sent me with your info... pls resend Albert!
Thanks,
Carlos.
AMA #934662
Old 04-02-2010, 01:58 PM   #14
azheliguy
Carlos, PM sent
Old 04-02-2010, 05:54 PM   #15
tonyblade
Thanks caralmar! Yea I don't like the idea of 3 minute flights so it's going to be the 4025. Thanks very much. Tony.
Old 04-02-2010, 10:38 PM   #16
caralmar
Sure! Good luck with it! Let us know how it works out.
Carlos.
AMA #934662
Old 04-03-2010, 05:18 PM   #17
rceccleston
Originally Posted by tonyblade View Post
I have read all the pages on 12s on a budget and the 4025 630 kv seems like the one to go...
Thanks for reading..
The 4025-630kv has more than enough power for swinging 600 blades, with respectable flights time, while few get approximately 3mins on 4035 series motors.
T-Rex 700e 'Chrome Edition', Skookum 720, Turnigy , Scorpion motors, Align servos. DX8 with Turnigy 4000Mah Li-Po
rceccleston is offline        Reply With Quote
Old 04-03-2010, 05:31 PM   #18
hmurayam
I set my timer to 7min and putting back 1900mah back to my turnigy 3000mah 30C sport flying @ 90% idle.
At 100% flat I'm landing after 6 minutes just not to force my batteries.
I bought my 630 with 5mm shaft just because it is hard to find pinions. I'm using align ones with little mod on top of the hole. I had to open the hole to 5mm on the upper side of the pinion. It's a easy task anyway.
regards,
Old 04-03-2010, 05:52 PM   #19
EatMorePizza
4035-400kv
ice hv 80
115 mod 1 main
revco 15 mod 1 pinion
3.0 turnigy 35-45c
i just test flew my 12s conversion for the first time today. Im working out some bugs with the esc settings and the mikado parameters. I went off the charts with a totally different setup. I get no sign of bog and i pushed it to the limit without stripping any gears. I only flew for 5:30 minutes and it seem I can squeeze some more out of the packs.
here are some graphs that i pulled from the data log. these represent the logs when I was doing tic tocs.
Name:	final run tt stripped.png
ID:	149182   Click image for larger version
ID:	149183   Click image for larger version
GOBLIN 700 SPEED-KOSMIK200-700XF-NEO-BK CYCLIC AND TAIL
TREX 700E-NEU KDE 1917-12 PINION-NEO -JR 8717 HV CYCLIC-MKS990 TAIL-ICE 160-KDE UNIVERSAL MOUNT W/PINION SUPPORT
EatMorePizza is offline        Reply With Quote
Old 04-04-2010, 09:52 AM   #20
meatbob
As far as 6mm pinions, the only ones I could find are
http://www.readyheli.com/RevCo_Hard_.../ho-0700h6.htm
Unfortunately, the 12/13T units are out of stock.
Logo 500 SK720, 4025-890, CC ICE 100
T-Rex 600 ESP w/3G - 12S, 4025-630, CC ICE 80HV
Blade 400 w/ HS5065MG, CopterX FBL, ICE Lite 50
eRaptor Conversion, 12S, 4035-500, JR 8700g, 3xDS610s
meatbob is offline        Reply With Quote
