Old 04-01-2010, 11:45 AM   #1
StoneGod
Default Best Trex 450 Motor Review/Comparison I've ever found
For everyone out there that is (or ever has) tried to figure out which motor they should get for their 450 to give them the best power, or longest flight times, or the best balance between the two.... This link will be of interest.
http://www.helituning.com/index.php/...uper-test.html
The review is from 2006, so it IS dated, but the info. is still very good and little has changed with the motors (if anything) since the review was done.
For those of you that don't care to read through the entire review here is a very quick summary (based on a 4s setup, Head speed of RPM).
Longest flight time/most efficient: Neu 1105H/3Y
Most powerful: Medusa 28-40-3400
Best blend of power and flight time: Neu 1107H/2Y
So there you have it. Buy what will give you what you are looking for.
There are enough people (new and not so new) that keep posting questions about motor selection, so this just might be worth making a sticky out of so people can find it easily in the months/years to come.
Anyway, my Neu 1107H/2Y is on its way to my door as we speak. I hope that this posting helps out with motor selection.
Best regards.
StoneGod is offline        Reply With Quote
Old 04-01-2010, 01:13 PM   #2
ksechler
Default Uh..yeah
That article is 4 years old. A lot has changed.
ksechler is offline        Reply With Quote
Old 04-02-2010, 06:34 AM   #3
markleyland
A lot? Like what? The Medusa is still probably the most powerfull and the NEU the most efficient. (I said probably)
"Sort your head out and fly with your heart"
Trex 450 SE V2: 9257 tail, Spartan Quark, HS65mg cyclic, DX7-AR7000, NEU 1107h/2y, Jazz Esc,
Trex 550 FBL: Jive 100+LV, KDE/NEU 1907H/1/N42, Vbar 5.3, Futaba BLS 251
markleyland is offline        Reply With Quote
Old 04-02-2010, 08:31 AM   #4
dizzymarkus
you should also list several others for info
Scorpion
Kora
Turnigy
JGF and their results
Happy flying,
Markus
dizzymarkus is offline        Reply With Quote
Old 04-02-2010, 04:44 PM   #5
Starcruiser
Scorpion
Kora
Turnigy
Happy flying,
Markus
+1
Carl
Trex 550E FS Vbar Pro 5.2- EXI-450T Mini Vbar Pro 5.2 - EXI 450T BeastX - Trex 250SE - mCPx v1 Hp05 & HP06 w/HP03t tails - AMA #952544
Starcruiser is offline        Reply With Quote
Old 04-04-2010, 12:10 PM   #6
StoneGod
It wouldn't be hard to add these motors to the list.... All that would need to be done is have someone with an eagletree on their heli run the same tests with them.
I don't have any of these motors (nor do I intend to put the coin into buying them just for test purposes), but if someone already had one or more of these motors and the test equipment they could post their results.
.....Any takers???
Old 04-04-2010, 01:07 PM   #7
DominicD
The Capi
Medusa no longer is making product for RC. I still have the Medusa 3400KV motor in my Frankenheli even after trying make 450 motors.
DominicD is online now        Reply With Quote
Old 04-05-2010, 12:16 AM   #8
snjbird
Me thinks you need more coffee... or maybe more sleep! lol
snjbird is offline        Reply With Quote
Old 04-05-2010, 12:26 AM   #9
DominicD
The Capi
I have a dyslexia with my problem.
Old 04-05-2010, 05:09 PM   #10
snjbird
Is that , ' after trying many motors?
Old 04-05-2010, 05:28 PM   #11
DominicD
The Capi
yes
Old 04-05-2010, 10:24 PM   #12
JBuck
I dont mean to hijack this thread,
But what is currently the most powerful motor for the 450Pro on a 3S setup?
I have the stock BL430SP with 14T pinion and seems pretty fast. Is there something more powerful?
T-Rex 550E, T-Rex 450 Pro, T-Rex 250 SE, Blade MCP X, Funjet Ultra, 3DHS 41 Edge, DX7, BC6
JBuck is offline        Reply With Quote
Old 04-05-2010, 11:11 PM   #13
bmlasater
fwiw..
My favorite is the Align 4050 Kv on 11t...Hard 3d for about 5-5:30, pretty easy on batts...Needs 25C or better packs to really come alive...
John.
bmlasater is offline        Reply With Quote
Old 04-06-2010, 12:56 AM   #14
DominicD
The Capi
I am still running my Medusa 3400KV on 14T, i get about 3:30min of 3D if it manages to last that long.
Old 04-06-2010, 07:38 AM   #15
snjbird
The Scorpion 2221-6 "feels" like the most powerful motor I have tried. I added a 2221-8 to my Pro, after about 150 flights, I needed to do a bearing swap, even with very regular oiling... So while I waited for bearings, I put the Align 450M back in, and it is really a very strong motor!
Old 04-06-2010, 02:19 PM   #16
ksechler
Default a lot
Medusa doesn't make motors, plus the scorpion motors arrived on the scene. I have a NEU and a scorpion and I would take the scorpion first hands down. It makes about the same power as the NEU and weighs a lot less.
Old 04-08-2010, 03:03 PM   #17
colson3265
Was doing a search looking for info so I can replace the ESC and motor in my 450 SE V2. I put in a PRO head and I am looking to increase head speed a bit. Have the stock 430XL and Align ESC in it. Was looking into a 430M or one of the Scorpion's. But alas this thread has failed me..so far. Maybe we can update it.
Chris
Rex 500 ESP / CC Ice 100 / Scorp HK-3026-1600KV /
Stock servos and Gyro (for now) Jr 7202 TX
colson3265 is offline        Reply With Quote
Old 08-03-2011, 12:26 AM   #18
RaceCarr
Default that motor is 130 dollars!1!!?//?//??
ill try the 17 dollar one
RaceCarr is offline        Reply With Quote
Old 09-12-2011, 04:23 PM   #19
rightto360
Default What about for scale?
I am looking to put a scale body on my 450 Pro V2. I have the 450M motor and the stock align ESC. Do you guys think that motor has enough torque to lift the extra weight i am going to add to the heli? Just scale/sprot flying. The hardest I will probably ever push it is FFF and stall turns.
Derrick
TREX 450 Pro
Futaba 9CAP
rightto360 is offline        Reply With Quote
